Old 01-30-2012, 08:41 AM   #751
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Originally Posted by screaminchevypickup View Post
Looks good mike!! Keep up the good work.
Thanks Kyle.
Originally Posted by scotts62 View Post
Very nice! : thumbs:
Thanks Scott.
Originally Posted by Crash_OK View Post
Great progress Mike.. you make it look easy… The spot welder looks like the way to go…
Thanks Mark. The spotwelder works great. I think it's quite a bit faster than drilling all the holes, welding and then grinding the welds. Gives it that factory pinch weld look too
Originally Posted by brn agn View Post
Nice work. Keep up the momentum.
Thanks Jesse. I know mine is a piece of cake compared to what you did on your cab.
I hope to be on the downhill side of this cab by the end of the week. I keep thinking it's going to get easier once the cab is done
mcbassin is offline   Reply With Quote
Old 01-30-2012, 10:30 AM   #752
sgaylord
Project collector
sgaylord's Avatar
Re: 1969 Short Wide
Gotta love progress! Keep on truckin Mike!
Steve
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel
Jezebel 3.0 NEW!!!
2020 GMC 3500 Denali Duramax
2016 Harley Street Glide CVO
Roll Tide!
sgaylord is offline   Reply With Quote
Old 01-30-2012, 05:15 PM   #753
68 TT
Still plays with trucks
68 TT's Avatar
Re: 1969 Short Wide
Nice work Mike. I'd like to pick up a spot welder like that eventually. Nice tool to have on hand.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 01-30-2012, 06:19 PM   #754
Daaaanz67
Re: 1969 Short Wide
Hey mcbassin just finished reading your build thread. I am new to this site and must say, I know you already heard it but i'll say it again awesome job! I'm only confused on one thing and it was the subject of off setting the motor to clear the a/c compressor. I am currently installing a 4.8l in my 69 c/10. I am using early classic enterprise mounts that appear to look just like yours including the towers. My towers are turned the other way Which has the big ears facing forward.That was were u made that little bracket to secure the tower. My a/c compressor seems to fit between the frame rails just fine but will have to clearance the upper frame rail a bit for the lines. My motor is an 06 with the small compressor did yours come with the large compressor? Is that why you offset the motor? Sorry not trying to high jack this build just confused.
Daaaanz67 is offline   Reply With Quote
Old 01-30-2012, 07:02 PM   #755
68 Four on the Floor
68 Four on the Floor's Avatar
Re: 1969 Short Wide
Cab is coming along. Good job
68 Four on the Floor is offline   Reply With Quote
Old 01-30-2012, 11:10 PM   #756
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Steve
Thanks Steve trying to catch up with your metal work buddy.
Thanks Mike, I have had it for years this is the first time I've got to put it to good use.
Thanks for the kind words and for checking out my build. As far as I know the compressor on mine is the same as your 06. I'm not familiar with the ECE mounts and stands. I guess you looked at the pictures HERE? I would like to see how you mounted you stands. I assume its a 2wd? On my engine the a/c compressor couldn't mount with the adapter plate in the standard location so I had to trim it off, move the stand back and drill some new holes. That's why added the brace because one side wasn't supported. The stands, mounts and clamshells are from stock a 73 and up 1/2 ton chevy. Also have you looked at THIS. It's where I got the info on cutting the adapter plate and bracing it. Glock shows a 73 up but it's basically the same crossmember on the 72 back.
Thanks Drew. Getting there.
Old 01-31-2012, 04:43 AM   #757
Daaaanz67
Re: 1969 Short Wide
I wish i knew how to post photos from my I phone cause thats where all my photos are. Now I kind of understand, the ece mounts do not use adapter plates. They actually have their own plate that mounts to the block. Their kit actually gets rid of 72 and down motor mount/towers and use 73-87 towers and motor mounts. My towers sit right on the crossmember just like one of the photos that you refered to in your last post. I also used the ece trans crossmember and they lined up with factory hole in the frame. This kit seems to center the motor, I think It moved the motor foward a little. You can go to their web site early classic enterprise or brothers truckparts to see the mounts. Maybe another member can chime in on this if i'm wrong. Oh yeh my truck is 2wd. You were more creative than me, you fabricated your on mounts I took the easy way out and bought a kit cause I don't have your skills. This is my first conversion but am able to do everything else build my own harness ect.
Old 01-31-2012, 09:10 AM   #758
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
I did most of the fabrication because I'm tight with the budget. If I think I can save a few bucks by making or modifying something I will. I guess you know how expensive these projects get in short order.
On the pictures, you should start a photobucket account to host all your pics. Then all you have to do is Click the picture icon at the top copy and paste the link in between the brackets ([IMG]paste image link here[/IMG])
Old 01-31-2012, 09:13 AM   #759
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
The other option and the one I just used. You should be able to do right from your phone is to select the attachment icon at the top and browse for the photo on your phone. It will automatically show up in your post resized. You can upload up to 5 pics at a time I think. They are stored on this site.
Old 01-31-2012, 12:46 PM   #760
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 1969 Short Wide
Great work Mike! That spot welder rocks! I'll need to look into one of them for sure for my next project!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-31-2012, 12:54 PM   #761
67cheby
67cheby
67cheby's Avatar
Re: 1969 Short Wide
yep that spot welder is too cool !
67cheby is offline   Reply With Quote
Old 02-02-2012, 03:52 AM   #762
fakerwade
fakerwade's Avatar
Re: 1969 Short Wide
Great work on the cab Mike! ,, I can't help thinking that if you lived closer "Tangerine" would be done by now!!! (why do all you seriously skilled guys live in Oklahoma??)
Wade
JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!!
Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570
Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro
fakerwade is offline   Reply With Quote
Old 02-06-2012, 12:38 AM   #763
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks Ryan, I'm finding myself planning to use in more areas.
thanks Mike I'm diggin it too.
Thanks Wade. It looks like you guys out in the west have it going on too. There is a bunch of skill all over the country. Just look around.
Old 02-06-2012, 12:42 AM   #764
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Re: 1969 Short Wide
Any new progress?
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 02-06-2012, 12:49 AM   #765
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Any new progress?
Working on an update with some pictures.
Old 02-06-2012, 01:00 AM   #766
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
On to the passenger side.
Old 02-06-2012, 01:10 AM   #767
67c10rustbuket
67c10rustbuket's Avatar
Re: 1969 Short Wide
Nice! you make it look so easy.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 02-06-2012, 01:53 AM   #768
Re: 1969 Short Wide
Lookin good. When you gonna get started on mine?
Old 02-06-2012, 03:13 AM   #769
68 TT
68 TT's Avatar
Re: 1969 Short Wide
Nice work Mike. You are making great progress. Your cab will be done in no time. Keep it up.
Old 02-06-2012, 08:44 AM   #770
Crash_OK
Crash_OK's Avatar
Re: 1969 Short Wide
Looks great Mike... Looks like the floor pan is spot welded in many places... I see now why you need the air chisel. You are making great progress.. won’t be long before you are priming and painting…
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 02-06-2012, 07:49 PM   #771
Daaaanz67
Re: 1969 Short Wide
Ok mike I'm really a dumb a***** cause I can't find those icon that you talked about on post 759. I have the I phone 4. Sorry I didn't get back with the request of you wanting to see my mounts still trying to figure this out. I did take more photos on passenger side to show how the motor is situated with the ac compressor installed. I'll keep trying, keep up the great work wish I had your fab skills going to get a welder down the road and try to learn.
Old 02-06-2012, 09:46 PM   #772
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: 1969 Short Wide
Way to tear into it Mike. Looking good!
Zoomin is offline   Reply With Quote
Old 02-07-2012, 12:16 AM   #773
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks. It is pretty easy labor wise, very tedious and time consuming.
Thanks Drew. I know you have a desert truck. It should take near this much lovin.
Thanks Mike. Plugging along as time allows.
Thanks Mark, Yep there are a butt load of spotwelds. If you don't know where they are because of all that rust it's hard to drill them out.
Daaaanz, I see your problem. I don't know if you can do a direct upload from an Iphone, If you can I haven't figured it out yet. I can however upload from my Iphone to photobucket and copy and paste the link here as shown above.
I think it's the best and easiest way. I just grabbed the photobucket app.
Thanks Steve. one step at a time. I have some questions about your paint. I'll shoot you a message.
Old 02-07-2012, 07:36 PM   #774
Re: 1969 Short Wide
Rust wise no. Some idiot must have jacked the truck up using the cab corners back in the day. Should be fun.
Old 02-08-2012, 12:18 PM   #775
Bowtie468
Bowtie468's Avatar
Re: 1969 Short Wide
Mike , your metal work is looking great !!!!
Chris
click here to see my buildpage
http://67-72chevytrucks.com/vboard/s...d.php?t=394656
1979 C10 Silverado Big10 SWB
Factory 454/400
Cardinal Red/Santa Fe Tan (original paint)
1969 Camaro X44 LS swap
1968 C10 SWB Fleetside (SOLD)
468BBC MultiPort TPI / Dynamic EFI P4
Black/Black
1963 Nova SS convertible (SOLD)
194 I6/ PowerGlide
Bowtie468 is offline   Reply With Quote
