Old 06-06-2012, 09:50 AM   #751
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Trying to get everything air tight. Broke a airhose, a fitting, pinched a front airhose. Ordered new hoses and a fitting. One of the new hoses is blocked. What a pain. Ordered 2 new hoses, one for a back up. Used pipedope when I redid all the fittings seemed to work much better than tape.
daverod is offline   Reply With Quote
Old 06-06-2012, 10:00 AM   #752
99 to Life
99 to Life's Avatar
Re: Daverods 52
good call on the pipe dope. good call on the extra hoses. I love having extras of things. I try and have double alot of tools even. But I have two living locations so it is nice to have that. Can't wait to see some test runs man.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 06-06-2012, 10:07 AM   #753
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Ya kinda getting excited. I can see a small light. Still need a few things.
Plug wires- need 90 at both ends. See if I can make something
Rad. hoses- lower one is going to be a pain.
Rad. outlet on bottom cut and moved down.
fitting for gas line.
trans lines
brakelines
and the list goes on.
Old 06-06-2012, 01:16 PM   #754
OrrieG
OrrieG's Avatar
Re: Daverods 52
Spare parts are good, when I go to the boonies I have a box with spare alt, starter, fuel pump and dist. Also duct tape, wire (bailing and electrical) JB weld, clamps, lots of tools. In 40 years have only had four incidents, brake pad failure (clamped the line), electical wiring from the switch to the starter and coil shorted out (used tail light wire to patch it up to get home), dumped a battery, had to use stream water luckily it recharged enough to get started and had to replace a fuel pump when i starved out on a hill and broke the diaphram.
For the rad hoses make a mock up with a hanger or welding rod and take it to the store. If the counter guy is sharp you will walk out with something close.
OrrieG is offline   Reply With Quote
Old 06-06-2012, 02:25 PM   #755
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
I'll have to remember those fixes. Someone said their fuel pump went out so they took a coffie can of gas and ran a hose to the bottom of it. He had the wife hold the can out her side window and they lived lhappliey ever after.
Old 06-07-2012, 12:12 PM   #756
99 to Life
99 to Life's Avatar
Re: Daverods 52
dang 1 incident every 10 years aint bad. daverod. see if you can take your prebent wire in the back and look for something. Heck I see the parts guys soo much they know me, so it's usually ok to go in the back and look for stuff.
Old 06-10-2012, 11:57 PM   #757
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Dog's really putting the heat on me to take him for a ride.
Old 06-12-2012, 02:20 PM   #758
focusedontheprize
focusedontheprize's Avatar
Re: Daverods 52
The rod is looking good. Looks like someone already called shotgun for the first ride.
What are you going with for rim/tire setup?
focusedontheprize is offline   Reply With Quote
Old 06-12-2012, 03:04 PM   #759
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Right now I just have stock s10 rims and tires off my horse trailer.I still havent made up my mind on whitewalls and 8x15's. Or somthing like 20" smoothie centerlines. I know what I really want but what I can afford is a different thang. Still need some spacers for the front. The rear is tight.1/4"
Old 06-12-2012, 03:12 PM   #760
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
http://www.chevsofthe40s.com/browse/...0T.html:metal: headlights and everthing else.
Old 06-13-2012, 09:10 PM   #761
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Anybody have a pic of how the heater control valve is mounted?
Old 06-13-2012, 09:43 PM   #762
99 to Life
99 to Life's Avatar
Re: Daverods 52
daverod,
here is a pic when I was going to run the ranco valve and OG heater. My valve leaked and so did my heater box, so I just got an aftermarket 3 speed heater. I can send you a pic of it if you like, but it was like 200 bucks for the kit. Anyway, here is the valve, I believe the hose closest to the firewall on the valve comes from your intake aka hot, then it flows through the valve and out the hose (second port on valve) to the heater, then from heater (should be colder by then, back to the water pump. I looked off of my 54' truck and that is how it was run I believe, so I ran mine the same way, but never checked it cause both the valve and heater box leaked.
Old 06-13-2012, 10:32 PM   #763
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
I'm hoping my stuff won't leak. It cost more to rebuild the stuff than a new one. ie rad core 170. rebuild controll valve 50. If nothing leaks its free.I was thinking the valve would be one the other side of the wall?
Old 06-18-2012, 10:59 PM   #764
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Put some oil in.Zinc stuff in oil. Hoses on, antifreeze in. Gas line hooked up.
Old 06-19-2012, 01:06 AM   #765
99 to Life
99 to Life's Avatar
Re: Daverods 52
sick, so your about ready for the breakin? working on an engine for my buddy, same stage with it. Getting closer man, all the hard work is worth it when its driveable.
Old 06-19-2012, 11:08 AM   #766
98layinframe
98layinframe's Avatar
Re: Daverods 52
Im rather new on this forum as this is the first ad truck I picked up recently, and just started looking thru your build thread here this morning.. I was quite shocked when i saw my pics of the lower control arms i made for my S10 awhile back! Glad they helped ya make an identical set that worked for ya!
91 s10 - bagged bodydropped 4", 350/700R4, narrowed reared, cantilever rear air bag setup
1951 chevy 3100 - in build/acquiring parts process. Have full C4 Corvette suspension front and rear, tpi 350, 700r4, 18" torque thrust II wheels
98layinframe is offline   Reply With Quote
Old 06-19-2012, 11:20 AM   #767
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
See your famous and you did'nt even know it. The pictures you took really helped. That's whats great about the internet you can find out how to do just about anything. A lot of times I just use this site as a place to store pictures of stuff I like.
Old 06-19-2012, 11:56 AM   #768
98layinframe
Re: Daverods 52
Pretty cool! Haha i haven't looked threw the entire thread yet, but are you running spacers on your front clip? If not how far from the fender lip is the outer edge of the tire?
Old 06-19-2012, 01:26 PM   #769
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
I'll need spacers. With the rims I have one there now its about 4 1/2 on each side.
Old 06-19-2012, 11:39 PM   #770
Layedoutsonoma91
Layedoutsonoma91's Avatar
Re: Daverods 52
Keep us updated, this is exactly what im looking for. Layin frame, i see u made the move from s10forum as i did. Lol. Still using a dime frame tho.
Layedoutsonoma91 is offline   Reply With Quote
Old 06-20-2012, 08:20 AM   #771
98layinframe
Re: Daverods 52
Yeah I like reading threads like this one since im debating on using the s10 frame i have or if i should just spend the time boxing and clipping the stock one. Both are in excellent shape, its just seems cheaper and smarter to use 50 year newer technology.
Old 06-20-2012, 02:48 PM   #772
Layedoutsonoma91
Re: Daverods 52
I just decided to roll with the s10 chassis. That way i can go to the local pars store and buy what i need, and cheaper. Plus im an s10 guy anyway. Know them like the back of my hand. Makes the most sense for me. Daverods is exactly what im doing minus the plates and interior. I love logging in and seeing a new post haha. Saved almost all the pics to reference back to.
Old 06-20-2012, 03:29 PM   #773
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Thanks Guys. I think the s10 is the way to go. Once you've done it once it would be so easy to do it again. Doing it the first time is the hard part. That and the money part. Just thinking about what to do is hard.Doing it is the fun part. Well ,buying new parts is pretty fun too. Ordered some plug wires with 90's on both ends. Straight ends would work on all but one plug.
Old 06-20-2012, 06:35 PM   #774
bulldog2513
bulldog2513's Avatar
Re: Daverods 52
man that thing is lookin good. look forward to the end product. guess i should be workin on my ride instead of on this computer lol
I'd Rather Push My Than Drive A Floppy Ol' Ford
1988 GMC Sierra SLE, 2 door, shortbed (Ol' Blue) (http://67-72chevytrucks.com/vboard/s...d.php?t=528216)
1995 GMC Sierra SLT Z71, ext-cab, long bed (The Beast) (http://67-72chevytrucks.com/vboard/s...d.php?t=531244)
1996 Chevrolet Tahoe LT, 4 door grocery getter (Mama's Ride)
bulldog2513 is offline   Reply With Quote
Old 06-24-2012, 06:40 PM   #775
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Went to Autozone and rented a oil pump primer. Got my new wires put on. Just bought a cheap gage and a tube kit so I can read my oil presure. Maybe I'll go get some gas.
