06-12-2017, 09:50 AM | #776 | |
Re: My 78 K15 High Sierra build - Fish Tremble
Those interior pieces look great Rick! Can't wait to see this thing completed already. Vroom Vroom! Chris
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636 Easier to beg forgiveness than ask permission! |
06-12-2017, 10:07 AM | #777 |
Good job getting your truck dialed in!
Probably went to the wrong address we've had that happen a few times!
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
06-12-2017, 01:20 PM | #778 | |
Well, not entirely dialed in. Yesterday I got a chance to start it up cold (well it was about 90 degrees in the shop) and it took a lot of nursing the throttle to get it warmed up. I suspect I still need to open up some things in the Quadrajet's idle circuit but didn't want to make more than 1 change at a time. But I wonder about a couple things it is hard to find specific answers on. Should the choke always close when I press the accelerator for startup, even when its hot outside? Even if the choke doesn't close, should the fast idle cam engage? Mine isn't so the engine is having to warm up at the ~650rpm regular idle setting. I suspect I've still got adjustments to make on the choke linkage. Oh, and just got good news. Even though the tracking number showed under the $50 shipping charge it was actually for the other part of my order - a couple of window crank handles which I did receive. Who'd have imagined it would cost $50 to ship a couple small/light items that cost < $10 Headliner hasn't shipped yet so not lost or stolen - whew!
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 Last edited by rgunlock; 06-12-2017 at 02:09 PM. |
06-12-2017, 04:46 PM | #779 |
Are you running mechanical or electronic choke?
Chris
06-12-2017, 06:13 PM | #780 |
Its an electric choke Chris.
Update: Yep, even on a hot day the choke and fast idle need to engage when you press full throttle to start a cold engine. I adjusted the choke until it did and engine warmup went much better. I'd already followed instructions for adjusting the bend in the choke linkage, adjusting choke pull-off, initial setting for fast idle, etc. I've probably still got some tweaking to do for choke and startup but at least in the ballpark now. Engine still surges on normal idle. I "think" that means I still need to open up the idle circuit some because I "think" this behavior means idle fuel supply isn't consistent. Any case, I'm closer. I'll be out of town the next couple weekends so this is where things will sit until I get more truck time.
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 Last edited by rgunlock; 06-12-2017 at 08:57 PM. |
07-19-2017, 12:12 AM | #781 |
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
07-23-2017, 06:44 PM | #782 |
Been to 2 weddings ( a nephew and a niece ) since I last posted, so not a lot of truck time. Still working out the carburetor issues. Posted in the Engine & Drivetrain forum and the advice I got was leave it alone. Just bump the initial timing up to 12-16 and work on the idle fuel mixture. Been working on that and it still runs "ok" but surges, making it tough to get a steady rpm, timing or vacuum reading.
Decided that I would add "installing headliner" to my list of least favorite tasks on this build, but got it done. Took so long in our 100+ heat index that my interior no longer smells like new car but now smells like sweat I bought some map pockets for the door panels, but the color just wasn't close to working. Bought some vinyl in a better color and have them at the upholstery shop getting sewn up. Other than the map pockets, I have to mount the rear view mirror when the glue sets up on the button and the interior is almost done. Almost because I'm going to re-do the seat again. Member TCKR was kind enough to meet me in Ohio on my wedding road trip and swap me a frame that uses the full foam and has a tilt back. Was cleaning up the frame for paint when my compressor started burning up a capacitor or something on the motor, so I have to get that resolved. I just plan to cut the hog-rings and re-use the bench upholstery I've already got. Pics of the headliner and interior, before - with sound deadener - and some afters. PS for anyone reading this and planning a headliner, the sun shades have to go in BEFORE you put in the a-pillar and side trim. Also, it helps to run masking tape along the upper windshield gasket and put marks where the screw holes are. That is the biggest pain part of doing one of these is to find all the screw holes under the headliner and trim. The pictures make the contrast in color between the trim and headliner look worse than it is. I think I'm going to like this!
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
07-23-2017, 07:04 PM | #783 |
Looks great! My last quadrajet convinced me to put on aftermarket fuel injection. The aftermarket fuel injection convinced me to swap a factory MPFI motor. I say quadrajet just because the monojet in my plow truck runs great and pulls down a solid 6-8 mpg haha. Good luck with the tuning.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
07-23-2017, 07:43 PM | #784 |
That looks awesome!! Did you use vinyl on your headliner? I ask that because it looks identical to you visors.
Can't wait until you get your seat done. I like to hear how it feels compared to the poor mans foam. I'm sure it will be BETTER!! Happy we were able to meet to do the swap. I know those full foam seat frames are hard to find. I've come across a few more recently.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
07-24-2017, 07:42 AM | #785 |
The headliner is Deluxe Vinyl Saddle that I got from Classic Parts that already had the foam-backed vinyl applied to an ABS plastic backer. This seems to be a very nice part that fits well as long as you can get it positioned properly. Got real lucky that it matches the used OEM visors I got nearly perfect.
07-24-2017, 09:55 AM | #786 |
Hey Rick. Headliner turned out really nice. I can relate to it not being the most fun. I did not enjoy doing the trim around mine as I recall. Glad that is over.
Sucks that the carb is still giving you fits. Probably not interested, and their certainly not cheap, but there are so many fuel injection options for these trucks now. It would certainly make life easier... You know, if money grew on trees and all. Chris
07-24-2017, 01:11 PM | #787 |
Thanks for the compliments. Sure beats the original interior all to heck!
At this point, I'll keep futzing with the carb because I just want to start driving before making decisions on upgrades. I've thought about the FI upgrade but haven't looked into it enough. Some reminders of the "before" on the interior...
07-24-2017, 01:34 PM | #788 | |
I recovered my headliner, but that wasn't so bad. My biggest issue was finding the original holes for the screws, on the garnishes. You wouldn't think that would have been that hard, but it was. I cussed, sweat and cussed some more, before I got all of it back in. So I'm with you on the "sweat"
07-25-2017, 04:19 PM | #789 |
When does it surge? I'm thinking lack of fuel, possibly a bigger main jet or needle too low or too fat, even a primary? Pending load and rpm etc.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
07-26-2017, 10:18 AM | #790 |
Man what a difference, beauty!
08-04-2017, 05:29 PM | #791 | |
Thanks so much! May have to get it out this weekend and see if its even possible for me to "accidentally" leave some marks on the driveway like a beautiful white dually I know of No pictures yet but I think I should be able to finish up my AC this weekend. I've made up and hooked up the hoses. Got a vacuum pump and AC manifold, kitchen scale and some R134a but discovered the compressor belt I'd got isn't long enough. Bought an insurance policy for it today. I know, it would have been smart to have had at least comprehensive coverage for some time now but... Since this is my own thread I'm going to rant a bit. Called my agent that I have 6 vehicles and my house covered through. They can only offer "antique" vehicle coverage that limits my driving to shows, parades and occasional pleasure cruising if I want an "agreed value" coverage. If I want to drive it anywhere, anytime I want (which I do) they can only offer the typical coverage. If I have to make a claim they will "consider" its restored state given that I can provide pictures and receipts, but will not guarantee me anything above KBB or NADA value. I asked if there was a way that I could avoid having them decide it was totaled if I was in an accident where the damage was repairable but perhaps more than THEY valued the truck (probably the case for anything worse than a fender-bender) - I don't want to have to deal with a salvage title if I decide to repair it myself. Sorry, can't do that either! If I were to purchase a $40K equivalent new truck, no problem with insurance. If I spend $20K restoring one to near-new condition they can't deal with it. Ok, end of rant. Did any of you have better luck finding a reasonable policy for a situation like this?
08-04-2017, 05:54 PM | #792 |
Just switched both of mine over to hagerty decent rates and they will insure it for anything you want to pay for with in reason no appraisals on my end. I gave my agent 5 pictures and answered a few questions about the truck and I was done. No issues full coverage.
08-04-2017, 06:28 PM | #793 |
I'd read that Hagerty's policies had restrictions on use of the vehicle, but haven't actually called and talked to them. Perhaps I should...
08-04-2017, 10:38 PM | #794 |
You should give them a call. I heard 4x4 was a no go from one guy, but that it wasn't a problem from another.
08-05-2017, 01:24 AM | #795 |
If you have issues let me know I'll give you my agents phone number. I'm sure she would love to sell you some insurance.
08-05-2017, 07:06 PM | #796 |
This is the culprit on my air compressor. Husky parts list only shows the whole motor ($$$) as replaceable, although this capacitor is easily serviced. Trying to figure out how to select a matching replacement.
08-05-2017, 08:22 PM | #797 |
We’ve used State Farm Classic Car and Anpac Chrome in the past, don’t know why I’ve never tried Hagerty (probably because we bundle home, etc. all with one company) but I do prefer Anpac Chrome and still use them currently. Never put in a claim so can’t speak to that, but really like the agreed value/replacement cost method and under 25k no appraisal is needed.
08-06-2017, 06:35 PM | #798 |
Far as I know I got the AC done right. Looks like 40-42 degrees out of the vent. Now I just have to find where the condensation leaking under the evaporator is coming from. Most, but not all is coming out the drain tube where it belongs.
Had my own little oops in the driveway. Neighbors were out walking so had to take it easy
08-06-2017, 08:36 PM | #799 |
Just so you know, I think I'm already using my truck as a truck. It is currently serving as the counter for my outdoor kitchen
08-06-2017, 08:59 PM | #800 |
That's the dream.
