05-16-2021, 11:33 PM | #51 |
I’m not trying to go super low with this truck just have essentially an old man hot rod hauler that I can use to run around and pick up parts and just have fun.
Posted via Mobile Device |
05-16-2021, 11:34 PM | #52 |
Here it is off the Jack. This old cowboy truck is a little less country and a little more rock ‘n’ roll. Can’t wait to get the rear done.
05-17-2021, 11:02 AM | #53 |
Re: My 1968 C-20 vermillion metallic...1 in a VERmillion
Look'n good in the Arizona neighborhood!!!
Amazing how the wheels and trim make it look sooo much better!!! Carry on! THat's how I would do it!!! |
05-18-2021, 07:05 PM | #54 |
Oooooo...dis gon' be goooodd.....
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
05-20-2021, 11:00 PM | #55 |
05-20-2021, 11:04 PM | #56 |
1/2 ton rear end. Gonna swap to 5 lug axles. ? On ring gear pic 11:41 assuming that’s teeth on pinion and ring gear. 3.73 ratio. Is that a date code on righ gear “GM 2-68” ????
05-20-2021, 11:43 PM | #57 |
Correct on the ratio numbers. I don’t know for sure on date code, it’s likely a 68 rear.
I’m sure I’m captain obvious, here, but make sure you get the correct length axles for the axle housing! If you get Moser axles, buy the studs AND have them install them, it’s worth every penny! I plan on 3.73 gears for my 67 and 68. If you DO need new gears, I’ve read that Motive gear is preferred, for reasons I don’t remember... |
05-21-2021, 07:58 PM | #58 | |
05-23-2021, 01:58 PM | #59 |
BlahBlahBlah
Are you going the CLR treatment and buff and wax when done?
05-25-2021, 11:37 PM | #60 |
05-25-2021, 11:40 PM | #61 |
Progress from Sunday. Rear end removal started.
05-25-2021, 11:43 PM | #62 |
Progress from today. Rear axle, rear 3/4ton springs, rear helper springs, rear bumper removed
05-25-2021, 11:51 PM | #63 |
Tie rods. 3/4 ton to 1/2 ton for 1/2 ton spindle. Just needed AZ Pro performance sleeves. I did not change 3/4 ton center link.
05-27-2021, 02:01 PM | #64 | |
chevy truck fan
one of these days we will need to meet over at each other's garage - I believe we are pretty close to each other.... |
05-30-2021, 01:27 PM | #65 |
Progress !! No more 3/4 ton now 1/2 ton with 5 lug swap.
05-30-2021, 10:32 PM | #66 |
Old school cool!
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
06-02-2021, 01:11 AM | #67 |
Plan is to test drive after I bleed brakes. Really digging this 1968 !!
06-02-2021, 11:10 AM | #68 |
Very nice and making progress! I think if you give that thing a good bath, a little CLR and maybe some polish here and there you will be getting waves and thumbs up all over town.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
06-03-2021, 01:08 AM | #69 |
What size tires did you use?
Did you get the bench seat re- done? Thanks for all you have shared. I’m sure there are other threads here that have converted a 3/4 ton to a half ton, but yours is first I’ve seen, Very well done! |
06-03-2021, 04:34 PM | #70 |
06-03-2021, 04:35 PM | #71 |
We got a driver. Time to start putting some miles on it and getting it all cleaned up.
06-03-2021, 05:06 PM | #72 |
Man............that boy is looking good. I love the wheel and tire package along with the stance now. And it is a full bed and not any of that short stuff.
06-03-2021, 05:44 PM | #73 |
To quote the immortal Jethro Bodine...
"Yeee Haaaa"!!! |
06-07-2021, 06:28 PM | #74 |
Weeellllll doggies! Looks great!
06-08-2021, 12:32 PM | #75 |
Thanks guys!
Seat time. Here is the before pics. Dropping seat off today to get upholstered. Posted via Mobile Device |
