Old 03-26-2021, 05:22 PM   #51
mikentosh
mikentosh's Avatar
Re: SMOG LEGAL ENGINE SWAP TO LS yesterday passed!
Originally Posted by EricU View Post
Well my current plan is;
1) Wait to hear back from my local smog Ref to dial down exactly what my options are.
2) Hopefully find a compliant 2wd 6.0 or 6.2 with a six-speed automatic combo that fits in my GVWR window (8.5k - 10k) that I can start searching for a relatively low mileage one to purchase out of wrecking yard (how hard could that be???)
3) Get the OP Steve Van Gent, who is "only" three short hours north of me to come down for the weekends to help sort out the wiring BS.
EricU, when you talk with the smog ref can you clarify with them if the e-rod motors are acceptable for class 1 GVWR trucks? My understanding is that this is okay.
mikentosh is offline   Reply With Quote
Old 03-27-2021, 11:49 AM   #52
KQQL IT
At the body shop.
KQQL IT's Avatar
So if I was to swap this blazer. I wonder if it would require an suv donor
I should've re read the whole thread.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 03-27-2021, 11:56 AM   #53
EricU
Originally Posted by KQQL IT View Post
So if I was to swap this blazer. I wonder if it would require an suv donor being ca dmv doesn't call it a truck ?
No, it goes by GVWR.
Look at your door tag, my "guess" is that your in the 2a group (6k - 8.5k) which are pretty easy to find.
As mentioned before, you need to have ALL emissions related components in working order.
Sent by the random thoughts from the voices in my head...
EricU is offline   Reply With Quote
Old 03-27-2021, 12:43 PM   #54
EricU
The E-rods are only for vehicles with a GVWR <5,725 lbs - so check your tag.
If it does meet the criteria, they are a great solution in CA. You still have some other items that you need to address but it is much simpler.
CARB doc
Old 03-27-2021, 04:16 PM   #55
KQQL IT
At the body shop.
KQQL IT's Avatar
They're not a truck per the registration.
Hoping the 83 and prior no smog passes.
The op was a jimmy and they used a tahoe for a donor.
Why I should re read the thread
Old 03-27-2021, 06:31 PM   #56
EricU
Truck, Van or Suburban, it doesn't matter.
Your donor vehicle just needs to be in the same GVWR catagory.
What is the GVWR of your Blazer? That is step one.
Old 03-27-2021, 08:26 PM   #57
KQQL IT
At the body shop.
KQQL IT's Avatar
Door tags gone.
Has a CHP assigned vin
A '82 2wd that was a originally 305 t350 10 bolt
Been stuffed hard at some point, currently fixing a ruined frame we've gotten a bit of project on our hands.
Old 03-29-2021, 01:01 PM   #58
rodstored-72
chevy truck fan
rodstored-72's Avatar
steve, thank you for the info & right up.... I am looking to do a very similar situation here in AZ. I am wondering how you went about finding the CA guidlines for emissions pass requirements related to the swap? I know to call the "local" DEQ office, but looking for "terms or phrases" that you might pass along to help speak their jargon ... to explain what what was done...
thanks!
rodstored-72 is offline   Reply With Quote
Old 03-29-2021, 01:32 PM   #59
EricU
Originally Posted by rodstored-72 View Post
...I am wondering how you went about finding the CA guidlines for emissions pass requirements related to the swap? I know to call the "local" DEQ office, but looking for "terms or phrases" that you might pass along to help speak their jargon ... to explain what what was done...
In CA we have a website to start with AskTheRef.com
The CA BAR engine swap guidelines are listed here.
Old 04-03-2021, 11:54 AM   #60
Axle
Axle's Avatar
Originally Posted by nekkidhillbilly View Post
the trans thing is crazy how the hell does that make a difference in emissions. fuel economy possibly if you kept say a th350 or 400 but emissions aren't going to change. I wonder how they deal with
Think about how modern vehicles control the transmission and what gear you are in. A th350 cruising down the highway in 1:1 is going to rev higher than the overdrive computer controlled vehicle that is always attempting to keep you in the highest gear possible, and lowest rpm to not only keep fuel consumption down, but to also lower emmisions by keeping the engine in a certain rpm band for the given speed. Keith S. can probably give us an idea of how much time in development is spent on meeting emmsions targets, or how much it plays into what rolls off the end of the assembly line.
Axle is offline   Reply With Quote
smog engine swap ls
