07-15-2010, 06:23 PM | #926 |
Re: 1969 SuperBurb build-up (Bagged and Blown!)
Rob - LOVE the gauges, especially the 180 MPH. Your progress, and workmanship are spectacular!!!
72 Cheyenne shorty "CheyLow" 72 3/4 long 4X4 69 SWB "Prospector" 68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled" Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com |
07-15-2010, 06:29 PM | #927 |
67cheby
by the way , i thought you had the trim on ??
07-15-2010, 06:48 PM | #928 |
07-15-2010, 06:53 PM | #929 |
Still Learning
Those gauges look awesome! I know that you had that done a few years back, but you have a ballpark cost on just the gauges? Looks like a bunch of $$$.
+1 on the Mar-K stuff. I have used their stuff in the past with good results. |
07-15-2010, 08:15 PM | #930 | |||
I just had it taped on to check the fit. I won't put the trim on until all of the body panels are on and aligned. I got the gauges from Summit. I think the total was around $550-$600. Here's some more pictures of the front brake lines going to the master cylinder, the Flaming River tilt column, the CPP steering shaft setup and my custom made glove box emblem, .
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 07-15-2010 at 08:17 PM. |
07-15-2010, 08:56 PM | #931 |
Holy...! That emblem is insane!
07-15-2010, 09:17 PM | #932 |
GM ONLY BABY!!!
Rob, I have a few questions. Hope you can share some of your wisdom.
You are using the ECE motor mounts correct? I am starting to install a LS2 in my 72 GMC truck. I also have the ECE mounts. What headers would you recommend, the Thorleys? I will be using a 200 4R trans, which is still in the truck. My LS2 is like a 01 or 02, and I would like to use the mechanical fan that's on it. I wonder if I can use it with the stock radiator? Why did you go electric, radiator to fan spacing?
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
07-15-2010, 09:29 PM | #933 | |
It was hand carved......
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-15-2010, 10:03 PM | #934 |
GM ONLY BABY!!!
Thanks Rob, ya I just found that LS swap subforum. Keep up the good work!! We all want to see the finished 'Burb. Maybe at a board meet someday.
07-15-2010, 10:41 PM | #935 | |
R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 07-15-2010 at 10:41 PM. |
07-16-2010, 12:36 AM | #936 |
Going Down?
Rob,
Where did you get the temp sender bushing? All looks good Thanks
Just another day in Paradise Rebuild thread http://67-72chevytrucks.com/vboard/s...d.php?t=354512 |
07-16-2010, 12:45 AM | #937 |
Still Learning
thanks for the info on the gauges. I was thinking it would cost more than that.
Wow! that took some serious time! Just curious what material did you use to make that from? Have I mentioned this burb is way over the top. |
07-16-2010, 01:04 AM | #938 |
VA72C10
Awesome as usual but that glovebox emblem.....WOW.....just.......WOW!
Looking for a 67-72 swb or blazer project in or around VA. |
07-16-2010, 03:49 AM | #939 | |
63 4 door Chevy II - NOVACATION (Updated 08/23/09) 65 Morris minor Traveler 77 Chevy Longbed. 93 Corolla JDM 20V Swap Daily Driver (Updated 07/16/09) Powder coating Hawaii Domestic Violence Awareness Show 5/3/09 Hawaii Rod and Custom Show 4/18 Last edited by Jvsapp; 07-16-2010 at 03:54 AM. |
07-16-2010, 05:48 AM | #940 | |||
Thanks. The sending unit came with the gauges and the bushing came from Dakota Digital. I'm not sure if it will work with the stock gauges.
07-16-2010, 08:53 AM | #941 |
GEARHEAD
Tranny temp, vacuum?
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
07-16-2010, 09:39 AM | #942 |
Still Learning
Cool! I like the way you are spreading the love on this project all over the board. Let me know if I can make something for you too
07-16-2010, 02:38 PM | #943 |
Thanks! How's the blazer coming?
Blazer(s) are doing about as good as your's!!!! That hand engraved emblem is out of this world sick! Ronnie
07-17-2010, 06:03 AM | #944 | ||
One gauge will be a dual boost/vac. I've already got tranny temp. I was thinking wideband and oil temp?
R/
07-17-2010, 08:24 AM | #945 |
67-72 parts collector,…
How about some billet Coys centercaps?
07-17-2010, 02:13 PM | #946 |
Still Learning
07-17-2010, 03:54 PM | #947 |
Some caps with SB on them would be SUPER COOL!!!
07-18-2010, 04:11 PM | #948 |
Here are a few pictures of the modification I did to my "drive by wire" gas pedal that allowed me to install a stock 72 CST pedal in it's place. I also got all the steering linkage cut and connected.
07-18-2010, 10:26 PM | #949 |
Here are some pictures of what the inside of a "NEW" engine looks like when I pulled the valve cover, . I'm thinking about painting the valve covers, but I can't decide between red or black???? Also, any suggestions to where to install a oil temperature sender for a 4L60E? TIA.
R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 07-18-2010 at 10:27 PM. |
07-18-2010, 10:28 PM | #950 |
VA72C10
Man, you know how to test a man's willpower from coveting.
