04-19-2016, 10:08 PM | #776 |
Re: Started my first frame off - 72 SWB LS1, 6-spd manual
Thanks!
Nothing better than trucking to the Pomona Swap Meet & Classic Car Show and hanging out with good friends. Truck ran amazing and did over 500 miles.
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
04-19-2016, 10:21 PM | #777 |
Still can't figure out how to post more than one pic at a time with iPad.
04-19-2016, 10:30 PM | #778 |
Pic
04-19-2016, 10:33 PM | #779 |
My first time to Pomona, it was a blast!
04-20-2016, 08:13 AM | #780 |
Still Learning
That looks like an awesome good time.
04-20-2016, 08:18 AM | #781 |
Definitely looks like it was a good time! Sounds like 500 miles of happiness to me
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
04-26-2016, 01:47 PM | #782 |
cool truck!! Do you have a close-up picture of your shifter knob, looks really cool
04-26-2016, 09:11 PM | #783 | |
Thanks..
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU Last edited by trkfrk; 04-26-2016 at 09:22 PM. |
04-26-2016, 09:57 PM | #784 |
lol, I love what it says for 6th gear!
05-25-2016, 06:42 PM | #785 |
Now the real fun begins. I still haven't decided if I'm going to go through the fire wall or kick panel with the hoses.
05-25-2016, 07:58 PM | #786 |
Roto Reuter thats the name...
Go through the kick panel so you can show me how you did it. That's where I want to go through when I'm to that point. Good luck with it. Truck is looking awesome.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
05-26-2016, 07:46 AM | #787 |
Still Learning
Very nice! I like the kick panel idea too but I'm not sure how it's done....
05-26-2016, 08:13 AM | #788 |
Nice, now you'll be able to be comfortable and cool inside that truck with those hot vegas temps!
05-28-2016, 12:55 PM | #789 | ||
Thanks Keith, were supposed to hit triple digits next week
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU Last edited by trkfrk; 05-28-2016 at 02:51 PM. |
05-28-2016, 12:58 PM | #790 |
Vintage Air did an awesome job on these lower compressor brackets. I can't believe how much more room I have now.
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU Last edited by trkfrk; 05-30-2016 at 03:30 PM. |
05-29-2016, 11:23 AM | #791 |
A guy with a truck
That looks like a great fit. Enough room to run lines?
Edit: is it an Alan Grove bracket supplied by vintage?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 05-29-2016 at 06:02 PM. |
05-29-2016, 10:24 PM | #792 |
Thanks Chris.. Looks like I should have plenty of room. Not sure what an Alan Grove bracket is? Here is pic of VA part number
05-29-2016, 10:37 PM | #793 |
The lines from my condenser through the core support are way to long since I have no battery and running low mount compressor. Now I need to modify the lines.
05-30-2016, 08:05 AM | #794 |
Lookin good.
06-02-2016, 11:36 PM | #795 |
06-04-2016, 07:23 PM | #796 |
Made a simple bracket for the evaporator to hang from the cowl and I'm going to use the engine oil dipstick bolt In the fire wall to secure the evaporator unit. It's the cleanest way I could come up with without drilling holes into the fire wall.
06-04-2016, 07:27 PM | #797 |
With a lot of research and pictures from this forum I have decided this is going to be the cleanest way to run the A/C & heater hoses through the firewall.
06-04-2016, 07:30 PM | #798 |
No one in town has the bulkhead fitting, so I had to order it from VA. Went ahead and pulled the hood and hood hing in preparation to make the holes needed to mount bulkhead fitting.
06-09-2016, 11:36 PM | #799 |
Bulkhead in
06-10-2016, 02:13 AM | #800 |
. Clean bulkhead design and awesome truck! . .
... Click here to see thousands of 'Abandoned & Neglected' Chevy trucks rotting away... ... |
