Old 02-23-2018, 05:13 AM   #726
Tchuffman
Re: What did you do with your truck today, Part 3
mistake, sorry
Tchuffman is offline   Reply With Quote
Old 02-24-2018, 09:00 PM   #727
evilokc
after talking with vintage air about making my " hot rod " air system work I think ive given up. they said I can make it work but its a pretty hefty conversion. they sell an interior kit that will have all of the parts I need. its not cheap but it will have every part and they will be new and work as they should. I think I'm going to bite the bullet and purchase that kit. will take a bit to put the cash together though. I still cant find the correct size retaining clip for my shifter. I sent an email to b&m and hope they will answer me soon. I'm hoping t finish up my interior lighting tomorrow.
evilokc is offline   Reply With Quote
Old 02-24-2018, 10:40 PM   #728
Black_Sheep
Black_Sheep's Avatar
Got my speaker wiring roughed in and mounted the hidden antenna. Tomorrow I can finish up the wiring connections and test the sound system.
Black_Sheep is offline   Reply With Quote
Old 02-26-2018, 08:12 PM   #729
OrrieG
OrrieG's Avatar
What is the issue? I started with just a used VA inside evaporator and hoses thru the firewall I traded some other parts for. I got the condenser, dryer and condenser line kit from VA. Sanden compressor off Ebay (real not chinese knockoff). Bought hose locally and fittings off ebay. Friend loaned me his Mastercool crimping tool and I went to work. I found that overall I did saved a little, maybe 25%, over just buying a new kit from VA, but I had a different way I wanted to run the hoses.
OrrieG is offline   Reply With Quote
Old 02-27-2018, 01:15 AM   #730
evilokc
the evaporator kit I have is from a company called hot rod air. they went out of business years ago. the hot rod air units heat work off of vacuum and vintage air are all electric. to make the hot rod air unit work with vintage air controls I would have to convert the hot rod air unit from vacuum to electric.
Old 02-27-2018, 03:38 AM   #731
MiraclePieCo
MiraclePieCo's Avatar
'51 Panel: I got a used wood steering wheel mounted on my home made column. Then I replaced my pinion yoke ("modified" by a previous owner who cut the u-joint tabs off). Also installed the pickup tube, rollover vent and gauge sender in my gas tank.
Next will route fuel lines and then should be ready to drop the body back down on the frame.
MiraclePieCo is offline   Reply With Quote
Old 02-27-2018, 07:33 AM   #732
la hi
After talking with vintage air about making my " hot rod " air system work I think i've given up. they said I can make it work but its a pretty hefty conversion. they sell an interior kit that will have all of the parts I need. its not cheap but it will have every part and they will be new and work as they should. I think I'm going to bite the bullet and purchase that kit. will take a bit to put the cash together though. I still cant find the correct size retaining clip for my shifter. I sent an email to b&m and hope they will answer me soon. I'm hoping t finish up my interior lighting tomorrow.
I have a 57 swb and I purchased an under dash unit(called Freeze your As* Off and that did not fit. I put it behind the passenger seat instead and it blows cold air right up your armpit.
Then through parts houses I bought a condenser, a dryer, a compressor by VA, and had hoses made by my NAPA store.
The point is IT COST LESS AND FIT MY APPLICATION BETTER THAN THE PACKAGE PRICE. Try pricing it out as an alternative solution.
la hi is offline   Reply With Quote
Old 02-28-2018, 11:39 PM   #733
Kevin Mac
Kevin Mac's Avatar
Cool Re: What did you do with your truck today, Part 3
Operation see less gas tank and more coil over spring. Not crazy about the shiny tank hanging down so I am trying to raise it as much as I can. (1.75") had some 1 1/2" SS OD tubing laying around so I started cutting and tacking. Didn't quit get done with it but a good start anyway. Not sure either if you can notice just 1 3/4" but I will.
I guess my next question is how to rotate pictures?
Mac
Kevin Mac is offline   Reply With Quote
Old 03-01-2018, 01:53 AM   #734
robertsjm711
robertsjm711's Avatar
Sitting with new parts, searching for proportioning valve to master brake lines. In the kitchen. At 10pm. Oh, what an exciting life I live...
It was said that if you cut off one hydra head, two more grow back.
-Lernaean Hydra
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=743246
robertsjm711 is offline   Reply With Quote
Old 03-01-2018, 03:59 AM   #735
Tanman
Tanman's Avatar
I finally swapped out my races on my new rotors to fit my spindles. Put on my new dust shilds on the spindles, packed up the bearings and put the rotors on. Been needing to do this for a while.
Tanman is offline   Reply With Quote
Old 03-01-2018, 05:14 PM   #736
MiraclePieCo
Originally Posted by Kevin Mac View Post
Operation see less gas tank and more coil over spring. Not crazy about the shiny tank hanging down so I am trying to raise it as much as I can. Not sure either if you can notice just 1 3/4" but I will.
Mac
I understand. Not only is a higher tank more aesthetic, it's safer because it's less exposed to impacts. Another trick you could use to hide your tank would be to paint the underside flat black.
That looks like an awful lot of welding on that poor tortured filler neck; seems you could get a couple of 90* rubber hoses and connect them with tubing? They make moulded hoses that have extremely sharp bends. Heck, I've even seen guys use 90 PVC elbows for gas fillers (yes, despite what you've read PVC is gasoline resistant - here's the results of an actual test: http://www.spudfiles.com/spudtech_ar...pic.php?t=7896 )
Thanks for your posts - we'll be watching!
Old 03-01-2018, 07:30 PM   #737
Kevin Mac
Kevin Mac's Avatar
Thanks for reply. I had the tubing laying around the shop kinda deal. Playing around. Just about done. Little water test.
Old 03-01-2018, 10:52 PM   #738
Advanced Design
Advanced Design's Avatar
Nice work Kevin!
Advanced Design is offline   Reply With Quote
Old 03-02-2018, 12:47 PM   #739
gigamanx
Nice fabrication. Tig welded?
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 03-02-2018, 02:51 PM   #740
Kevin Mac
Kevin Mac's Avatar
Thanks guys, yes tig welded. I don't own a wire welder. I got the tank as high as I could, now to see how well it fills. Its nice here today so I will do that after work.👍
Old 03-02-2018, 07:03 PM   #741
MiraclePieCo
Nice work. If I'd welded that, it would be spouting liquid like a Freddy Krueger victim.
Old 03-02-2018, 08:03 PM   #742
Kevin Mac
Kevin Mac's Avatar
Ha ha ha, no leaks here. Pipefitter by trade. Don't do much welding on the job anymore, besides my eyes aren't what they used to be. Have to wear cheaters to just to strike a arc.��
Old 03-04-2018, 03:27 PM   #743
evilokc
does it have heat as well? my unit is a heat/air/ defost
Old 03-04-2018, 05:00 PM   #744
la hi
No unfortunately, another one of the mistakes I made. I bought the a/c only unit instead of both a/c and heater unit. Then I moved the truck to Colorado. Fortunately it snows a lot here and I haven't take it out this winter, therefore I don't look so bad with my lack of foresight.
Old 03-04-2018, 08:30 PM   #745
svr
svr's Avatar
Finished up welding and painting the exhaust system and got it hung, just a couple more brackets waiting for the paint to dry and will call it done. Am dumping exhaust down right in front of the rear ink ill like that better than out the side, just no room to go out the back with the C4 suspension and fuel tank.
57 short box, 235, T5, C4
http://67-72chevytrucks.com/vboard/s...d.php?t=739132
svr is offline   Reply With Quote
Old 03-04-2018, 08:31 PM   #746
svr
svr's Avatar
18" magnaflo glass packs
Old 03-04-2018, 08:32 PM   #747
svr
svr's Avatar
And out the back
Old 03-04-2018, 08:34 PM   #748
svr
svr's Avatar
Also finished up engine plumbing, pcv, vacum line, fuel line
Old 03-04-2018, 08:42 PM   #749
Kevin Mac
Kevin Mac's Avatar
Looking good SVR. Love the rearend.
Mac
Old 03-06-2018, 01:22 AM   #750
MiraclePieCo
What an original, creative and beautiful build!
