Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 01-02-2020, 10:22 PM   #876
Captainfab
60-66 Nut
Re: Power Steering Adapter Plates
I replied to your PM.
Originally Posted by Dieman63 View Post
PM sent
Old 01-11-2020, 09:20 PM   #877
Dieman63
Got my adapter plate for my 63 today. Excellent quality workmanship. Template makes it an easy task to get done. Already had it apart ready to go. Took about 2-3 hours very nice upgrade. I will be contacting you when I'm ready to get the power brake booster bracket.
Dieman63 is offline   Reply With Quote
Old 01-11-2020, 10:45 PM   #878
Captainfab
60-66 Nut
Thank You for the compliment and the purchase.
Old 01-19-2020, 06:27 AM   #879
66_C20
Captain,
I purchased your power steering adapter plate a while back and got it mounted. Very nice quality piece and am very happy with it. I did have a question though that I was hoping you could help with. The power steering box is from an 86 C20 that I’m using on my 66 C20 which has a 76 454 BB in it. I still need to get the power steering pump assembly, lines, and reservoir to complete the project but not sure what year I should be searching for for these items. Any advice there?
66_C20 is offline   Reply With Quote
Old 01-19-2020, 10:58 PM   #880
Captainfab
60-66 Nut
Your '86 steering box will have Metric with an o-ring style fittings. So it will be best if you purchase a 1980 and newer power steering pump. Most likely one for a 454, but that also depends on what water pump you are running. A long pump or the correct short pump. As for the lines that is a tossup. The lines for a '80+ truck with a 454 may or may not work. The only one that is a worry is the pressure hose. Personally I would just have a hydraulic shop make a hose for you with the correct ends. The return line does not have crimped on ends, so that is easy.
Originally Posted by 66_C20 View Post
Captain,
Old 01-23-2020, 04:24 AM   #881
66_C20
As always, thank you for your help and knowledge. From you explanation, it doesn’t sound too bad, I’ll probably just get an ’86 PS pump to match the box itself but as for the water pump, I might go with an electric one in the end. Not sure if that changes things at all. Then for the lines, it sounds like my best bet would be to just spend the time and money to have a hydraulic shop make the hoses for me and call it done.
Old 01-23-2020, 01:19 PM   #882
raylube
raylube's Avatar
P.M. sent
raylube is offline   Reply With Quote
Old 01-23-2020, 10:17 PM   #883
Captainfab
60-66 Nut
Originally Posted by raylube View Post
P.M. sent
Old 01-24-2020, 10:25 AM   #884
raylube
raylube's Avatar
P.m. Sent
Old 02-05-2020, 01:24 PM   #885
raylube
raylube's Avatar
Got the adapter in the mail, it looks well made. Thanks for all your help and all the time spent helping me and others on this website. Is Aotte build the most helpful with install on K trucks?
Old 02-05-2020, 11:03 PM   #886
Captainfab
60-66 Nut
Les's thread is good as well as 72cs20's build thread on his '66 K20 Adventure Rig. He says that he used the 2wd template to mount his steering box.
Old 02-06-2020, 01:34 AM   #887
Matt's k5
BLAZER THIRTY!!
Matt's k5's Avatar
I can vouch for Capt Fab! Worked great on 63 GMC 4x4
49 chevy 5 window 20 year project (sold)😟
57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.)
62 GMC 305 V6 custom L/B
72 HIGHLANDER K5 BLAZER 2nd owner
71 K5 MAMMA'S RIDE!
63 GMC 4X4 305 V6
62 GMC SHORT BED SERVICE BODY V6 (STUMPY)
74 GMC CUSTOM 1500 L/B
Matt's k5 is offline   Reply With Quote
Old 02-06-2020, 10:42 PM   #888
Captainfab
60-66 Nut
Thanks Matt
Old 03-22-2020, 12:36 PM   #889
Gleno97
Hi Captainfab. I am converting my 69C20 from manual to power steering. I bought a 75C20 parts truck to harvest parts from. I think i'll need a box spacer from you and I'm not sure what else. Will the 75 pitman arm work?? Or will i need to do something else? Thanks in advance.
Gleno97 is offline   Reply With Quote
Old 03-22-2020, 09:38 PM   #890
Captainfab
60-66 Nut
You do not need any steering box adapter plate on a '69 C series frame. The integral power steering was first available starting in 1968. All you need to do is bolt your '75 steering box directly to the frame. As far as I know the '75 pitman arm will bolt up to your '69 draglink.
Old 03-26-2020, 01:22 AM   #891
Gleno97
Thanks. I dug into it last night and noticed that the frame is already clearenced to accept the pump......which I installed and it fit perfectly. Now I'm waiting on the Pitman arm to arrive.
Old 03-26-2020, 09:55 PM   #892
Captainfab
60-66 Nut
The pump mounts on your engine. The steering box bolts to the frame.
Old 07-01-2020, 03:18 PM   #893
jazzbum
Hey Captain,
I know covid has probably had some impact on your supply/distribution. Just wondering if there are any brackets currently available. I'm ready to buy if so. Thanks.
jazzbum is offline   Reply With Quote
Old 07-01-2020, 10:07 PM   #894
Captainfab
60-66 Nut
Yes I have been severely impacted......I have never been busier and have not slowed down one bit. I replied to your email.
Originally Posted by jazzbum View Post
Hey Captain,
Old 09-09-2020, 05:02 PM   #895
aotte1
Need a power steering adapter plate for 66’ Suburban 4WD. The one on 64’ K10 works great!
PM sent.
Les
aotte1 is offline   Reply With Quote
Old 09-09-2020, 09:48 PM   #896
Captainfab
60-66 Nut
I replied to your PM Les
Old 10-05-2020, 02:35 PM   #897
dschmit
captainfab - I need another PS bracket for a 66 C10
dschmit is offline   Reply With Quote
Old 10-05-2020, 09:33 PM   #898
Captainfab
60-66 Nut
I will send you a PM with ordering and payment info.
Old 10-17-2020, 05:41 PM   #899
Riverstory
Riverstory's Avatar
Thanks CaptainFab for the power steering brackets and shaft adapters. Awesome components - perfect in so many ways!
You're the best!!
Riverstory is offline   Reply With Quote
Old 10-19-2020, 08:10 PM   #900
Captainfab
60-66 Nut
Thank you for the purchase, I appreciate it.
You're the best!!
