01-15-2020, 03:48 PM | #826 |
Post Whore
Re: Suburban and panel finds
Trim parts you may need. Theses are not mine!
https://portland.craigslist.org/wsc/...056179375.html I have all ( or most all, I believe ) aluminum lower exterior body trim parts and 4 door panel covers for the interior. There are 16 pieces of trim and the 4 panels as shown in the picture. There are two valve covers as well included.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
01-15-2020, 08:24 PM | #827 | |||
here's the aforementioned burb sold for $40,750.. https://bringatrailer.com/listing/19...olet-suburban/ and thread; http://www.67-72chevytrucks.com/vboa...&highlight=BAT
I started out with nothing - and I still have most of it |
02-12-2020, 04:30 AM | #828 |
Collector of Projects
I'm pretty sure this belongs to a member here ….
https://sacramento.craigslist.org/ct...071708659.html |
02-12-2020, 05:46 AM | #829 |
Not mine...
https://sandiego.craigslist.org/ssd/...064973457.html SUPER COOL 1971 SUBURBAN DONE RIGHT NEW PAINT AND INTERIOR. 350 MOTOR AND 350 TRANS IN EXCELLENT RUNNING CONDITION. RECONSTRUCTED TITLE. CALL OR TEXT NOW FOR DETAILS TO 858-869-7827 THX |
02-12-2020, 05:48 AM | #830 |
not mine:
https://orangecounty.craigslist.org/...072873572.html This is a three door 1969 Chevy suburban running driving! Has a 350 and 3 speed trans. $3,900 Price not negotiable! Thx 🙏 |
02-12-2020, 05:50 AM | #831 |
not mine:
https://sacramento.craigslist.org/ct...059767186.html 1968 Chevrolet Suburban Very nice rust free California truck continuously registered since 1968 with original black plates. Currently registered and insured in CA for road use. Clear title. C10 Factory 4WD 327ci / SM465 4 speed w/ granny Low / NP205 / 3.73 Positrac Rear/ Warn 35 spline front hubs PS, PB, 6” spring lift, front disc brake conversion, D44 Front Axle w/ GM rear. 2” tow hitch. Original style steel 16.5” wheels with caps and brand new 35” Cooper Discoverer XPP tires. Also comes with a nice set of shiny aluminum wheels the same size – no tires mounted 83k original miles w/ original 327 engine never removed, cast iron block, forged steel crank, engine compartment is original blue color. Edelbrock 600 Carb, K&N filter. Fully adjustable performance HEI electronic ignition by Davis Unified Igitions. Hedman headers, nice dual exhaust exits in front of rear wheels. Runs great – takes a few minutes to warm up. The short rod v8 and posi rear is also really nice offroad. 3rd Gear Low will conquer just about anything comfortably at idle. Rarely even need the 4WD New paint inside and out in 2014. Flat White single stage enamel. Super EZ to repair. Bedliner paint along bottom. Complete new interior…headliner, seats and foam, seatbelts, carpet, mats, dashboard, visors, nice steering wheel, all new rubber seals in all windows and doors including windshield, privacy tint on all rear windows. No Entertainment system, or nice HVAC. These 2 last items are going to cost $$ Was to be an offroad adventure vehicle and now it is too nice to use as planned. Hagerty Classic Car values says its worth $42K in “Like New” condition $36K if “Excellent” I have seen professional builds of this truck go as high as $115K at auction. Make Offer. Prefer to avoid the cost to install HVAC and electronics and auction fees. Email through Craigslist to make arrangements to view. |
02-12-2020, 05:55 AM | #832 |
not mine:
https://spokane.craigslist.org/cto/d...072284888.html Up for sale, a very neat 1969 C20 suburban, 3 door, barn doors in the back.. Very solid, just a little cancer in front and back of the rear tires, the front 2/3 of the truck is awesome solid. Has the plywood floor, but there is NO rot at all there. 4000$ in the engine alone. It’s a screamer, just has the cam broke in, and we got real busy farming last year, amongst other duties.. Powered by a fresh engine, a 377 Chevy, (a 350 crank and 400 block), bored .040 over, with forged pistons that are compatible with a turbocharger (had a plan)..1.5 roller rockers, edelbrock aluminum heads, rpm Intake and 750cfm carb. Headers, but exhaust not finished out... Hei ignition, Comp cams 280 magnum, 12,500 rpm silicone filled harmonic balancer, and she is extremely responsive and snappy.. Other features are as follows: Power steering and power disc brakes (former owner swapped in ‘72 pickup discs) Has trailing arms and rear coil springs for great handling compared to leaf springs. Older two-tone custom restoration, newer carpet. Dash is unmolested Brand New KYB monomax shocks (pricey, and tight) and struts, New U-Joints, and carrier bearing installed A/C cab- not connected. Tilt column Electric adjustable seat(not known if factory) Have a set of new front weatherstripping. Note! I did somehow put in the wrong rear main seal off of a 400cu in. But I do have the right part now, to be installed. And will consider doing it for you depending on your offer. She could use some tires, they have some life on them, just a little uneven wear.. Would not be selling this dream boat if we didn’t have to come up with the down pay for a new home. That’s why I’m offering it. Thanks for looking!! God bless, ...and scammers will be ignored. Don’t waste your time.. |
02-12-2020, 05:58 AM | #833 |
not mine:
https://sacramento.craigslist.org/ct...070597444.html 1970 1-2 ton 3 door suburban 402 big block ac original seats roof air no rust ca car |
02-12-2020, 06:20 AM | #834 | |
02-14-2020, 06:17 PM | #835 |
Post Whore
[QUOTE=mcmlxix;8677033]not mine:
https://sacramento.craigslist.org/ct...059767186.html I find this truck scary. The fuel line to nowhere, bypassed heater core, the hose coming from the what should be the PVC on the passenger side, the wire nut on the battery lead, and the bedliner covered rockers. With a 30K asking price! Run Forest RUN!
02-14-2020, 08:19 PM | #836 | |
[quote=HO455;8678504]
02-15-2020, 12:51 PM | #837 | |
I painted my 70 4WD Suburban the exact same color combination back in the early 90's complete with the undercoating below the body line. It was an attempt to hide the crappy body work and filler! Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
02-15-2020, 12:52 PM | #838 |
Looks kinda the same!
Paul
02-16-2020, 03:32 PM | #839 | |
Post Whore
[quote=Beach-Burban;8678547]
Thanks for the chuckle.
02-16-2020, 05:55 PM | #840 |
Post Whore
69 K Burban $15000. Not mine.
https://portland.craigslist.org/wsc/...074386695.html 1969 Suburban 4x4. Runs and drives well. Very straight body in good shape. Recently gone through motor. Brakes converted to hydro boost. 14 bolt rear end. New plastic fuel tank.
02-16-2020, 06:01 PM | #841 |
after the ragging on that 67, I can hardly wait to hear y'alls thoughts on this
02-16-2020, 06:04 PM | #842 |
Post Whore
Another 69,a panel this time. With more holes in the hood than you can shake a stick at. $4800. Not mine.
https://seattle.craigslist.org/sno/f...075572248.html 1969 suburban panel Delivery truck Partially restored needs more work please see second picture of what it’s got done I bought this thinking I would finish it but my circumstances have changed and I’d like to pass it on to someone who will
02-17-2020, 04:59 PM | #843 | |
Paul
02-17-2020, 05:25 PM | #844 |
Carpe manana
72 K10 in New Mexico on eBay: https://www.ebay.com/itm/1972-Chevro...YAAOSwnw5eN00N
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
02-18-2020, 08:00 PM | #845 | |
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
02-18-2020, 10:41 PM | #846 |
Carpe manana
I was wondering the same. Bid to $6300 not meeting reserve.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 02-18-2020 at 10:49 PM. |
02-20-2020, 12:35 PM | #847 |
Post Whore
It's one of those subUrban legends.
3 doors were built in Mexico and 4 doors were built in the US.
02-27-2020, 04:55 PM | #848 |
Post Whore
67 Crummy judging from the yellow in the door jams it could be an old UP truck as the owner suggests or ex Weyerhaeuser, or any number of state agencies. Not mine. Only $5000
https://portland.craigslist.org/mlt/...082448593.html Nice classic original first year body style 1967 3dr suburban 2wd 3/4 ton. Runs good. I think it was an old railroad union pacific truck cause its orginal yellow orange color. Has a later model 350 v8 with 4 barrel carb with hei ignition and automatic trans, manual steering and power brakes. Only has 1 seat in the front and all open in the back with Barn doors. Good original cond. Has collector plates so you never got to renew the tabs. Good driver but tires are kinda old if your gonna drive it on highway or long distance. All the glass is nice and all the lights work as they should. Cool old truck with lots of potential! Clear Washington title if interested call or text 509-46.0-35.92 (Richland Washington)
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 02-28-2020 at 10:34 AM. |
02-28-2020, 10:33 AM | #849 |
Post Whore
71 K model $20000. Looks like a nice rig from the ad which is all the closer I have been to it.
https://salem.craigslist.org/cto/d/a...077648226.html 71 chevy suburban - 3 door - tail gate rear door - 6” lift - added springs - 37” toyos - fuel wheels - new brakes and custom lines - cross over steering - new steering box - custom ladder bars - New front and rear gears ( 4.56 gears) - posi in rear - custom 3” exhaust - flowmasters - headers - 383 stroker with alum heads - dyno sheet (430 hp, 450 torque) -350 Tranny - 205 t-case - original middle and rear seats To many things to list, call for details Title in hand Bought from original owner
02-28-2020, 12:19 PM | #850 | |
