Old 05-08-2017, 08:29 AM   #851
Bennett68C10
Bennett68C10's Avatar
Re: Owen's C10
Looking good, I really like the change you made with the caps for the wheels.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 05-08-2017, 11:10 AM   #852
mooseknuckles
mooseknuckles's Avatar
Re: Owen's C10
Originally Posted by kehstr View Post
Where did you get the remote coil mounting brackets?
Same place as the brackets...ICT Billet. Summit caries them.
mooseknuckles is offline   Reply With Quote
Old 05-08-2017, 11:12 AM   #853
mooseknuckles
Re: Owen's C10
Thanks. These are the only set of caps that I have. I wanted to make them less s10 looking so I painted them.
Old 05-08-2017, 11:43 AM   #854
Scotts 70
Re: Owen's C10
SCOTT FROM TULSA WOULD LIKE MORE INFO ON C/10 CLUB OF OKLAHOMA THANKS E MAIL SCOTT64668789@gmail.com
Scotts 70 is offline   Reply With Quote
Old 05-14-2017, 07:13 PM   #855
mooseknuckles
Re: Owen's C10
more pics...
Old 05-14-2017, 07:34 PM   #856
69short
69short's Avatar
Re: Owen's C10
Sweeet! It's looking good man
69short is offline   Reply With Quote
Old 05-15-2017, 06:59 PM   #857
mooseknuckles
Re: Owen's C10
thanks brother..!
Old 05-16-2017, 08:42 PM   #858
mooseknuckles
Re: Owen's C10
The Boyd Welding/Aeromotive fuel pump and bracket came today....what nice quality piece!
Old 05-22-2017, 06:32 PM   #859
mooseknuckles
Re: Owen's C10
Installed and wired up a master disconnect switch....actually turned it on to see what all works and what doesn't. everything looks good, got to finish wiring the pump, plumb all the lines and hopefully fire it up soon...
Old 05-22-2017, 08:09 PM   #860
Lorne
Lorne's Avatar
Re: Owen's C10
Wow looks awesome!!
Lorne
Si vis pacem, para bellum
48 Ford F100 Panel
67 Chevy C10
71 Camaro RS
73 Camaro RS (in progress)
Lorne is offline   Reply With Quote
Old 05-22-2017, 11:20 PM   #861
69short
69short's Avatar
Re: Owen's C10
It's getting close. You're cruising right along. Make sure to take a video the first time you fire it up
Old 05-25-2017, 06:10 PM   #862
mooseknuckles
Re: Owen's C10
Originally Posted by Lorne View Post
Wow looks awesome!!
thanks!
thanks bro. I'll try to remember that...
Old 05-25-2017, 06:19 PM   #863
NewType72
NewType72's Avatar
Re: Owen's C10
Probably one of my favorite builds right now purely off the wet look that body has at every angle
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 05-28-2017, 06:54 PM   #864
mooseknuckles
Re: Owen's C10
thanks!
Old 05-28-2017, 07:16 PM   #865
mooseknuckles
Re: Owen's C10
Had a busy weekend, lots of wiring! did the fuel pump relay no. 2, E-fan relays, back up light switch, brake switch, front lights, mounted the fuel filter/reg and ran the -6 feed and return lines, and then finally I powered everything up......motor rolls over like it wants to start, but I still don't have a throttle body so I'll order something else this week. I'm not waiting any longer for the back ordered holley piece... having issues with the turn signals, so I'll order a new signal switch as well.. couple of pics all lit up. I'd show the back, but I'm still needing a taillight, and the back up light housings, those things are hard to find new..
Old 06-06-2017, 09:22 PM   #866
mooseknuckles
Re: Owen's C10
got the Nick Williams throttle body today... 92mm compared to the old stocker. I need to get some longer bolts and I can get the throttle bracket on there as well...
Old 06-06-2017, 09:42 PM   #867
mooseknuckles
Re: Owen's C10
check it out... https://youtu.be/nx7JKK38tTs
Old 06-06-2017, 10:16 PM   #868
smbrouss70
smbrouss70's Avatar
Re: Owen's C10
Sounds good!
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 06-11-2017, 12:54 PM   #869
NewType72
NewType72's Avatar
Re: Owen's C10
Just getting closer and closer!
- Dylan
(209)-985-7721
Old 06-11-2017, 06:47 PM   #870
mooseknuckles
Re: Owen's C10
throttle body and cable bracket bolted up...
Old 06-12-2017, 07:48 PM   #871
mooseknuckles
Re: Owen's C10
soakin' up the sun....
Old 06-12-2017, 09:24 PM   #872
mooseknuckles
Re: Owen's C10
another vid. https://www.youtube.com/watch?v=Xxit...ature=youtu.be
Old 06-18-2017, 09:12 PM   #873
mooseknuckles
Re: Owen's C10
some pics with the rad installed. upper and lower silverado rad hoses...still have to fab something to mount to the top of the rad to hold it in place..
Old 06-18-2017, 09:16 PM   #874
mooseknuckles
Re: Owen's C10
drove around the yard a bit...can't wait to give it a shakedown run.!
Old 06-18-2017, 11:47 PM   #875
Metaldoc
Metaldoc's Avatar
Re: Owen's C10
That's a nice lawn roller with them tires.
Metaldoc is offline   Reply With Quote
