Old 06-13-2020, 07:25 PM   #51
JUN1269
Re: My time... Nothing New. But it's my Build.
Single intercooler or dual....leaning towards two.
Freddie...
1969 Chevy C20 – Twin turbo Gen III 5.3 Restomod in progress http://67-72chevytrucks.com/vboard/s...d.php?t=793149
2006 Chrysler 300 SRT8 – Supercharged, Bored and Stroked 426 with nitrous: https://www.youtube.com/watch?v=uPAyVwL_C_I
JUN1269 is offline   Reply With Quote
Old 06-13-2020, 07:34 PM   #52
JUN1269
Turbo feed and drain routed through the frame
Freddie...
Old 06-13-2020, 07:38 PM   #53
dag19
dag19's Avatar
I'm with you...2!
What'd you paint your frame with? It's puurrrrty.
dag19 is offline   Reply With Quote
Old 06-13-2020, 07:40 PM   #54
dag19
dag19's Avatar
Also...what A-arm kit did you go with?
Old 06-13-2020, 07:43 PM   #55
JUN1269
Originally Posted by dag19 View Post
I'm with you...2!
Frame isn't painted yet...just sanded here and there.
Freddie...
Old 06-13-2020, 07:43 PM   #56
JUN1269
X2 Industries
Freddie...
Old 06-13-2020, 07:59 PM   #57
dag19
dag19's Avatar
Oh hell...it looked like a reflection in the picture! My bad.
Nice on the X2, how were they to install?
Old 06-13-2020, 09:50 PM   #58
cornerstone
cornerstone's Avatar
That's pretty funny. I thought the same thing...
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 06-14-2020, 10:02 AM   #59
JUN1269
The X2 was pretty straightforward to install. Did require a little modification and welding to c notch the frame for the rack and pinion....but couldn't beat the cost when I purchased at the time.
Freddie...
Old 06-17-2020, 10:37 PM   #60
JUN1269
How low can you go? Hmmmm.
Freddie...
Old 06-17-2020, 11:57 PM   #61
cornerstone
That's the money shot!
Brian
Old 06-18-2020, 09:32 AM   #62
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Looking at this is why I know mine will never be done. Love what you are doing on this. And glad to see you didn't go with the obligatory can crush shot.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 06-18-2020, 09:56 AM   #63
JUN1269
Thank you...my problem is I don't have a definitive plan or direction. Honestly, this wasn't the look I was initially going for, I just detoured and ended here.
Freddie...
Old 06-18-2020, 10:01 AM   #64
1971Stepside
Almost Satisfied
I had a plan for years and no time or money. I then began working on the truck and found I changed the plan completely. So, I guess that is what makes them fun. The build, the process, the figuring it out, and the driving....only to continue to change things as you go. I just know I don't want to do paint and body a second time Looking back, had I had a big pocket of money I would have rushed through mine and probably not been as satisfied with the outcome.
Old 06-24-2020, 09:31 PM   #65
JUN1269
Got the air lines connected. Fully deflated vs inflated shots...ride height.
Freddie...
Old 06-26-2020, 10:00 PM   #66
JUN1269
Exhaust frame pass through...
Freddie...
Old 06-27-2020, 11:24 AM   #67
raggedjim
raggedjim's Avatar
Nice work so far Freddie. Do you like the Vulcan welder? I've been thinking of buying a better welder.
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 06-27-2020, 11:54 AM   #68
JUN1269
Rg
Thanks Roger...For years I've toyed around with cheaper flux core welders, with no success of course. I was to the point where I started paying folks to weld simple tasks. Honestly, with this Vulcan, I feel I can tackle any project. I should've purchased a quilty welder long time ago.
I can't go into specifics as to which is better of the name brands vs the Vulcan. However, you cannot go wrong getting this one. In fact, after seeing my weld, friends went out and got the Vulcan.
Freddie...
Old 06-27-2020, 02:39 PM   #69
JUN1269
Is a sway bar needed if you're using a Watts link?
Freddie...
Old 07-27-2020, 01:28 PM   #70
JUN1269
Decided to go with 3.25 gears.
Freddie...
Old 10-10-2020, 03:25 PM   #71
JUN1269
Going with two air tanks. Just using what I have to accommodate that desire.
Freddie...
Old 10-11-2020, 09:11 PM   #72
cornerstone
Modifications to the bracket for the compressors and tanks looks good. Where do you plan to mount them? I mounted my 3 gallon tank between my rear mounted gas tank and the bumper and don't really have confidence that 3 gallons will be enough so I may relocate it and add another tank at the same time. Keep up the good work, I'm enjoying watching it!
Brian
Old 11-21-2020, 06:03 PM   #73
JUN1269
Sorry for the delayed response. I really don't have a plan. Just trying different things as I go, using things laying around the garage
Freddie...
Old 11-22-2020, 08:26 PM   #74
JUN1269
Steering gearbox removed. Switched to a rack & pinion setup. Thought that would a good spot for my remote oil filter
Freddie...
Old 11-22-2020, 10:26 PM   #75
cornerstone
What a sweet build! Where do you plan on placing the mufflers, outside the frame rails?
* Edit * I see they are already aft the trans cross member.
Brian
