Old 07-27-2012, 02:36 PM   #801
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Re: 1966 SBBW pro street
I have lost sleep over these stupid ac vents.....So be gentle I am sensitive...They don't come apart...they are billeted but no one so far can get thm apart or i would do them in green too. But for now they stay like that till i decide what to do . I don't want them to look like a 70's disco van.....
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 07-27-2012, 02:40 PM   #802
wutnxt
Just messing with ya now.....
There is the 58 sitting tall the LS2 almost finished......I had to take a picture of both at the same time for a change.....I have enough work for awhile
Old 07-28-2012, 09:42 AM   #803
65Pickup
65Pickup's Avatar
Great builds, they look awesome.
65Pickup is offline   Reply With Quote
Old 07-28-2012, 09:01 PM   #804
wutnxt
Thanks ....it's alot of work but i hope it's all worth it in the end....
Old 08-26-2012, 09:52 PM   #805
wutnxt
Okay so .....
The 58 was supposed to be theraphy and a easy build.....not so much . But I am in the home stretch now. The beast is mostly wired now and i rebuilt each light housing fo every light. I glass beaded then primed then painted the housings and replaced each and every socket. I wired it with one of the EZ wire kits and I have used a bunch of differnt kits but I really like the product. I should have taken more pictures with all of that but i didn't, but each wire soldered and heat shrinked and the harness is all wrapped. But I also managed to get the oak kit in.....It didn't turn out as nice as i wish it would have but It's going in for now until I get a chance to fx it. When I had the body shop widen the rear tubs i showed them where to place the bed strip grooves but they were out 1/2" . Not easy to try and hide and lots of work to fix it.
Old 08-26-2012, 09:53 PM   #806
hotrod1
56 - autocross
hotrod1's Avatar
Have u used American Autowire? If so, how does it compare?
hotrod1 is offline   Reply With Quote
Old 08-26-2012, 09:58 PM   #807
wutnxt
Now the 65 street truck....( not the pro )
I have had a great run on this thing lately.........and i really like how it's starting to look. I now have the vision or look that I want....anyhow....I painted the booster and master cylinder to match the firewall and got al o that mounted on.
Old 08-26-2012, 10:02 PM   #808
wutnxt
I got the A/C pump mounted....The alternator mounted....
Old 08-26-2012, 10:09 PM   #809
wutnxt
So it's going together .....
Old 08-26-2012, 10:12 PM   #810
wutnxt
So not only did i get all the inners and rad support mocked up , I got them painted.....
Old 08-26-2012, 10:16 PM   #811
wutnxt
Ya i am sure I used it on my buddies 66.....I think that was the kit that you had to mount each wire back into the fuse block....So you mount the block then pull the wire back to the block then tighten a screw down for each wire.....with the EZ kits the block comes prewired so it's mount the block and pull the wire towards where it goes too.
Old 08-26-2012, 10:20 PM   #812
wutnxt
Okay so ......lets see who notices the changes i made ......
Old 08-26-2012, 10:25 PM   #813
wutnxt
But I also think that the auto wire did come with the head light switch...and EZ doesn't...I don't like the goody switch stuff where you have to cut down the headlight arm for the switch. I like to buy the good headlight switches anyhow...I am using the EZ kits for all my builds now, I like the kits and I want to use one kit for all my builds it really saves time and you really get good at putting them in.
Old 08-26-2012, 10:45 PM   #814
wutnxt
I need to get rid of those blue wires and tan cap.... I need to run the smaller cap set up i think...Do those run a diffrent distributor or the same distrbutor just a differnt cap set up.....guessing they run a differnt drive...ugh i don't wanna scratch my paint changing it out....
Old 08-26-2012, 10:48 PM   #815
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
so what is going on with the title truck on this thread? On hold for the other projects?
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 08-26-2012, 11:02 PM   #816
wutnxt
Will be back onto the pro truck soon as i finish one of these builds....The pro truck was killing me...But because I am a fat tire kinda guy the 58 is running 14" wides on the rear.....and well the 65 street version is going to get the tubs widdened as big a i can go rubber wise as well.....it's not done yet but right now thats the plan....and i see a NOS set up as well in it's future. But now that I am thinking Pro truck I should call and check on my engine. The body shop is back on the pro truck as soon as they finish the street 65 if that make sense.
Old 08-26-2012, 11:25 PM   #817
wutnxt
In my spare time i flattened out another acre to make trailer turns easier and park more trucks. I hope to move enough stuff to get my new bay added on before the weather changes.......crosses my fingers
Old 09-03-2012, 12:30 AM   #818
65Pickup
65Pickup's Avatar
Great up dates, looks very hectic. Hope your enjoying the ride. Will you have something to drive to Dino's Party?? Stuff is turning out awesome.
Old 09-03-2012, 09:10 AM   #819
wutnxt
I hope to have the 58 test fired at some point this week.....there are a few parts I am waiting to finish off...My air conditioning,my stereo , carpet and the rest of the wiring. I hope to take the 58......just want to make sure it's finished and trouble free.Thats a long way to send a untried truck.....but Dino could fix it for me....lol
Old 09-03-2012, 12:11 PM   #820
Dinos63
chevy only
Dinos63's Avatar
send it i will!!!
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 09-03-2012, 12:12 PM   #821
Dinos63
chevy only
Dinos63's Avatar
dang i forgot to ad such nice work kat!!
Old 09-03-2012, 01:54 PM   #822
65Pickup
65Pickup's Avatar
Good luck, that trip will be just reward for working so hard. Totally understand the nerves though. I'm battling just going to Mission for a race, in the next couple weeks. Don't need the aggravation should something break. Take the dually and trailer, extra friend driving it...should something go awry load it up and continue. Extra gas money but well worth the awesome road trip, to reward all your efforts. Projects are really shaping up, I look forward to next years progress.
Old 09-03-2012, 01:57 PM   #823
wutnxt
I learned everything i know from watching you.....lmao...yo got some skills over there dude....thanks by the way
Old 09-03-2012, 02:01 PM   #824
wutnxt
I am thinking of sending it down ahead of me actually......either on a car carrier....or have a friend drive it down. That gives me way more time off to hang out where it's warm.
Old 09-04-2012, 03:14 PM   #825
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
This street truck is looking killer man! You better get that addition done before the weather change! It sounds like you northern guys could get the raw end of things this winter!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
