Old 04-23-2014, 08:03 PM   #876
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Hope these help MP33...this is from the 63 accessory install book.
Seatbelt mounting instructions.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-23-2014, 08:08 PM   #877
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Also had a good/bad day with the stepside. Parked it under the carport for the last time with the old 230 after a ride in it. I have to say I'll miss the old 6cyl. Its been extremely reliable and from what I can see and tell and for what I've done to the engine....its never been rebuilt and the trucks gotten 51 years of use out of it.
I'll start removing some stuff after work tomorrow night. Rain coming in Friday and saturday will be engine/trans removal and start to clean up the engine bay & frame and remove all non-essential hardware since its going to a hydraulic clutch.
Old 04-23-2014, 08:10 PM   #878
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Got the fan and spacer on the big block and I think it looks much better with the blue accents on the fan. The blue on the fan really broke up that solid chrome/stainless steel look I had going on. My OCD is happier with it too. The 2" spacer I already had, so I just cleaned it up and used it. I could get away with a 1", but I don't want to buy one until the engine is in and I know how my clearance looks on the radiator. I'll get some matching ARP bolts down the road so it matches the rest of the engine, but for now the grade 5 bolts will work. Still gotta swap the valve covers and unbolt and slide the distributor over a little for some clearance at the vacuum advance/water bypass hose on the pass side. But no biggie and easier to do once its out by the truck. Will do both at the same time so I can visualize the valves and TDC.
Old 04-23-2014, 08:34 PM   #879
Sharps40
Re: 1963 C-10 in NC
Remember....prime the oil and then start up break in is , 2000 rpm steady for 30 minutes....make triple sure everything is ready to support that first critical 1/2 hour run in!
Luck!
Oh yeah, have a full tank, that big block will drink at least 1/4 in 30 minutes!
Sharps40 is offline   Reply With Quote
Old 04-23-2014, 08:37 PM   #880
Sharps40
Re: 1963 C-10 in NC
It'll prolly smoke the paint some...be ready for it so it ain't a surprise.
Old 04-23-2014, 10:04 PM   #881
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
it'l be a week or two off before im ready for fire up. gotta set the engine and trans in after frame clean up and crossmember swap. disk conversion and hydraulic clutch set up, new brake lines, then i can look at fire up. but thanks for the break in procedures....pretty much what comp cams says. and i have all the proper break in fluids.
Old 04-23-2014, 10:05 PM   #882
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
and yeah, i expect some paint casualty.
Old 04-24-2014, 05:11 AM   #883
Sharps40
Re: 1963 C-10 in NC
Man last time we fired one it was big smoke! Bakein the paint in place and an awesome scary sight!
Old 04-24-2014, 08:15 AM   #884
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Haha....right on. Last time I broke in a big block it was in the late 90's in my 69 Chevelle SS. I was 18 or 19 and was so damn excited hearing that big block fire up I could have run a marathon.
I've got a check list of stuff that I'll keep on standby for initial start up. Fire extinguisher included.
Paint can always be touched up, so not real worried about that. Your welcome to come down when the times right if you want to. I can keep you updated on it.
Old 04-24-2014, 08:23 AM   #885
Sharps40
Re: 1963 C-10 in NC
Remember, no tire shreding the first 4000 miles!
Old 04-24-2014, 08:29 AM   #886
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
I hear you there....especially with the cost of the new white walls....
I'll still have the rear end to convert to posi...so tire shredding will have to wait a few weeks. I'll need to take it easy on the ol one legger so I don't shred it.
Old 04-24-2014, 10:09 AM   #887
MP33
MP33's Avatar
Re: 1963 C-10 in NC
Yep that works. Thank you very much.
MP33 is offline   Reply With Quote
Old 04-24-2014, 10:20 AM   #888
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
Make sure to put 4000 miles on it quickly so we can get a vid of some tire shredding! Motor is looking killer! Can't wait to hear it run(I hope!)!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 04-24-2014, 10:37 AM   #889
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
No problem. You know we'll want some pics of the install!!
Old 04-24-2014, 10:37 AM   #890
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Thanks TJ. I'll probably use some old tires for the whole tire shredding episode!!
Old 04-24-2014, 11:58 AM   #891
bj383ss
bj383ss's Avatar
Re: 1963 C-10 in NC
4,000? I was always told by 500 miles the rings were seated and ready to go. I used to drive around all night until I had 500 miles. LOL
Breaking in the cam. My least favorite thing of a new engine build. The neighbors love it though!
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 04-24-2014, 12:12 PM   #892
Sharps40
Re: 1963 C-10 in NC
Yep, 4000 miles. A 500 mile oil and filter change with full service checks and retorques.
The first 3500 mile oil and filter change, full service checks and retorques.
At this point ye'll be confident in the entire system, very familiar with its performance quirks and characteristics and ride quality and with bunghole just absolutly quiverin to suck up an upholstery plug on the first burnout.
Old 04-24-2014, 12:19 PM   #893
Sharps40
Re: 1963 C-10 in NC
Make sure ya got a spatula near by to break the seal twixt ass and seat after the first burn out. Scotchguard the upholstery first.
Old 04-24-2014, 12:33 PM   #894
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Haha....my upholsterer already did the scotch guard treatment for me.
Old 04-25-2014, 12:30 AM   #895
dwcardfan
dwcardfan's Avatar
Re: 1963 C-10 in NC
The big block looks sweet!!!!!
dwcardfan is offline   Reply With Quote
Old 04-25-2014, 08:16 AM   #896
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Thanks a bunch for the kind words!!
Old 04-26-2014, 08:15 PM   #897
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
good news, finally got the engine conversion started. pulled the radiator and all electric systems, got the engine disconnected and removed. got the starter and bellhousing pans pulled for clean up as they'll be reused. motor mounts are pulled and i got a few coats of degreaser down. hood is off and front end will be next. i'll get the trans, driveshaft and bellhousing pulled tomorrow. i also got the exhaust system removed. removed all bolted in clutch components, just the frame mounted portion to grind the rivots off of. i'll also try and get the m/c and upper brake lines out. once front ends out 8 can get the crossmember dropped and the frame prepped. i'll get some pics up later
Old 04-26-2014, 09:01 PM   #898
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Heres a few pics from last night and this morning. Feels good to finally get started on this part of the project. A few years worth of saving and buying parts coming to a head and alot of conversions and upgrades going on. Will b amuch differnt ride.
-Engine conversion 230 to 427
-Trans from standard non synchronized column shift to hd fully synchronized floor shift
-Cluth from mechanical to hydraulic
-Brakes from 4 wheel drum/single master to disk brakes on dual mc w/stainless steel lines
-All new front suspension, springs & shocks + adding sway bar
Old 04-26-2014, 09:04 PM   #899
niterider65
niterider65's Avatar
Cool Re: 1963 C-10 in NC
sure am liking the way that motor is lookin
keep up the good work
niterider65 is offline   Reply With Quote
Old 04-26-2014, 09:06 PM   #900
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Some more progress today. Have done all work solo so far, but I'll get done what I can on nights and weekends and it'll get done when its done. A forum member Eric stopped by today. He's getting transferred to Bragg from Eustis and is a helicopter mechanic. Has was nice enough to help remove the hood while he was there...much needed and thanks a bunch!!
Heres a few of the engine coming out and of it completely out. All bolts have come out great so far. Will get more done tomorrow. Didn't get a pic of the bays 1st degreasing or of the engine mounts and clutch mounts out, but it'll be in pics down the road.
Note*** Harbor freight hoist has worked great for the 427, the 348 and the 230. There was still another 6-7 inches left on the boom, and it was in the rear position. Its a 1 ton foldable and I'm completely satisfied with every project it's done so far. Payed like $105 shipped to the house with the online coupon a few months back.
