02-01-2013, 03:37 PM | #776 | |
Re: Project "What was I Thinking" 68 SWB
The G4L stands for Grounded 4 Life. It is a big Car & Truck club in PA and Jersey that I am a member of. Posted via Mobile Device
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 Last edited by Bennett68C10; 03-06-2013 at 11:48 AM. |
02-01-2013, 03:40 PM | #777 |
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
02-01-2013, 05:44 PM | #778 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-02-2013, 12:51 AM | #779 |
Must be nice Rob, between you and your son you guys will have three beautiful trucks to choose from. I'm jealous as I feel I'll never be finished with one
02-02-2013, 12:58 AM | #780 |
Man of Mini-Talents
Just remember Keith - its the journey that matters, not the destination.
Or some such b.s. Posted via Mobile Device
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
02-05-2013, 09:13 PM | #781 |
I need your guys opinions on something. Right now my front suspension consists of the stock front crossmember with slam ss7's and Porterbuilt forward arms. I'm thinking about changing it over to the Porterbuilt Touring Dropmember. The only thing holding me back is that i would have to sell my forward arms cause they only work with the stock crossmember. I guess this wouldn't be such a big deal as they should sell easily.
I already have the Mild Rear Dropmember on order and would like to match the front with the rear. I also like the fact that I can have a low ride height with much better ground clearance and also upgrade to rack and pinion steering. I like the touring dropmember better then the mild cause i'm thinking it will give me a little rake but without having to notch the frame or move the engine up like the Extreme version. Dave told me that the Mild Front would sit level with the mild rear when aired out and like I said I like a little rake. I guessing now is the time to do it since my truck is still in pieces. I would hate to have to do it after everything is painted and bolted together. Maybe a little work now will save me alot of work down the line. What do you guys think.
02-05-2013, 09:20 PM | #782 |
I have the extreme front and mild rear because I wanted a hot rod rake when air out. The frame under the front cab mounts sits on the ground and rakes back. The portion of the frame just under the rear cab mount and in front of the first bed mount is about 3" off the ground.
After talking with Nate he told me that the weight of the bed would make it sink another 1/2" to and 1". Not sure if that gives you an idea or puts you in the area that you want to be. |
02-05-2013, 11:15 PM | #783 | |
02-05-2013, 11:20 PM | #784 |
I did the mild front and rear. I'm running a 255/45/20 front and 295/45/20 rear. This is how it sits
Posted via Mobile Device |
02-05-2013, 11:25 PM | #785 |
Thanks I have your pics saved on my phone, I reference them often. Your truck looks great.
02-05-2013, 11:29 PM | #786 |
Thanks! I think you'll be happy with any of the dropmembers. Looking forward to seeing the finished product.
02-05-2013, 11:33 PM | #787 | |
02-06-2013, 07:44 PM | #788 |
Knuckle head
I love my mild dropmember and can't wait to see it completed. I say bite the bullet and do it now otherwise you will regret it and end up getting one regardless.
You can do it!!! -Adam
Adam '71 SWB/Step http://67-72chevytrucks.com/vboard/s...d.php?t=291750 2017 Crew Cab Silverado LTZ with 6.2l, 8 Speed tuned by RPM in Garner, NC '00 Chevy 1500 6.0l Silverado Reg. Cab Short Bed '09 Chevy 1500 5.3l Silverado Crew Cab Short Bed (SOLD) 1971 LWB on 2014 1 ton chassis, L96 6.0LS / 6L90E http://67-72chevytrucks.com/vboard/s...d.php?t=796785 1969 LWB C10- Future project, possible AWD C10 on a 2002 Escalade Chassis. |
02-06-2013, 08:57 PM | #789 | |
02-07-2013, 12:35 PM | #790 |
A guy with a truck
Touring. Do it
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
02-07-2013, 12:57 PM | #791 |
Man of Mini-Talents
May as well.
02-07-2013, 04:12 PM | #792 |
Thanks guys, I'm going to shoot Nate an email with some of my questions. I'm setup for the dropmember already with the sloshtubz and porterbuilt hinges so I might as well do it.
02-07-2013, 04:28 PM | #793 |
Man of Mini-Talents
Hey, we're here to help.
It would be worth your time to call Justin (owner) at Scott's Hot Rods while you're at it. 805 485-0382. You just committed to taking your build to a lower level.
02-07-2013, 04:37 PM | #794 | |
02-11-2013, 01:03 PM | #795 |
I want to thank Nate and Dave at Porterbuilt with all their help this past week. Nate and I exchanged a ton of emails back and forth as I was trying to decide what was the best direction to go with my front suspension. I wanted the front to lay out but was worried how much clearance I would have due to the Big Block/TH400 combo I have.
With Nate's guidance I finally decided to go with the Touring Front Dropmember with 1" narrowed tubular arms to help clear the backspacing on my front wheels and help clear my BBC as well. This will lay out the front on a 28" tire with my 2.5" drop spindles. I also decided to switch my order for the mild rear dropmember to the extreme dropmember. I figured might as well lay the whole truck out no point in going half way I can adjust my ride height to give me the rake I want while driving.
02-11-2013, 01:05 PM | #796 |
Also keep a look out on the for sale section. As soon as I can get my forward arms, shock relocators and shocks removed i'll be listing them for sale.
02-11-2013, 01:07 PM | #797 |
Man of Mini-Talents
You know this is what you wanted all along, so I'm glad you took that step. When do you expect to get your stuff - this is gonna be fun!
02-11-2013, 01:17 PM | #798 |
I'm glad I took this step as well, I don't why it was so hard for me to finally come to this decision. Maybe because now I have to redo my frame, but oh well in the end it will be what I wanted. Should have everything in a couple weeks. Still don't have the time to work on my truck but I will have plenty of parts waiting for me when I can
02-12-2013, 10:42 PM | #799 |
How do you like the boom mat. Curious, how many cans it took to do you floor. I'm planning on using it and doing my floor, firewall and the back of the wall of the cab.
02-12-2013, 10:52 PM | #800 |
I like it alot, leaves a really nice finish and definitely deadens the sound of the metal when you bang on it. I think I used 3 cans on the firewall and floor. I also used it on the inside of my doors when I re-skinned them. I still need to do the back wall of the cab.
Tags |
bbc, dropmember, intro wheels, porterbuilt |
