Old 05-15-2015, 02:33 PM   #826
67chevemall
67chevemall's Avatar
Re: It’s Just A Pickup
WOW, what a truck! Great Job! Didnt get a thing done at work today! What a great read that was!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 05-15-2015, 02:47 PM   #827
BrianG
BrianG's Avatar
This would sure make a nice book. Your attention to detail is amazing, and the information contained in this thread alone is amazing. Thanks again for taking the time to put this together and continuing to update it from time to time.
BrianG is offline   Reply With Quote
Old 05-24-2015, 02:43 PM   #828
LDO
LDO's Avatar
Here is my clumsy attempt at duplicating your plug wire separators. Hanging on a hook after some DEI Silver high temp paint, waiting for satin clear.
Thanks for the inspiration.
LDO is offline   Reply With Quote
Old 05-24-2015, 04:17 PM   #829
Bruce88
Bruce88's Avatar
You are more than welcome LDO
Sometimes it’s the small things that I make to finish off an installation like brackets and such that I know it makes everything work. Each installation may require slightly different parts and this is where customizing it to your needs falls. Hope your wiring brackets that you’re making are just the finishing touch that works for you.
You have some nice build threads, keep up the good work
Enjoy your build
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544
Bruce88 is offline   Reply With Quote
Old 05-24-2015, 06:16 PM   #830
LDO
LDO's Avatar
Thank you sir. Coming from you, that means alot to me....
Old 06-20-2015, 05:56 PM   #831
Bruce88
Bruce88's Avatar
Storage Area
After moving the gas tank from behind the seat
What do you do with the open area now?
The area is somewhat small, not flat, and almost anything that you put back there slides side to side or finds its way under the seat or in the sloped corner areas. I’ve been looking at this area for some time and wondering what I could do?
I didn’t want to drill any additional holes in the cab, just use existing fastener holes. I did make a small bracket to mount the small air compressor for my air shocks in the passenger side sloped area that I did some time ago on the build, I’m not going to change the compressor bracket and is the reason the bracket/frame I designed does not go all the way over to the passenger side corner. I’m primarily going to use the boxes I made for tie down straps, trailer hitch ball, and scissor jack storage.
Material I used to make the bracket/frame and boxes
2 inch X 1/8 inch Aluminum bar for forward bracket/frame legs and brace between forward and aft angles
1 inch X 1 inch X 1/8 thick Aluminum angle for forward edge of bracket/frame and corners of the boxes
1.5 inch X 1.5 inch X 1/8 thick Aluminum angle for aft edge of bracket/frame and aft legs
.025 thick Aluminum sheet for the boxes
3/16 blind rivets 1/8 & ¼ inch grip length
¼ - 20 X 1 inch bolts and rivnuts for box mounting bolts to bracket/frame
5/16 – 18 X 1 inch bolts for mounting bolts to floor (old gas tank lower fastener holes)
¼ inch thick rubber for cushion on aft legs
I had some tool box liner mat that I put in the bottom of the boxes to minimize any rattling and sliding in the boxes
I’m not going to give any exact measurements concerning the bracket/frame or boxes. Because each truck could be a little different plus different seats that could be used. It’s kind of build to fit your needs bracket/frame and boxes. So if you like the concept and want to make your own you will need to break out your tape measure and build to your truck (smile).
Here are some pictures of the bracket/frame and boxes from different angles out of the truck.
Name:  storage area 1.jpg
Best pictures I could get with the bracket/frame installed, seat moved forward for access and viewing.
Name:  storage area 2.jpg
Name:  storage area 3.jpg
Best pictures I could get with the boxes installed on the bracket/frame, seat moved all the way aft to its normal driving location.
Name:  storage area 4.jpg
Name:  storage area 5.jpg
Enjoy your build
Old 06-21-2015, 11:06 PM   #832
88Stanger
88Stanger's Avatar
Thank you for this write up!!!
88Stanger is offline   Reply With Quote
Old 10-29-2015, 07:45 AM   #833
y5mgisi
Second Chance Program
y5mgisi's Avatar
Hey Bruce, a few years ago, in post 712, you posted a picture or two of factory timing numbers out of a book. Do you happen to have one for a 69 396 big block out of a chevelle? Or any advice on where I could find such info? Thanks!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 10-29-2015, 01:50 PM   #834
Bruce88
Bruce88's Avatar
Hi
I looked thru my books and found some 396 big block distributor numbers (posted below).
As with older engines that people have it can be hard to tell whether the distributor you have on the engine is the original stock one or has it been changed. If you’re trying to set the distributor to a stock distributor curve the numbers below should get you in the ball park, but you’re still going to need to check it. Recommend that you check your distributor curve exactly the same way I described it in post #712 & 716 http://67-72chevytrucks.com/vboard/s...318544&page=29 but with the numbers you’re trying to achieve.
The performance timing curve that I described in the post will work with the 396 big block and an upgrade to a HEI distributor is possible if desired just make sure you remove the resistor block or resistor wire to power your HEI distributor.
Name:  396 Timing.gif
Hope this helps you out
Enjoy your build
Old 10-29-2015, 02:09 PM   #835
y5mgisi
y5mgisi's Avatar
I plan on following your write up! Just wanted to see where it was at with respect to original.
Old 02-20-2016, 09:42 PM   #836
crakarjax
crakarjax's Avatar
Thanks for the detailed build Bruce, I always enjoy seeing how people accomplish things; it gets me motivated and thinking about my own build! Nice meeting you the other day and thanks for the practice doors
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 03-01-2017, 01:43 PM   #837
72peace
72peace's Avatar
Phenomenal build, don't want to lose this one. ttt
Cheers,
72peace is offline   Reply With Quote
Old 03-01-2017, 03:58 PM   #838
El Dorado Jim
great job on your truck!!!!
El Dorado Jim is offline   Reply With Quote
Old 10-31-2019, 04:52 PM   #839
KMAT
Look great. Why does the rear brake lines have to run down pass. Side of frame rail? Wouldnt driver side be shorter distance?
KMAT is offline   Reply With Quote
Old 10-31-2019, 05:14 PM   #840
dracko
dracko's Avatar
You could customize any route but at the rear PS there’s a junction block fitting in the frame and the stock lines on the diff are set up to take line from the PS. So it’s easier.
dracko is offline   Reply With Quote
Old 05-23-2022, 04:49 PM   #841
LT7A
Hey Bruce, it does not look like you have been on the site for quite some time. I hope things are well and that you are enjoying your truck immensely. I'm so glad that I discovered this thread and I read it avidly over a period of days.
I think some folks get caught up in trying to replicate what you did. I understand that because it's outstanding. For me, the approach that you took and your efforts to research and simplify things are great teachers.
We're nearly neighbors, and I will be watching for your truck. I hope to see it and meet you sometime. Thank you for all the effort that you put into documenting your build process.
PS, I'd also like to hear more about the Volvo with the 327!
Take care, and may your road be as straight or as twisty as you wish, and may your small block Chevy get you down that road at whatever speed makes you happy.
Old 09-22-2022, 01:24 AM   #842
BLP1969
How do I subscribe?
BLP1969 is offline   Reply With Quote
Old 09-22-2022, 09:51 AM   #843
SCOTI
SCOTI's Avatar
Originally Posted by BLP1969 View Post
How do I subscribe?
Once you post in a 'thread' it typically will populate your page when you first log-in to the site (if there were any additional posts)
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
