Old 03-05-2008, 08:54 PM   #926
SactoJim
SactoJim's Avatar
Re: LFD's low buck truck build!
OK.....I'm pissed.....thosed turned out really nice Kevin. I like them better then my 60/40's I just got done.
If you don't mind me asking.....how much did they charge?
If it's close to mine....I'm gonna be really pissed!
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 03-05-2008, 09:23 PM   #927
70STOVEBOLT
70STOVEBOLT's Avatar
What causes all the condensation? The design of the mufflers?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 03-05-2008, 11:50 PM   #928
NTR72GMC
2wd FTW!!!!
NTR72GMC's Avatar
That Seat Is Going To Set The Interior Off Very Nicely I Realy Like The Door Panels As Well Cant Wate To See Them In The Truck.
NTR72GMC is offline   Reply With Quote
Old 03-06-2008, 08:38 AM   #929
Rokcrln
Rokcrln's Avatar
$836 out the door with door panels and dyed arm rests to match. They also installed the seat heaters I brought them. I could not be happier with the end results.
Turns out all the water I had comming out was not the head gasket I have not driven this truck in three months but I have been starting it up and moving it around alot as needed. This caused condisation but never let it blow out or get hot enough to cook it out. Also my exhaust has not been changed since I swaped motors and it has a good low spot that can hold alot of water it turns out Also it is the design of the muffler to a point. Flow masters are fully welded and do noit have a weep hole to let moisture out like OEM's do. But then again that is why OEM's rust out so fast.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 03-06-2008, 08:55 AM   #930
slammed1
1972 Chevrolet SWB
slammed1's Avatar
I have seen many many many late model vehicles with FlowMasters and other mufflers rust out very prematurely due to all the condensation and especially with smog type engines. i would suggest a weep or drain hole in the muffler somewhere to keep them drained........it wont negatively effect the muffler or make it any louder. Might help keep muffler lasting a lot longer.
My New thread with pics (not my build thread yet.)
http://67-72chevytrucks.com/vboard/s...46#post2573646
1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project.
1980 Camaro Inherited when father passed,68K Miles
2003 Ford Mach1 FUN as Hell!!
2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot)
2004 Dodge Ram HEMI 10" lifted on 37's and 2wd.
slammed1 is offline   Reply With Quote
Old 03-07-2008, 06:18 AM   #931
Rokcrln
Rokcrln's Avatar
Well I had a few minutes between Taylors naps so I put it to good use. I finished the Dyna Mat up the fire wall, cab corners, inside the doors and any were else I could get it. I had 3 sheets left over so I doubled up the fire wall and front floor. Then any part that was not covered by carpet I painted black so it would blend in. I will try and get a bit more done tonight after he heads off to sleep.
Kevin
LFD Inc.
Old 03-07-2008, 06:41 AM   #932
grady5
first off let me say that your skills are incredible. i have checked out several of your threads and i am always amazed. my question for you is have you ever thought of making an under dash panel? one thing i never liked about older vehicles is the unfinished looking lower dash. i would love to see what you could come up with. and again great work on all the rides. chris
grady5 is offline   Reply With Quote
Old 03-07-2008, 08:55 AM   #933
Rokcrln
Rokcrln's Avatar
Funny you mention that as I was just adding it to a build list I have going for another project. This one is not that detailed so it will stay as is once I clean things up a bit and wire in my C.C. and seat heaters. I will probaly do it out of fiber glass so it tucks into the dash lower lip and covers everything under the dash to the fire wall. Just leave the brake pedal comming thru.
Kevin
LFD Inc.
Old 03-07-2008, 09:09 AM   #934
grady5
great, i cant wait to see it. i know it will be top notch!
Old 03-07-2008, 11:16 AM   #935
slammed1
1972 Chevrolet SWB
slammed1's Avatar
I may have missed the info if it was given but I will ask.........the gauge housing you have above the left A/C vent,is that hand built or a product that is purchaseable?
Thanks again for all the progress info and pictures,one of the top threads I visit daily.
Old 03-07-2008, 03:53 PM   #936
Rokcrln
Rokcrln's Avatar
Hand built! It is a few pages back I may have been in the project shell games thread when I was doing some part swapping. It was florest foam shapped to size then glassed with the gauge mount inserted into the foam. A bit of sanding, a hole in the dash and a new mounting bracket since the dash is curved at this spot then you are done.
Kevin
LFD Inc.
Old 03-09-2008, 06:27 AM   #937
Rokcrln
Rokcrln's Avatar
Here are some more pics! Almost ready for a test drive to see how the CC works. Thanks to my father in-law who spent some time bolting in parts while I was at work. Retirement must be nice
Kevin
LFD Inc.
Old 03-09-2008, 07:18 AM   #938
nuke1
nuke1's Avatar
that is starting to look killer kevin. hope she will be on the road soon.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 03-09-2008, 09:43 AM   #939
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
I will agree...that looks great...nice job!
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 03-09-2008, 10:42 AM   #940
TonyJohnson
TonyJohnson's Avatar
Nice!
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 03-09-2008, 05:06 PM   #941
killer71
killer71's Avatar
Seats look much better installed....
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 03-09-2008, 05:59 PM   #942
see ten
WTB this ad
see ten's Avatar
It's really starting to look like a truck again!
see ten is offline   Reply With Quote
Old 03-09-2008, 09:55 PM   #943
Rokcrln
Rokcrln's Avatar
So what are you saying they did not look good as trailer seating!
I went out to the shop at 2am this morning when I woke up and decided to try and get a few more things done. All that is now left is to install the carpet sill plates, headlights and a full tank of gas and we are off and running. I am heading down to my parents later today and I will take it out for it's maiden make over shake down. It is just a 130mile round trip but should be alot of fun. Sunday I will be coming back home with my son (7months old) as my wife will be staying for a baby shower for a family member and comming hoime Sunday night. I think we might have to go for a nice long drive on our way home
My car cover finally came back from California Car Covers again so once I fix it this time I can park the truck out side and finish up Traizer!!
Ok this is not a bash as much as it is a just know what you are getting into! I have ordered covers from Ca Car Cover before with out any problem but this time was another story.
First I went on-line and ordered a cover for a 70 SWB Custom fit with my company logo on the front. Simple enough since it was a regular item of theirs. Then I marked the box for side mirrors and antena. Then down in the aditional info box I discribed the mirrors and left my cell # if their were any qiestions or problems they could call me before shipping. No calls is good right?
I get the cover and guess what no mirrors and with the stock ones I have the cover will not fit with out almost ripping the cover. I call to find out what happened and the lady tells me well it is a pre 80 model so we do not do mirrors!! I said is this not a custom fit cover and did I not have a box to check that SAID MIRRORS? She said yes but we do not do mirrors for pre 80 models. But if you want you can send it back and we will add them at not extra cost I am sorry but this maid no sence to me but I said ok when will I get the shipping return lable so I can send it back (long pause) and she says they will send one right out. I tell her I will mark the cover for the mirrors and antenna so their are no mistakes before I send it out.
So I take pics with a tape measure showing key dimension, start and stop points and I slice the cover right at the millor and antenna locations. I test fit the antenna sleave to make sure it is long enough for our stock cowl mounted antenas and it is like 4" too long but I figure I will leave it as is.
3 weeks later I get the cover back and the mirrors fit great but now the antenna sleave is 12" too short So I call back and talk to the same lady and tell her thank you the mirrors fit great BUT the antenna sleave is too short now. So she wants me to send it back again (that would put it about 2 1/2months from order date) and I tell her no thank you just sent me a new antenna sleave and I will pay someone here to put it on because I need the truck to be out side so I can get other vehicals built.
So a long story short I have the sleave comming, they gave me my original shipping $ back and I have a real nice cover. I will be ordering from them again but I wil call first and set it all up with a manager as to what I want and need. Also I will order it a few months before I think I will need it. Like I said they are a great company and have good products but youy may run into a few snags but now you know about them so it won't be a surprise
Kevin
LFD Inc.
Old 03-09-2008, 11:53 PM   #944
jwcardy
looking good...awesome job...
-wes
jwcardy is offline   Reply With Quote
Old 03-10-2008, 01:50 AM   #945
Rokcrln
Rokcrln's Avatar
Went for about a 2mile test drive to get gas and a few parts I needed for my exhaust fan set up I am doing in my shop and boy is this a solid truck now. Not a single rattle or tin can sound. Between all the dyna matt, carpet, door panels and making sure every nut and bolt was new or cleaned and tightened made a world of differance. You shut the doors with a click and all you head is a nice thud sound. Heck with new cars I will be heading out soon and wil get some pics to post up in a day or so when I get home.
I went ahead and put in my "show" head lights. They put out cr@p for light but sure look good with the blue bulbs. I wil put the H4's back in soon enough.
Kevin
LFD Inc.
Old 03-10-2008, 11:53 PM   #946
Rokcrln
Rokcrln's Avatar
Well all went great! No problems, alot of thumbs up along the way. My parents loved it and my dad even gave up his parking fior his Benz for the night to keep all the due off of it. I stopped a few spots along the way for some pics on the way to my parents and only a few on the way home because I hade Taylor with me and he was busy sleeping away the day. I guess he approves of the ride and rumble. We went home thru Napa and over the hill past Lake Beriessa so I had about 15 miles of nice twisty road that was alot of fun. I even cought up to a couple of Mazda's and Honda 2000 that were playing on the twistys as well. I guess horse power is good for somthing after all.
Kevin
LFD Inc.
Old 03-11-2008, 12:17 AM   #947
texanidiot25
Eat My Rust
texanidiot25's Avatar
That must blow their minds when a 5000 lbs, 38 year old truck is on their rear in the twisties
The truck is beautiful, and has come a HUGE way since the start.. Congrats man!
Now, about my truck, the offer still stands: free food and cookies for daunting hours of labor. Sound good?
texanidiot25 is offline   Reply With Quote
Old 03-11-2008, 01:08 AM   #948
SkylineNXS
SkylineNXS's Avatar
First let me say awesome work and i love checkin your builds all teh time. The truck turned out beautiful, and it was on the cheap, very nice.
All i can see on ur last pics post is teh red x's though....i wanna see those pics, lol
Nice job, very nice job...
BRAD
2000 GMC Sierra EXT Cab Short 4x4, finally mine...
1966 C10 SWB Fleet, 250 I6, three on the tree....
Previously Owned....
1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4....
1972 Chevy LWB Fleet 350/350
EXTENDED CAB ALL THE WAY!
.._..~...-...._...____
.._..-...______|_|__\____
..-..~.|_(O)__|_|__|_(O)]
SkylineNXS is offline   Reply With Quote
Old 03-11-2008, 01:35 AM   #949
Rokcrln
Rokcrln's Avatar
BRAD
They show up fine for me so I am not sure what's up on your end!
Kevin
LFD Inc.
Old 03-11-2008, 02:03 AM   #950
kyull67
kyull67's Avatar
I see the pics too. It turned out very nice! But whats up with that bumper?
kyull67 is offline   Reply With Quote
