Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 01-14-2023, 05:00 AM   #51
firedog
firedog's Avatar
Re: Project "Pandemic" 1927 Chevy Capitol
It appears I failed to mention before the kit includes GM metric calipers from 1980s monte carlo for example, the rotor is from a 2wd pre 90s ford f150, and there is an adaptor to fit the wheel bearings to the spindle as well.
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
Old 01-14-2023, 05:08 AM   #52
firedog
firedog's Avatar
Next up is a rear disk brake conversion on the 1977 model ford 9" that I am using. Parts i have ordered to make it happen, 1980 Ford Bronco front rotors, 1985 monte carlo brake caliper and pads, and a weld on metric GM disk brake bracket. I will also be making new 3 links as the ones that came with my axle are using tractor style Heim Joints and one recently broke when i dropped the axle.
*SOLD*
350/350 combo
Bagged/18" Wheels
Black on Black
'30 Model A Frame
Dual Carb 5.3 LS
2007 GMC 4 DOOR 2WD
2023 Jeep RENEGADE
Wifes ride
Old 01-15-2023, 06:06 AM   #53
firedog
firedog's Avatar
Looks like I am getting one of these tomorrow. Found one locally new in box. For cheap. Should look good on the top of my 5.3
*SOLD*
350/350 combo
Bagged/18" Wheels
Black on Black
'30 Model A Frame
Dual Carb 5.3 LS
2007 GMC 4 DOOR 2WD
2023 Jeep RENEGADE
Wifes ride
Old 01-16-2023, 12:54 AM   #54
firedog
firedog's Avatar
Picked up the intake today, brand new still in box sells on Holley website for $550 I got it for $250 off marketplace. I will get some pics of it sitting on the motor tomorrow! Now to find a matching eldebrock carb to match the other one i have sitting on the shelf.
*SOLD*
350/350 combo
Bagged/18" Wheels
Black on Black
'30 Model A Frame
Dual Carb 5.3 LS
2007 GMC 4 DOOR 2WD
2023 Jeep RENEGADE
Wifes ride
Old 01-16-2023, 10:59 AM   #55
Rickysnickers
Nice score
Old 01-30-2023, 02:28 AM   #56
firedog
firedog's Avatar
some pics of the intake sitting on the motor gonna look pretty good i think
Pictures of my newly built 3 link
*SOLD*
350/350 combo
Bagged/18" Wheels
Black on Black
'30 Model A Frame
Dual Carb 5.3 LS
2007 GMC 4 DOOR 2WD
2023 Jeep RENEGADE
Wifes ride
Old 01-30-2023, 02:34 AM   #57
firedog
firedog's Avatar
Attachment 2255133
Here are the parts to convert my Ford 9" to disk brakes. The conversion is simple, uses a Fullsize Bronco front rotor, metric GM caliper/pads just like the front and a weld on caliper bracket. I decoded the 9" to be from a 1977 LTD or Cougar with 2.75 gears and limited slip.
*SOLD*
350/350 combo
Bagged/18" Wheels
Black on Black
'30 Model A Frame
Dual Carb 5.3 LS
2007 GMC 4 DOOR 2WD
2023 Jeep RENEGADE
Wifes ride
Old 07-02-2023, 04:25 AM   #58
firedog
firedog's Avatar
Well i have fell behind here. I have done tons of work up to this point. It still does not drive but i did take it to a car show recently. It is currently on the back burner due to moving but i will finally have a garage with a concrete floor to work from and not in the basement with having to take out the rear end to get it out the door. It is not far from finally starting it but that will probably be a winter goal.
*SOLD*
350/350 combo
Bagged/18" Wheels
Black on Black
'30 Model A Frame
Dual Carb 5.3 LS
2007 GMC 4 DOOR 2WD
2023 Jeep RENEGADE
Wifes ride
Old 07-02-2023, 04:25 AM   #59
firedog
firedog's Avatar
can someone flip these photos over
*SOLD*
350/350 combo
Bagged/18" Wheels
Black on Black
'30 Model A Frame
Dual Carb 5.3 LS
2007 GMC 4 DOOR 2WD
2023 Jeep RENEGADE
Wifes ride
Old 07-02-2023, 10:03 AM   #60
Rickysnickers
Yep, done. Well done job on your truck!
Old 08-07-2023, 04:34 PM   #61
daveshilling
daveshilling's Avatar
That is a sweet looking rod!! This is a hidden gem hiding over here in the pre47
daveshilling is offline   Reply With Quote
Old 08-07-2023, 06:05 PM   #62
firedog
firedog's Avatar
Thanks for the kind words. This message board gets way more attention from the 67-72 guys, and that is exactly how i found the board. But there is not a lot of attention on the other area of this great board. I have more updates to post I just have difficulty posting pictures. they always end up upside down.
I did recently move and finally got the rat rod moved into my garage. All the work up to this point was in my old house in the basement. Name:  20230805_124750.jpg
*SOLD*
350/350 combo
Bagged/18" Wheels
Black on Black
'30 Model A Frame
Dual Carb 5.3 LS
2007 GMC 4 DOOR 2WD
2023 Jeep RENEGADE
Wifes ride
Old 08-07-2023, 11:12 PM   #63
3757chevy
3757chevy's Avatar
Here you go.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 08-08-2023, 09:03 AM   #64
Rickysnickers
Post away!! If pictures need to be flipped, I can do it by editing your post. It makes no difference what the orientation is, just put them up
Old 08-11-2023, 02:12 PM   #65
firedog
firedog's Avatar
My first real upgrade to my garage at my new home. The garage only had 2 regular light bulbs to light it up. I have been hoarding these 2x4 fluorescent lights after a a remodel at my work a few years ago. They had been upgraded to new ballast and T10 bulbs after an energy audit. I installed 7 lights in my 20x25 garage. Let the nighttime activities begin!
*SOLD*
350/350 combo
Bagged/18" Wheels
Black on Black
'30 Model A Frame
Dual Carb 5.3 LS
2007 GMC 4 DOOR 2WD
2023 Jeep RENEGADE
Wifes ride
Old 08-13-2023, 09:21 AM   #66
VWNate1
VWNate1's Avatar
Post Shop Lighting
They now have LED plug & play bulbs for that fixture, we put some in my brother's man cave and wow what an improvement .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 08-16-2023, 09:26 AM   #67
firedog
firedog's Avatar
I will have to look into that. Thanks
*SOLD*
350/350 combo
Bagged/18" Wheels
Black on Black
'30 Model A Frame
Dual Carb 5.3 LS
2007 GMC 4 DOOR 2WD
2023 Jeep RENEGADE
Wifes ride
Old 08-16-2023, 09:47 AM   #68
VWNate1
VWNate1's Avatar
Post Flourescent To LED Lamps
You'll need to read the package as some are direct plug & play, others want you to remove the old ballast first .
-Nate
Geezer
Old 01-08-2024, 06:00 AM   #69
firedog
firedog's Avatar
Ok folks here is the end of this build, I recently sold the ratrod after removing a few parts and selling them as well, with the sale I have purchased a late 1928-9 ish General Monarch Fire Truck and a 1976 4 door long bed gmc 3500 for a donor chassis 454/400 4/10 posi. Plans are to fab the firetruck onto the GMC frame after it has been bagged and have a very different bagged rat rod firetruck. Wish me luck!
*SOLD*
350/350 combo
Bagged/18" Wheels
Black on Black
'30 Model A Frame
Dual Carb 5.3 LS
2007 GMC 4 DOOR 2WD
2023 Jeep RENEGADE
Wifes ride
