05-14-2012, 04:25 PM | #901 |
Vintage 4x4s
Re: Finally starting my Longhorn 4x4 conversion
Ryan, I think you'll like the hydroboost. I have it on my 01 hd and its hard to tell if the trailer brakes are working
Keep up the good work, Jud
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
05-14-2012, 07:40 PM | #902 | |
Motor mounts are a blast to build that clear everything on these trucks, huh?! Don't ya think you might be able to get a custom hardline built to get around it all? |
05-14-2012, 07:42 PM | #903 |
6>8 Plugless........
That's no joke. I'll look for a pic and if I don't have one I'll take one in the morning. I might be able to build a hard line, but it's going to be real tight. We'll see.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-14-2012, 10:40 PM | #904 |
Custom power steering hoses are ridiculously expensive, tried that on the Corvette.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK" ASSEMBLY THREAD |
05-14-2012, 11:20 PM | #905 | |
05-14-2012, 11:34 PM | #906 |
i cant tell for sure in your pic, but there may be room for a metric 0-ring to JIC #6 (AN6) adapter and a block 90* i did that on my jeep. then you can use standard hydralic pressure hose and fittings. you need two 16m and one 14m to convert the hydraboost and the steering pump. then another 16m for the box if it isnt a std. flare type. if i remember correctly. in doing the jeep including the hose and fittings for the Howe assist ram and box i think i may have spent 90$ on hydraulic hose and another 20-30$ on fittings. the adapters are 10ish bones apeice. pretty cheap for super stout and easy to make hoses.
ryan |
05-15-2012, 09:42 AM | #907 | |
05-15-2012, 09:52 AM | #908 | |
05-15-2012, 04:31 PM | #909 | |
05-15-2012, 04:34 PM | #910 |
Here you go.
12v manifold 24v manifold You can either run the turbo down low and the manifold dumps at 4 and 5 or flip it over and the turbo will be up top. You will have to source or build a spacer to get the turbo off the valve covers. Let me know if you need one, I have 2 of each.
05-15-2012, 09:28 PM | #911 |
Thanks again man, I'll be sure to let ya know!
Keep up the work! I'm goin back to mine now, I'm gettin jealous! |
05-22-2012, 06:29 PM | #912 |
No more progress. I did get some fittings and wouldn't you know it, I can't get one in there either. I have a steel line I'm going to try to fit in there with some mods to the engine mount bracket. It's always got to be some thing!
05-22-2012, 08:19 PM | #913 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=218253
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
05-22-2012, 10:28 PM | #914 |
Thanks for that link Tim! I doubt I'll do it to this truck though.
05-22-2012, 10:47 PM | #915 |
Enjoying left field
I've never cared much for the forward tilting hood. Seems like it would just get in the way. I would love to have the whole nose tilt forward. Now that would be handy.
05-22-2012, 11:32 PM | #916 |
Still Learning
New progress Ryan?
05-23-2012, 02:14 PM | #917 |
I was thinking the same thing. You'd always be leaning over the fenders and it wouldn't be long before scratches are all over them. I did a tilt front end on my corvette and I love it. But I don't want to mess with all that on this truck seeing how the fenders are already painted.
05-23-2012, 02:16 PM | #918 |
Nothing more than dust accumulating on it. This morning I replaced the intake manifold gaskets on the 350 for my wife's suburban. I've got so much to do I farmed the engine swap out to my little cousin.
05-23-2012, 02:20 PM | #919 |
Tot Roddin'
Nice progress Ryan.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
05-23-2012, 02:24 PM | #920 |
05-23-2012, 03:46 PM | #921 |
Enjoying left field
Ryan, have you got some pics of your corvette tilt? If I can figure out a way to do a tilt cleanly, I might attempt it.
05-23-2012, 07:40 PM | #922 |
What kind of pictures would you like? I know i have a fewe but can get more.
05-24-2012, 11:40 AM | #923 |
awesome build Dieselwrencher im in the process of building a 2wd ppumped 24v and your build has alot of insightful information to help my build as it goes. Thanks. subscribed.
12ram3500 HS mm, FP 5" tbe, SB cai, 2.5" up, 35s on 20s. SOLD 02ram2500 twin turbo, built 47re, sticks & studs : SIKDZL -youtube. 68gmc1500 soon to be: shortbox, ppumped 24valve, s467.7, dap 300s, H2O/Air intecooled, meth controlled, 47re, 14bolt, 2wd. |
05-24-2012, 02:42 PM | #924 |
Thanks, if you have any questions, feel free to ask. I saw your thread on my not so favorite forum.
05-24-2012, 07:14 PM | #925 |
haha yeah good old cf, thanks man. Im sure ill stumble across a couple speed bumps with my build.
