Old 04-02-2017, 05:59 PM   #826
mooseknuckles
mooseknuckles's Avatar
Re: Owen's C10
finished the bed side cut outs and exhaust...
mooseknuckles is offline   Reply With Quote
Old 04-02-2017, 06:01 PM   #827
mooseknuckles
Re: Owen's C10
Old 04-02-2017, 07:04 PM   #828
Lorne
Lorne's Avatar
Re: Owen's C10
John, the exhaust cutout looks amazing and it's that much closer to being done.
Lorne
Si vis pacem, para bellum
48 Ford F100 Panel
67 Chevy C10
71 Camaro RS
73 Camaro RS (in progress)
Lorne is offline   Reply With Quote
Old 04-03-2017, 01:18 PM   #829
knomadd
knomadd's Avatar
Re: Owen's C10
Looks great! Just for my education, do you have a section of flex pipe in the exhaust somewhere? If not, what's to keep the pipe from sliding out of or putting a bind on that beautiful flange on the bedside?
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 04-03-2017, 05:45 PM   #830
mooseknuckles
Re: Owen's C10
thanks!...and yes it is.
no flex pipe...its very solidly suspended at the hanger by the muffler. engine mounts are almost solid and a poly trans mount, not a lot of movement anywhere really...Do you think I need one..? I may put another hanger on the pipe out by the bedside if it rattles...
Old 04-04-2017, 11:37 AM   #831
knomadd
knomadd's Avatar
Re: Owen's C10
I don't know if you need one. I was just curious if you were concerned about flex from engine torque. If you're not concerned, I'm not concerned.
-Duane
Old 04-04-2017, 02:22 PM   #832
McDeezl
Re: Owen's C10
I welded in SS braided flex couplings into mine as insurance. When I put up the Flowmaster setup it just seemed way to rigid to me even with the hangers so I could see the weakest link becoming the headers and them cracking to pieces. Didn't want to take the chance so the flex couplings were cheap and easy and not visible. Mind you I have stock engine mounts and quite a bit of torque flex movement with throttle accelerations. There are pics in my build thread. Maybe run the engine and try it out to see how much movement you get? Becomes one of those better sooner than too late things I guess.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=626178
McDeezl is offline   Reply With Quote
Old 04-04-2017, 07:55 PM   #833
mooseknuckles
Re: Owen's C10
IDK either...I've never had trouble before, but anything's possible I guess...
The motor doesn't move at all, and the exhaust can only move a 1/4" until it hits something, like the trans cross member or trailing arm cross member so I have it mounted pretty snug to keep from rattlin'...
Old 04-07-2017, 06:19 PM   #834
Metaldoc
Metaldoc's Avatar
Re: Owen's C10
I like that look as well, I still have plans to run mine like that but cut on a 45 deg. with these as pipe covers. These are 316 stainless pipe fitters belt buckles that I made and had extras.
Metaldoc is offline   Reply With Quote
Old 04-09-2017, 07:33 PM   #835
mooseknuckles
Re: Owen's C10
still pluggin" away....I made some stands to support the front of the bed and tie it to the frame, and joined them together with some square tube, and on the square tube I welded some tabs and mounted the air tank to that. I mounted the compressors on the frame and wired everything up from the relay to the battery..I also ran all the wiring for the taillights, gas guage, fuel pump, accuair, trans cooler as well, all pulled through the frame.. just waiting on my fuel tank to show up then I can mount the pump and fuel lines.
Old 04-09-2017, 07:35 PM   #836
mooseknuckles
Re: Owen's C10
Old 04-09-2017, 07:45 PM   #837
TexasLS1
TexasLS1's Avatar
Re: Owen's C10
That paint and those wheels, mmm mmm mmm. Looking nice
TexasLS1 is offline   Reply With Quote
Old 04-09-2017, 09:20 PM   #838
69short
69short's Avatar
Re: Owen's C10
Looks great! I love seeing the updates on this badboy
69short is offline   Reply With Quote
Old 04-18-2017, 08:30 PM   #839
mooseknuckles
Re: Owen's C10
thanks!
thank you!
Old 04-23-2017, 07:44 PM   #840
mooseknuckles
Re: Owen's C10
Picked up some parts Saturday...got the front and rear glass, seals, and a few other interior items. here's some pics with the glass in..
Old 04-24-2017, 09:35 AM   #841
knomadd
knomadd's Avatar
Re: Owen's C10
Looking good! I really like the deep lip on the back wheel.
-Duane
Old 04-24-2017, 05:29 PM   #842
mooseknuckles
Re: Owen's C10
thanks Duane!
Old 04-30-2017, 06:28 PM   #843
mooseknuckles
Re: Owen's C10
Today I threw a fender back on to remind me of what it looks like....lol. currently working on the core support getting it ready for paint, hopefully get that painted next weekend. I'm expecting my custom Boyd Welding fuel tank this week then I can start running the fuel lines and mount the pump, and filter/reg. Then with any luck it'll be ready to fire up..!
Old 05-07-2017, 07:26 PM   #844
mooseknuckles
Re: Owen's C10
got my Boyd Welding custom fuel tank this week...what a killer piece!
Old 05-07-2017, 07:32 PM   #845
mooseknuckles
Re: Owen's C10
tank test fit and then mounted in..
Old 05-07-2017, 07:38 PM   #846
mooseknuckles
Re: Owen's C10
I also got the alternator and power steering mounted, the brackets are from ICT Billet and look a lot better than the factory set up and are very affordable....
Old 05-07-2017, 07:42 PM   #847
mooseknuckles
Re: Owen's C10
Lokar shifter installed as well....getting close to start up time..
Old 05-07-2017, 09:11 PM   #848
Advanced Design
Advanced Design's Avatar
Re: Owen's C10
Very nice! Truck is looking great. Did the accessory brackets come in black?
Advanced Design is offline   Reply With Quote
Old 05-07-2017, 10:12 PM   #849
mooseknuckles
Re: Owen's C10
no I painted them.
Old 05-07-2017, 11:49 PM   #850
kehstr
kehstr's Avatar
Re: Owen's C10
Where did you get the remote coil mounting brackets?
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
