09-14-2014, 07:21 PM | #826 |
Re: GM Semis
Like the Conventional Cab one. Don't remember ever seeing one like it, but it's pretty cool.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan |
09-14-2014, 11:04 PM | #827 |
Re: GM Semis
Crown Steel used to make the cabs for Mack and White Motor Co. 50 miles down the road.
Allison released automatic transmissions for trucks in 1957, but prior to that had planetary power shift transmissions that were used off highway. The early MT 40,41,42 had front and rear pumps so could be push started.They normally started in 3rd gear...................unless the driver selected the 1-2 position. The HT 70 was similar, but bigger and could be behind 8V71, 350 Cummins, but Allison always had an input torque limit . GMC used the Hydramatic car 4 speed in medium trucks in 54, possibly '53 . |
09-18-2014, 08:00 AM | #828 |
Re: GM Semis
I think the Hydramatic first appeared in these M135/M211 GMCs built for the military starting in 1951. When I was in the army (1966/67) most were used for driver training or Nat'l Guard. XM211, 1952 (GMC) by PAcarhauler, on Flickr
09-18-2014, 09:33 AM | #829 |
At the body shop.
Re: GM Semis
Facebook
" That didnt make it any newer " " Dont antique the equipment " |
09-18-2014, 09:50 AM | #830 |
Re: GM Semis
That's ^ nice!!!
09-19-2014, 11:47 AM | #831 |
At the body shop.
Re: GM Semis
Shared with Permission
09-19-2014, 03:31 PM | #832 |
At the body shop.
Re: GM Semis
[QUOTE=KQQL IT;6840708]
Maybe a repost Still alive and part timing.[ /QUOTE]
09-19-2014, 04:37 PM | #833 |
Re: GM Semis
Sure is load of gold there, including the truck hauling it.
09-19-2014, 09:12 PM | #834 |
Re: GM Semis
Good stuff indeed!, I like the red Autocar, Wondering what's powering the early Autocar with the later chassis/rears, Cool trucks.
09-23-2014, 09:54 PM | #835 |
At the body shop.
Re: GM Semis
09-23-2014, 11:44 PM | #836 |
Re: GM Semis
Great picture.
The truck looks fairly new. Bill
09-24-2014, 12:13 AM | #837 |
At the body shop.
Re: GM Semis
Do the C40 and up follow the pickup cabs. Look like that is a 64-66 cab?
Or where behind a bit
09-24-2014, 12:17 AM | #838 |
Re: GM Semis
Right, that is basically the same as a Pick-Up Cab. Many of the parts will interchange.
09-24-2014, 01:12 AM | #839 |
At the body shop.
Re: GM Semis
I thought that was the case. Just was curious if the years followed the pickups.
60-63 64-66 and so on.
09-24-2014, 08:38 AM | #840 |
Re: GM Semis
Right, they followed the same style Cab in year models. Same with '67 to '72, a C-70 Medium has basically the same Cab as a C-10.
09-30-2014, 01:22 PM | #841 |
At the body shop.
Re: GM Semis
Mike Kelett via facebook
10-04-2014, 06:59 AM | #842 |
Next!
Re: GM Semis
GMC 860s, 1959s?
Hope this isn't a repost
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
10-10-2014, 12:42 PM | #843 |
Re: GM Semis
I had the hots for 860s so bad about 25 years ago, then my lust switched to the early '50s fat cabs. So I bought two 503 gas powered and one with 4-71 GM diesel. Now I have none .
10-10-2014, 02:42 PM | #844 |
Re: GM Semis
You still have an MH or two, I believe ??
10-11-2014, 02:38 AM | #845 |
Re: GM Semis
The DR-860 was actually built through 1962. Reason I was told was because the 860 had the 6-71 inline Detroit, and the DB-7000 which was supposed to replace the 860 had the 6V-71 V-6. The 6V-71 had cooling problems early on and a lot of fleets still wanted the 6-71, so the 860 stayed around until the DBI-7000 came out which had the 6-71. Junkmandan, does that sound right to you?
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
10-11-2014, 06:49 AM | #846 |
Next!
Re: GM Semis
4x4 conversion towing a Greyhound Bus
10-11-2014, 07:53 AM | #847 |
Re: GM Semis
allmost looks like the used the undercariage of a militairy truck for that one
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
10-12-2014, 01:36 PM | #848 | |
Re: GM Semis
10-12-2014, 01:52 PM | #849 |
At the body shop.
Re: GM Semis
702 v12
GMC: http://youtu.be/KnQElM3Qr6Y
10-12-2014, 02:26 PM | #850 |
Re: GM Semis
What-----------When you see the big hubs on front wheels, it's usually a product of Marmon-Harrington from Colorado or Howe-Coleman out of upstate New York.
