Old 04-26-2014, 09:09 PM   #901
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Once the front ends off and the crossmembers in I can get the hole drilled in the crossmember for the cpp mounts in the rear location. Trim frame rails for header clearance and check valve cover clearance.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-26-2014, 09:13 PM   #902
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Originally Posted by niterider65 View Post
sure am liking the way that motor is lookin
keep up the good work
Thanks I appreciate it. It feels great to finally get to the point of doing the swap. And looking forward to a little more go in the gas pedal!!!
Old 04-27-2014, 10:38 AM   #903
Eric15chevys
Eric15chevys's Avatar
Re: 1963 C-10 in NC
Had fun getting to look around at all the parts. I wish I could have stayed to pull the engine, but friends were making homemade pizza. Hopefully I can get back over and help with the rest of the install...Oh and helicopter mechanic not pilot. I actually work.
84 GMC One ton 4x4 454 4 speed
62 Chevy C10 short fleet
plus about 13 previous gm trucks
from 1960 to 2000
Eric15chevys is offline   Reply With Quote
Old 04-27-2014, 08:44 PM   #904
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Got a little mre truck time in today. Got the driveshaft removed, transmission and bellhousing. Was able to do a few coats of degreasing and get the frame cleaned up real nice. Ground down the rivet heads to remove the frame linkage. Then groud down the rivets to clean the frame up. Pulled all of the rear brake lines and disconnected the system from the mc. I'll pull the front lines with the crossmember once the front end is removed. Then applied a good coat of rust converter/sealer/inhibitor to protect the frame. I want at least one more coat, I normally do 2 and 2 coats of paint with great success.
I feel good with 1st weekend work. Little tired from all the work and jumping in and out of the truck for 2 days, but its getting there.
We've got a few days of rain coming so may be a few days before i get the front end off.
Old 04-27-2014, 08:48 PM   #905
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Enjoyed the company and the truck talk. Looking forward to seeing your 62 and maybe helping some also. I corrected the pilot/mechanical thing....sorry...classic case of fingers not typing with the brain.
And the pizza was probably more fun than turning wrenches!!! I got alot done this weekend for 1 person and the number of things going on.
Old 04-27-2014, 11:36 PM   #906
CRGRS 66
CRGRS 66's Avatar
Re: 1963 C-10 in NC
Cleaning up nice, lots of hard work there, especially with the cab on, looking good, can't wait to see that big block in there
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 04-28-2014, 08:19 AM   #907
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Thanks. Yeah....my hands are feeling it today after two days of wrench turning and frame cleaning. Access isn't too bad, especially with the trans cover removed. Its cleaning up real nice though...haven't encountered any bad asphalt or road paint that doesn't want to remove. Its mostly oil, grease and mud. The rest will have to be done off my back on the ground. Luckily the frame is really clean once you pass the e-brake crossmember. The bed will be coming off in a few weeks when I do the rear end posi conversion and also to paint the back of the cab. So I'll do the tops of the frame rails once its off.
Cab looks ok from the bottom....driver side will need inner/outer rocker, lower a piller, toe boards and cab corners and cab supports...which was to be expected. Pass side is a little better, but will pretty much get the same treatment.
Old 04-28-2014, 10:57 AM   #908
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
Looking good bud!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 04-28-2014, 10:59 AM   #909
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Originally Posted by T.J. MCCAULEY View Post
Looking good bud!
Thanks TJ. Slowly but surely it'll get there. I have a buddy coming over this week to help pull the front end sheet metal. Then I can drop the cross member. Have already cleaned the front frame pretty good. Just the areas I can't reach left, but I'll have good access pretty soon.
Old 04-28-2014, 11:55 AM   #910
61K10
61K10's Avatar
Re: 1963 C-10 in NC
looking good--a little here--a little there and you will be done lol! don't we wish it was that easy--
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 04-28-2014, 01:17 PM   #911
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Yeah...wish it was like the 1 hour tv shows, but then reality steps in and it'll be time consuming. I've always been a fan of the little projects because they do add up. Especially with my work load and I'm never sure where my time will open up.
Old 04-28-2014, 02:36 PM   #912
Eric15chevys
Re: 1963 C-10 in NC
I showed the picture of the engine removal at work and a guy there might be interested.
from 1960 to 2000
Old 04-28-2014, 03:01 PM   #913
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Ok, just let me know. I"ll hold off on listing it then until we see what he says. Its complete from air cleaner to oil pan. I'd recommend a rebuild or at least new rings/gaskets. Still holds 40 psi cold on oil and will hold 30-35 psi warm all day long. Was last run on 4/23/14. It is 51 years old and has never rebuilt to my knowledge. I have all the records back to 1972 on the truck/engine.
Fuel pump was replaced about 4k miles back. Carb was replaced w/ a Holly remanufactured 1bbl Rochester a year ago. Pertronix II was installed 2 years ago w/matching coil. You've seen the engine, so you pretty much know what it entails. I've never had to do any major work to it....ie. take the head or oil pan off.
I will be keeping the alternator (its the same part # for my 348 "w" block, but the brackets will go with the engine.
The transmission will need a home too. Muncie mc318 non-synchronized 3 speed. I have a few pics of the engine I can post for you.
Old 04-29-2014, 11:03 AM   #914
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Got home late last night and saw the UPS guy beating feet down the driveway at a fast pace. Looked to the left and figured out why. Exhaust kit came in .....and obviously out somewhere. Looks like the box was ripped completely in half and half ass taped back up. And the exhaust pipe was stuck completely out of the box. Took pics for reference...and did inventory. All parts there except for a few bolts that will cost $4-5 at home depot to replace so I'm not filing a claim and going through all the hassle, but UPS will get a call today. 2nd box in a week with damage. 1st was the broken column parts and now this.
Always glad to have parts show up, but man it sucks to walk out and see a box in this shape.
Old 04-29-2014, 11:06 AM   #915
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
The exhaust kit was all there except for a few bolts. Test fit everything and no damage to the pipes, hardware or mufflers. Looks like a great kit. The "H" pipe is already welded and the price was right. We'll see how install goes with mods as its advertised as a 66-72 kit. So e-brake is the only issue that should pop up, but we'll deal with that when the time comes. I do have to get a different part to mount to the "ball flange" style headers I have, but they seem available through Summit and Jegs.
The storms kept me in last night, but I was able to degrease and strip the two bellhousing pans so I can get them prepped for paint. So at least it wasn't a total loss of a night.
Old 04-29-2014, 11:09 AM   #916
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
UPS is nothing but a bunch of overcharging idiots. They charge almost twice as much as fedex for longer shipping time and to damage your packaging. But at least you got your kit an its fitting good. If you had lost some parts though I'd still file a complaint against them. Time to start changing some of this carelessness.
Old 04-29-2014, 11:26 AM   #917
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
I've done the whole file a claim thing in the past with UPS....very time consuming and a big PITA. I'll definitely contact them but for $5 in parts I'll replace them myself.
At least it wasn't NOS parts like the last episode. Lost a factory passenger side cast iron mirror arm and an offset mirror head. They delivered an empty box.....
Old 04-29-2014, 01:21 PM   #918
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Got on Summit this morning and ordered the Hedman header reducers. Part # 21115 for the 3" inlet and 2.5" outlet ball/socket and costs was only $25.92 shipped. So this should wrap up the exhaust minus tips if I decide to install them.
Old 04-29-2014, 04:47 PM   #919
WhippinSaw
WhippinSaw's Avatar
Re: 1963 C-10 in NC
Excited for ya , beautiful job on the motor, gonna be sweet.
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle.
WhippinSaw is offline   Reply With Quote
Old 04-29-2014, 11:23 PM   #920
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
i appreciate the compliments. work has been at a stand still due to the storms. had a flash flood come through earlier and the creek in my front yard went up 2' in less than an hour. washed out over the driveway and took a few inches of crush and run with it. got some pretty good size hail too. but hopefully it'l pass in a day or so and i can get the driveway fixed and back on the truck. im ready to get the front end off and front crossmember dropped. its my weeks goal.
i cant wait to get her back on the road and its only been a few days.
Old 04-30-2014, 12:33 AM   #921
Captainfab
60-66 Nut
Re: 1963 C-10 in NC
Which exhaust kit did you purchase?
Old 04-30-2014, 08:38 AM   #922
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
I ordered the Thrush kit (although its all got Dynomax stickers) # WLK-89027 through Summit racing. Was $245.97 with free shipping. Did take about a week to arrive since it came from their west coast warehouse. Its a great looking kit and the pipes fit together nice. Don't know how it sounds yet, but we''' know in a few weeks. I'll run the mufflers that came with the kit, I can always change them if I don't like them. All hardware and the mufflers come with, but they do come with the flat style flange fittings for headers. I ordered some ball style flanges to go with my Hedman headers. Advertised for 1966 - 1972 small block and big block 2wd trucks, so I figured it couldn't be to far off of a fit for the 63.
http://www.summitracing.com/parts/wlk-89027/overview/
Old 04-30-2014, 08:48 AM   #923
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Heres a few pics of our flash flood in the front yard last night. Got kinda close to the carport where the stepside is. Neighbors been there 55 years and says its been 25 years since its gotten that high here. I normally have about 6-8" of water and it takes almost 3' to crest the road like it did.
The pic of Hardees is about 10min down the road from me.
Old 04-30-2014, 10:24 AM   #924
jcramsey
jcramsey's Avatar
Re: 1963 C-10 in NC
Wow...didnt realize that much rain came through. It must've just missed us. Downtown Charleston is a mess when heavy rains come....glad I work from home!
The Egg Hauler
The Government Mule
jcramsey is offline   Reply With Quote
Old 04-30-2014, 10:49 AM   #925
CRGRS 66
CRGRS 66's Avatar
Re: 1963 C-10 in NC
If you mentioned it and I missed it I am sorry to ask, but could you tell me what exhaust kit you ordered?
Craigerrr
