Old 07-19-2015, 12:08 AM   #801
Captainfab
60-66 Nut
Re: 60-66 Chevy And GMC 4X4's Gone Wild
There are at least 2 different radius arm frame brackets. One is a bit lower than the other. I would use the lowest one, or maybe fabricate your own. There are 'C' bushings available with different degrees of rotation in them.
Originally Posted by jaredyocum View Post
I am curious about wether I need to drop the trailing arm mounts lower? I think it will wind up with 4" of lift by welding the coil pockets on lower than they were on the ford but I doubt ford owners lower the brackets with a 4" kit maybe they replace the bushing where it clamps on the axle? I know you want a 10degrees of kingpin rollback to drive great .
Old 07-19-2015, 08:25 PM   #802
RANDY COX
RANDY COX's Avatar
I know that's been done I remember a few yrs back I think it was a 4 wheeler magazine that there was a 67-72 chevy 2WD that was converted to 4x4 using the FORD setup up front and used the 2WD rear and moved the rear trailing arms to sit I think on top of the rear end... the truck looked really good....
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 07-19-2015, 08:53 PM   #803
jaredyocum
jaredyocum's Avatar
Yea , there's a guy close to home that did it with a 68 swb and flipped the arm on top of the housing and hung a leaf spring 44 Chevy version and that's what gave me the idea . I don't think ill flip it though just bock the spring 4 in . I did a 90 gmc once ( it was already 4x4) with ford coils and a 9 in because it was cheaper than fixing the split open ifs front and it drove great ! But this will be my first 4 corner coil on road version . I'm not sure to plan to make a sway bar or just try it with out.
jaredyocum is offline   Reply With Quote
Old 08-09-2015, 02:27 PM   #804
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
66 C20 Service Truck:
Old 08-10-2015, 09:14 PM   #805
mud.man.rj
mud.man.rj's Avatar
Originally Posted by LostMy65 View Post
Very cool, might get lost if it's to close to the bush, seems like quality paint work w more than a few hours spent on it too.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 08-10-2015, 09:34 PM   #806
spacedebris
my guess would be a wrap rather than a paint job.
1960 c30 Apache Panel w/ '95 cummins bt6 turbo diesel (work in progress) NOTE: due to photobucket trying to extort money my photos are temporarily unavailable. currently looking for alternative to fix issue.
http://67-72chevytrucks.com/vboard/s...d.php?t=523009
spacedebris is offline   Reply With Quote
Old 08-10-2015, 11:06 PM   #807
mud.man.rj
mud.man.rj's Avatar
Good thinking on the wrap, how easy it is to forget new things..
5.0 4spd std.
7" lift w 35's.
Old 08-14-2015, 12:42 PM   #808
Dallas68rat
My 64 shop truck on 2002 z71 Tahoe chassis
Dallas68rat is offline   Reply With Quote
Old 08-14-2015, 03:23 PM   #809
mud.man.rj
mud.man.rj's Avatar
Nice 64 with new underpinnings, can't even tell from far.
5.0 4spd std.
7" lift w 35's.
Old 11-07-2015, 11:24 PM   #810
padresag
spotted in the parking lot outside Harbor Freight in Austin (north). Looks like it was maybe on an 88-98 frame ( spotted the IFS as he drove away). anybody know anything about it. found this on the f/b thread.
ron
hard to find this thread sometimes. it gets quite aways back.
padresag is offline   Reply With Quote
Old 12-02-2015, 05:28 PM   #811
jteck10
jteck10's Avatar
Originally Posted by ky-donzi View Post
My truck
nice truck! i have a flatbed myself, howd you lift her up that high?
1962 GMC 2500 3/4 ton longbed stepside (currently w/flatbed), 4 on the floor, 305-V6-5.0L
jteck10 is offline   Reply With Quote
Old 02-21-2016, 01:09 PM   #812
66Gilbert
1966 Crew Cab & 4X4 Fanatic
66Gilbert's Avatar
A GMC 4X4 2 Door Crew Cab Long Bed Gone Wild.
66Gilbert is offline   Reply With Quote
Old 02-23-2016, 02:53 AM   #813
Slow Build
Slow Build's Avatar
Well, you did ask for wild.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 02-23-2016, 10:05 PM   #814
spacedebris
well, gotta say its...............................................unique
Old 02-23-2016, 10:35 PM   #815
piratexpress1369a
piratexpress1369a's Avatar
66gilbert did the back doors open on that. ..I don't see any door handles on the back
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 02-23-2016, 11:18 PM   #816
sampsmit000
sampsmit000's Avatar
subscribed
1964 Chevy Factory K10 Short Bed
Mitchell Sampson
sampsmit000 is offline   Reply With Quote
Old 02-23-2016, 11:28 PM   #817
66Gilbert
66Gilbert's Avatar
Slow Build,
I think there's a difference between Wild and Barbaric.
No, it is a 2 door Crew Cab. Wish I some more photos and info on this one.
Old 02-23-2016, 11:44 PM   #818
66Gilbert
66Gilbert's Avatar
A 1966 Chevy 4x4 Short Bed Gone Bananas Wild.
Old 02-24-2016, 09:18 AM   #819
jaredyocum
jaredyocum's Avatar
Hey have any of you guys had trouble with stock lug studs being too short for some of these new aluminum rims , I'm looking for some longer 7/16 565 shoulder like 4x4 have on the front but not having much luck , soon be ready to drive though so I'm searching.
Old 02-24-2016, 09:42 AM   #820
patrickk1
Check out the Dorman Catalog. They have a ton of different size studs.
- Patrick
1964 GMC pickup lwb ~ My newest build!
1937 Ford Coupe ~ Custom frame, LS1, quickchange
1950 Chevrolet 3100 ~ Bagged (Sold)
1931 Chrysler Roadster ~'32 Ford Frame, Channeled 8" (Originally a 60's show car)
1967 Chevelle ~ 454 Triple Black (Sold)
1964 Chevrolet Impala SS (Sold)
patrickk1 is offline   Reply With Quote
Old 02-24-2016, 11:39 AM   #821
schpeen
schpeen's Avatar
Cool Re: 60-66 Chevy And GMC 4X4's Gone Wild
Originally Posted by 66Gilbert View Post
A Nice 1966 Chevrolet 4X4 Step Side Gone Wild.
Gorgeous !!
1991 K5 Blazer 4x4 "9 ball"
2019 Chevy Silverado Trail Boss 4x4
2018 Chevy Colorado 2 door ZR2 4x4
1988 23' Mako Marine
2005 Harley Davidson Road King
schpeen is offline   Reply With Quote
Old 02-24-2016, 09:45 PM   #822
RANDY COX
RANDY COX's Avatar
Man that Yellow one that's a whole lot of yeller...I really dig the silver step side and I like the custom touch of those cross flags on the fender...
1964 BBC 402 4x4
Old 04-24-2016, 01:45 PM   #823
66Gilbert
66Gilbert's Avatar
Wish I had more pictures of both of these two. A 64-66 GMC Short Bed 4X4 and A 1966 Chevrolet Long Bed 4X4. Does anyone know how to tell the difference between the three different years on the GMC's ? By emblems, grill, hood, original paint color or scheme or something else?
Old 04-24-2016, 08:55 PM   #824
GMCBURB
Maybe too obvious but a couple of differences I'm aware of are with the grill letters and hubcaps. The 64-65 grill letters (G and C) were oval shaped while in 66, the G and the C were more squared off... plus the 66 had a groove running though the letters which was painted red. The hubcaps for a 66 had a raised ridge around the center and also at the edge of the three pointed star shape (or whatever you call it). The 64-65 hubcaps were flat here.
GMCBURB is offline   Reply With Quote
Old 04-25-2016, 08:44 AM   #825
duallyjams
duallyjams's Avatar
to add to this, on 64 GMC the head light ring used two screws and a spring in 65 the head light ring used three screws to hold the head light and the spring was moved to the head light bucket, 66 used dull wiper arms and the top of the dash was darker, 66 head windshield washer and back up lights both of these were option before 66.
No big changes just a bunch of little things.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
