Old 10-26-2020, 09:58 AM   #51
MDPotter
MDPotter's Avatar
Re: '69 C10 - Black on Black
We managed to get the other side of the hood and tubs and both sides of the doors and cowl in primer Saturday.
Also pulled the cover on the rear end and was surprised to see 2.76 gears. The SPID says 3.07 but it rarely matches actual conditions. This explains why the truck was a little underwhelming on acceleration. We've got 3.42 gears and a limited slip diff on the way.
It was 70* here Saturday afternoon and then the storm came yesterday and started out as rain in the 50's and temps dropped to 30* and 4" of snow by the evening. Definitely unusual for this early in the season, but it's needed to help slow the fires.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 10-26-2020, 03:26 PM   #52
TA_C10
TA_C10's Avatar
Yeah I saw some of the tragedy's already from the fires. My buddy lives in Westminster and was telling me about it crossing the CD.
3.42 eh? Gonna be a highway cruising machine
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 10-26-2020, 03:49 PM   #53
MDPotter
MDPotter's Avatar
At first I was thinking 3.73 but finding out that it's actually got 2.76's in it and the fact that the TH400 is not an overdrive transmission I decided to go with 3.42 as a good all around ratio. I don't see this as an interstate truck, but a highway truck and it should have good acceleration still. The 4.11's in my 68 have good acceleration but even with the overdrive 4L80E it still gets pretty high in the RPM's when you get to highway speeds.
Old 10-27-2020, 10:02 AM   #54
Low Elco
Looks Great! Thanks for the Raptor review, bought a new project and it's gonna get a lot of it.
Low Elco is offline   Reply With Quote
Old 11-02-2020, 10:34 AM   #55
MDPotter
MDPotter's Avatar
Got a few things done this weekend. Did a lot more welding on the cab as we had just tacked in a few things. Now the cab corners are fully welded in and all of the holes inside the cab around the rear window are closed up. Also committed a sin and cut the dash for a double din receiver. Lastly, installed new, longer wheel studs.
Old 11-02-2020, 10:39 AM   #56
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Looks like a good weekend and good weather. There are days I wish I would have gone the double din route...
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 11-02-2020, 12:53 PM   #57
TA_C10
TA_C10's Avatar
What were the holes in rear window?
"It's only money".
Old 11-02-2020, 01:27 PM   #58
MDPotter
MDPotter's Avatar
I've had the same question since we got the truck. Of course there were the normal 4 holes for a gun rack, but the others looked very factory judging from how consistent and flat they were. I've never seen any kind of trim inside the rear window of these trucks and this truck was a low-option truck so I'm stumped.
Old 11-09-2020, 01:34 PM   #59
MDPotter
MDPotter's Avatar
Finally have everything in primer. We used a self-leveling 2-part product in the drip rail and then a 1-part non-sag product where the drip rail goes vertical and smoothed the transition and it turned out pretty clean.
I'm glad to have the metal work done so we can move onto filler. Not that I'm excited for filler work, but it's a milestone and a step closer to paint. I'm not sure yet whether it's better to start with a factory bed assembly or reproduction. The bed assembly cost less than repop, but had to be sandblasted and is going to require a lot of filler and time. The nice part is that the panels all fit together very nice.
Old 11-09-2020, 02:48 PM   #60
TA_C10
TA_C10's Avatar
Moving right along, looking good man. I loved that self leveling seam sealer in my drip rail, it works so easy and looks nice when done. I just let mine drip down the vertical part and stopped it with tape. And while it was setting up I would manipulate where it stopped in tape by wiping the excess out and then shaping it with razor blade at tip when got hard enough to take tape off but before it completely dried. Doing it the way you did it however I can see that would take a little less time so kudos.
"It's only money".
Old 11-09-2020, 04:02 PM   #61
MDPotter
MDPotter's Avatar
I did something like that on my 68, but I didn't manage it well and ended up getting a little stringy. So I was happy when this came out so well.
Old 11-10-2020, 12:18 AM   #62
cornerstone
cornerstone's Avatar
What was the brand name of the 2 part urethane for the drip rails? It looks different than the 3M that I used. Your channel look more full than mine does. I ran a little short and want to add some more...
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 11-10-2020, 10:15 AM   #63
MDPotter
MDPotter's Avatar
It's an Eastwood product. It has a decent working time - as you probably already know, it's best to apply it and not touch it. With this stuff, you can go back and add a little bit if it doesn't quite flow out and fill the channel but you have to do it within 15 minutes or so.
Old 11-23-2020, 10:59 AM   #64
MDPotter
MDPotter's Avatar
We've spent the last two Saturdays doing filler work on the cab and bedsides. Mix it up, spread it, sand it, repeat. Not fun at all but the cab is 95% done and will be getting high build primer next weekend.
Also dug the bench seat frame from my 68 out of storage so we can use it on this truck. The seats that the previous owner bought were crazy expensive and not at all comfortable or appealing. So I ordered new foam and a houndstooth seat cover for this one. I almost wish I would have put a bench seat in my 68...
Old 11-23-2020, 11:32 AM   #65
1971Stepside
Almost Satisfied
Just looking at that makes my arms tired.
I'm glad I ended up going bench. I liked the buckets since it made it feel more sporty, but the bench is just classic truck.
Old 11-23-2020, 11:44 AM   #66
MDPotter
MDPotter's Avatar
Yep, my arms and shoulders were pretty dead yesterday. But having the cab this far is a big hurdle - it is by far the most labor intensive of the bodywork process and once it's painted we can set it on the frame and free up a little shop space.
I don't feel like my buckets feel any sportier or nicer than a bench - they just feel kind of bulky and out of place. The new black covers will make it much better, but the bench is classic like you said. But the console is a good place to hide my PCM and OBDII and for some other storage so it's not bad.
Old 11-24-2020, 10:23 AM   #67
kev2809
low n' slo
kev2809's Avatar
nice build ill be following along!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 11-24-2020, 05:38 PM   #68
sprint_9
sprint_9's Avatar
Making good progress. Im probably half crazy, but I think that looks like a lot of fun.
I like the modern split bench for its nice arm rest, but like you mentioned they are so bulky and the classic look of a bench is nice. Ill be excited to see how your bench turns out. Id really like a set of the old buddy buckets, but they are expensive and hard to find.
sprint_9 is offline   Reply With Quote
Old 11-24-2020, 07:25 PM   #69
MDPotter
MDPotter's Avatar
You're welcome to come join us in the fun! There's plenty to go around! I'm just glad I have my dad to help because it's a bit daunting to think about how much work it is. But having someone there working on it with me keeps me going.
Buddy buckets are nice - but yes, hard to find and expensive just to buy and old worn out set.
Old 11-30-2020, 10:50 AM   #70
MDPotter
MDPotter's Avatar
And the sanding continues...
I'm starting to see the light at the end of the tunnel on the bodywork. The cab now has high build primer and the bulk of the filler work is done on the doors and fenders.
Old 11-30-2020, 11:18 AM   #71
TA_C10
TA_C10's Avatar
Looks good man. You fill the roof seam?
"It's only money".
Old 11-30-2020, 11:43 AM   #72
MDPotter
MDPotter's Avatar
Nope, we left it as-is.
Old 12-08-2020, 02:50 PM   #73
MDPotter
MDPotter's Avatar
Getting really tired of sanding, but getting close to being ready for paint on the cab. I'm still not happy with a few spots so I'll have to do some more blocking this weekend and reapply. I'm nervous for this black paint job because it will show any imperfections in filler, blocking, pinholes, sand scratches, runs, sags, orange peel, dry spray, and dirt. I've considered going satin black but I think gloss black is timeless and right for this truck.
Going with the black theme, I sprayed epoxy on the radiator filler panels, radiator hold down, and inner fenders.
Old 12-08-2020, 02:54 PM   #74
TA_C10
TA_C10's Avatar
Looking good potter, nice to have a paint booth! Need one to finish my hood...
"It's only money".
Old 12-08-2020, 03:29 PM   #75
1971Stepside
Almost Satisfied
looking good potter, nice to have a paint booth! Need one to finish my hood...
road trippp!!!
