#51 | |
![]() Join Date: Jul 2015
Re: Pulling motor question
1963 C20, small window, long bed 292, 4-speed |
#52 |
Who Changed This?
![]() Join Date: Jan 2013
The different height throw out bearings are for Borg & Beck (three-"finger") or diaphragm clutch (many "fingers"). I don't remember which one goes to which, though.
#53 |
![]() ![]() ![]() Join Date: Jan 2018
In the picture you posted, you do have the bearing oriented correctly. The clutch fork has two tines that ride in the grooved area on the throw out bearing. When installed correctly, you should have one tine on top and one on the bottom, and they should be about center on the bearing.
The height difference is for the different clutch fingers. I ran into this 2 years ago when I did my engine swap and also put in a different clutch. I used the many finger style clutch, but for the life of me, I can't remember which bearing I ended up using. Anyways, if you didn't change the clutch, and you get a new bearing, just match it up with the one you pulled out
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#54 |
Started getting the rest of it together and tried spinning the starter. It just clicks. Sounds like the solenoid is kicking out the gear, but it is not spinning the motor. So, either my battery doesn't have enough power or there's something wrong with the way I installed it.
Geez, so close.
#55 | |
The flat finger which uses a long tob and the raised finger which uses a short tob. The raised finger style was developed because the flat finger type would tend to overcentre and the fingers would stick in the opposite direction. High rpm did that. When the rpm dropped again the fingers would violently snap back to normal. The early 64-66 Chevelle and gto’s had the problem. Clutch pedal would stick to the floor, you’d lift the gas pedal, rpm dropped and bang. Back to normal. If you were lucky it didn’t destroy a few parts. It was a holy crap movement when it happened to me. IIRC Borg and beck took a mid length tob as did the long style. Borg and beck used mostly by mopar. Long style used by ford. |
#56 | |
#57 |
If the starter is clicking, start with making sure your battery has enough juice. You want to see at least 12.3 ish volts at your battery to start with
#58 |
I do have at least 12.5 volts.
#59 |
Got a good ground from engine to frame? Also, double check your wires on the starter.
Here's how my wires were run before I did my engine swap and installed an HEI dizzy. The HEI removed the double wire closest to you in the picture
#60 |
Wiring should be correct. Purple wire goes to S terminal, the other double wire goes to R terminal.
#61 |
I would try it with the key in the on position.
On my truck, the battery grounded to the block, and then the block grounded through the engine mount bolts to the frame stand. I didn't think that was sufficient, so I put a ground strap from the same lug on the block where the battery ground was to a clean spot on the frame rail. I used an existing hole in the frame, so no drilling was necessary
#62 | |
EDIT: Ok, I messed up - forgot to connect the wire from the battery to the BATT terminal on the starter; it was resting on the frame member, couldn’t see it. Works great now. However, trying to start the motor... got oil, coolant, everything hooked up, but just not starting. I think it’s turning over too slow? My battery seems weak, like it’s just not strong enough. Going to charge it and maybe get a jump from another spare battery.
1963 C20, small window, long bed 292, 4-speed Last edited by Asshat; 11-03-2020 at 08:02 PM. |
#63 |
#64 |
Sounds good!
#65 |
Who Changed This?
It is green! (ST:TNG joke) Sounds like a little tappet noise, and some adjustments needed, but much better than before. Congrats! Nice work! I bet it feels really good, right about now, after all that labor and money!
#66 | |
Yeah, what a relief. Still need to run it, break it in, but at least it’s running. And, not that much money. At least for this time around. Gasket set, rings, miscellaneous stuff like paint and oil.
#67 |
The first go-around I had the valves adjusted way too tight. Could hardly get it to fire. Checked compression and realized it was really low. As soon as I backed off the valves, it got compression and I was able to start it up.
What is the best way to adjust these valves? Last time I tried, I could not distinguish the tapping. Maybe my exhaust was too loud. Plus, it gets oil everywhere, such a mess. And, I don’t have a spare valve cover to cut up.
#68 |
Who Changed This?
Get yourself a set of oil deflectors like this at your local auto parts store-
https://www.jbtools.com/vim-tools-v1...iABEgKj0vD_BwE
#69 | |
#70 | |
#71 |
Who Changed This?
Yes. They're only 7 bucks, man! I'd loan you mine, but postage would be more than they are worth. You might be able to trick out a few folds of aluminum foil, or something.
#72 |
Gonna give this a try, just stuff laying around.
#73 |
You need a bigger chunk of cardboard than that.
Just use a 6 inch wide piece bent around just like the shape of the valve cover. If you haven’t broke in your cam yet I wouldn’t keep idling it. You might get unlucky and get to rebuild it completely. |
#74 |
Cam was not changed. Should rpm fluctuate for breaking in rings?
#75 |
I thought you changed cam and lifters!
Anywho rings need load on them to seat. Acceleration and deceleration. I used to go on a 100 mile loop. Hard acceleration, then steady variable cruising and using motor to slow down. Doesn’t hurt to run at a higher rpm for 10 minutes on first start up. That ensures adequate oil splash everywhere. |
