#801 |
![]() Join Date: Jan 2012
Re: 1969 C10 SWB - Big Block project
I too prefer the deluxe lenses on this truck. Not to offend anyone who runs or prefers the van lenses, but they have always looked "stuck on" to surface of the fender (even though the screws are visible).
Hey Pops or Chad, would it be possible to get a pic of that bumper straight-on from the back? Almost, if not all of the aftermarket rear bumpers I've seen in photos have had that "frowny" arc to them. That one looks perfectly straight from the angles already shown. Thanks! The truck is looking terrific! |
#802 |
![]() ![]() Join Date: Jan 2011
We put the can divider trim on today and worked on the bed wood. I put one of the CST emblems on the door.. just a creative pic
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
#803 |
Well.. It was supposed to be rotated 90deg.. but..
#804 |
Still Learning
Looks great!
#805 |
Looking good!
I must be in the minority with the side markers. I personally put the van markers on my 71 because the aftermarket deluxe markers that were on it felt cheap to me. Especially since the chrome trim is glued on and can easily come off. Before owning a C/10, I thought they all needed the deluxe side markers since it looked so good. I don't think you can go wrong either way.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#806 | |
#807 |
We went with van markers because of the chrome on the deluxe ones are usually bad. I actually have several repro sets and they're all about the same, those chrome rings come off easily. Maybe someone has some NOS deluxe markers they want to sell?
I agree though, they'd both fit the look of the truck. I'd be good with either I just didn't want the flimsy chrome pieces.
#809 |
^^ this..
![]() I tried ! ![]()
#810 |
Has anyone who installed a Vintage Air system run into a problem with the mounting bracket that frames the heater inlet/outlet tubes? The supplied bracket in our kit doesn't look like the one in the instructions and blocks about 1/4 of the upper tube and almost 1/2 of the lower tube (photo attached). No way will the hose connections clear without grinding away the bracket openings.
I contacted Vintage Air several times last week, but as of now the problem has been handed down to engineering. What should happen is that Vintage Air send a correct bracket FedEx Overnight. Instead, we are stuck with the whole installation until we figure this out. POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
#811 |
That's really weird. I believe they use the same Gen IV unit for every Gen IV kit they sell, and just make a different bracket for the vehicle. I don't know why it would be misaligned so badly.
Did anyone suggest they may have sent a bad part, maybe one from a Gen II unit, or did you get just a bunch of I don't knows?
#812 |
What headers are you using.
#813 | |
#814 |
Hey Pop, just an idea what if that bracket is 180 Deg rotated? Do you think it goes the other way? Just flip it around maybe ? Do the recessed areas then line up with the fittings ? Maybe that bracket just needs to go on the other way? I haven't looked at it closely, maybe I can come up tomorrow, supposed to rain all day
#815 | ||||
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. Last edited by NoNeck; 05-03-2017 at 09:42 PM. Reason: typo |
#816 |
New vent windows arrived today... I like them a LOT!
POP
#817 |
68 C 10
![]() Join Date: Aug 2010
Those look nice let us know how they fit. Where did you get them from if I missed it sorry.
Kevin "Life is Hard But its Harder when your Stupid" John Wayne 68 C10 70 C20 http://67-72chevytrucks.com/vboard/s....php?t=602326# |
#818 |
![]() Join Date: Dec 2012
I just went through this with my Vintage Air install although mine wasn't as far off as your looks in the pictures. I slotted the holes a little to make the bracket line up better and not interfere with the lines and its all good now. I love your build by the way!
__________________ Mike 70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804 Instagram- protouring66 |
#819 | ||
POP
#820 |
We got the tail light trim installed as well as the other CST emblem on the passenger door and eyebrow trim on front fenders. The Vintage Air has been plumbed and is ready to be mounted. We were able to install the liquid lines through the firewall without removing the grille. By removing the parking light assembly and carefully feeding the lines through the front of the grille they finally dropped in place.
The new AMD tinted back window has been wrapped with a Precision gasket and original stainless trim. A 1/4" rope was inserted and then it was taped with wide painter's tape to hold everything together. Chad and I are going to install it tomorrow and work on finishing up the wood bed. POP
#821 |
We got the Vintage Air unit installed under the dash and worked on the electrical connections. We will need a factory center "Y" vent to mount the center outlet. We will be needing a factory A/C Heat/Air Control panel too to finish up. The evaporator and filter is in as well as a relocated transmission cooler.
The windshield and back window are installed and we are beginning installation of new green side window glass and vent windows. The tailgate hardware is on and the bucket seats are bolted in for the final time. Chad and I plan a full work day on Saturday to get more stuff bolted up. Stay tuned... POP
#822 |
![]() Join Date: Jan 2013
Pops did you take any pictures of the Camaro gas tank from under the truck? by the way that is one beautiful truck and quality wrenchen.
#823 | |
POP
#824 |
Thanks, one more question, you stated that you was going to use the Camaro straps. How did they work
#825 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Truck is looking SO nice!
Curious why you didn't use 67-68 tail light trim?
