Old 06-06-2013, 10:57 AM   #926
gdavis
gdavis's Avatar
Re: 1968
I am not going to install the headers on the pass side of the engine today. We are haveing our first storm of the year. Already had 3 to 4 inches of rain and it has not even got to us yet.
I will work on the perch, I welded up last night. At least I can do something beside setting around getting lazy.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 06-06-2013, 08:28 PM   #927
gdavis
gdavis's Avatar
Re: 1968
Today I finshed welding the V8 perch I messed up. Now it looks like I never touched it. Also I re-installed the perch on the truck and now I am back to square one again. I installed the gas pedal and cut some plugs that will cover the holes where the 68 gas pedal was. Tomorrow I will weld them up. I hope that my gas tank will be here soon. I would love to run my lines from the fuel pump to the tank. Brian you savied me some money. Thanks on the perches.
I hope I can install the other header tomorrow.
Check out Patches
Old 06-06-2013, 10:45 PM   #928
mjensen
mjensen's Avatar
Re: 1968
Great progress! It's looking very nice!
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 06-07-2013, 04:16 PM   #929
gdavis
gdavis's Avatar
Re: 1968
thanks a lot my friend
Check out Patches
Old 06-07-2013, 04:27 PM   #930
gdavis
gdavis's Avatar
Re: 1968
Today, I removed the front clip. Had to demple the frame for the power steering gear box. I also cut the frame rail on the pass side so the headers would fit without rubbing. I think I might raise the motor a 1/4 inch so the perch don't kit the headers. A longer bolt on the rubber mount will do the job. I installed the headers on both side with headers bolts. Took the studs back and bought the headers bolts. Fit like a glove. Tomorrow I will re install the front clip and be back on track. The main reason I pulled the front clip is to dimple the frame. Which I forgot to do a while back Thanks brian for reminding me. The headers look a lot cleaner with the right bolts.
Check out Patches
Old 06-07-2013, 04:28 PM   #931
gdavis
gdavis's Avatar
Re: 1968
Headers installed
Check out Patches
Old 06-08-2013, 06:53 PM   #932
gdavis
gdavis's Avatar
Re: 1968
Well, guys I finshed the sand blasting on the grill. It turned out real nice. I Got it all primed up today. Fixed the two spots that needed some love. Had to get two new lines for the transmission cooling to the radiator. Had to re-route the line. They were right in the middle of the dump pipe for the headers. Tried to re- bend what I had but I broke one, so off to the parts store. Got one installed and I figured I would call it a day. Don't like the way they look so I think I will get another one and use the 45% elbo this time on both of them. Not going to show how they look untill I get them the way I like. Don't want you guys to think I did not know what I an doing.
I hired a new helper today. All he wants is a lot of attention.
Check out Patches
Old 06-09-2013, 08:20 PM   #933
gdavis
gdavis's Avatar
Re: 1968
Still no gas tank guys. Bad shipping seems to run all over the place. I will be raising my bed at least 4 1/2 inches. I seen it done in this months issue of Classic Trucks. I seen it up close also and I really like it. So stay tuned later down the build. Got a lot of other things that needs my money first. Like a column and wiring and a ton of other things.
How do you guys like my new helper. Dosen't get a lot but got to stay right with him. Or he will MESS up a lot.
Check out Patches
Old 06-10-2013, 07:27 PM   #934
gdavis
gdavis's Avatar
Re: 1968
Well, I got a PM from my gas tank guy. It was shipped out this morning I hope it was anyway. So I welded up the holes in the firewall where the 68 gas pedal was. Now I'm going to installed the 72 gas pedal. All I need is the measurements where the 72 gas pedal is to be installed. I wish I would have thought ahead. I would have done this when I was working on the firewall 5 months ago. But anyway it is done and it came out pretty good. I didn't spend a lot of time making the inside look as good as the outside. It will be covered with carpet anyway.
My adophed son's school project need to find them a home.
Check out Patches
Old 06-11-2013, 12:59 AM   #935
Evaded
Evaded's Avatar
Re: 1968
Great build so far.. awesome work. You my friend have some skills. Looking forward to more! Can you post what paints you used in a can.. primers and paints.
Eric (Evaded)
If I see a Zombie.. Im runnin it over with my Truck.
Evaded is offline   Reply With Quote
Old 06-11-2013, 10:08 AM   #936
gdavis
gdavis's Avatar
Re: 1968
Eric (Evaded)
This is the first frame off I have done. It is only a thing.
Check out Patches
Old 06-11-2013, 10:12 AM   #937
Low Elco
Re: 1968
Looks great! If I had that helper, I'd get nothing done, I'm a huge sucker for babies. Cutie patootie! Truck's rollin' along!
Low Elco is offline   Reply With Quote
Old 06-11-2013, 08:11 PM   #938
gdavis
gdavis's Avatar
Re: 1968
Yea I have a hard time working when I know he is in the house. What a little man he is. thanks
Check out Patches
Old 06-11-2013, 08:20 PM   #939
gdavis
gdavis's Avatar
Re: 1968
My gas tank guy gave me a PM this morning and what a guy. He refunded some of my shipping. It seems that it did not cost as much as he expected. wideside72 sells parts on the parts board. Guys he is a real stand up guy. I have sold and bought a number of parts from guys there. No problem at all. But a word to the wise be carefull when pictures are not posted only links. I'm not saying that all links are not real. Just be carefull. wideside72 it was refreshing to deal with a guy like him. We all could take lessons from him. God Bless
Check out Patches
Old 06-12-2013, 05:56 PM   #940
gdavis
gdavis's Avatar
Re: 1968
Eric (Evaded)
rustolem primer and gloss black
Check out Patches
Old 06-12-2013, 06:01 PM   #941
gdavis
gdavis's Avatar
Re: 1968
Gas tank should be here the 14th of June. I am pulling the bed off the truck so I can get to the frame easier.
Painted the front grill today orange. I hope to paint the hoops and light benzels tomorrow.
Also installed the 72 gas pedal in the correct place.
Check out Patches
Old 06-12-2013, 06:03 PM   #942
gdavis
gdavis's Avatar
Re: 1968
more pictures. I put the grill outside so the 90% weather will bake it dry. Boy was it hot here today.
Check out Patches
Old 06-12-2013, 09:49 PM   #943
Xeen
Xeen's Avatar
Re: 1968
Nice job George, they both look great.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 06-13-2013, 09:43 PM   #944
gdavis
gdavis's Avatar
Re: 1968
Thanks Brian
Check out Patches
Old 06-13-2013, 09:52 PM   #945
gdavis
gdavis's Avatar
Re: 1968
Today, I painted the cowl again. Somehow it got scratched so I painted it again and now it looks real good. I also painted the grill hoops and the head light benzels. Before long I will have a orange truck. Going to call my Brother-In-Law tomorrow and set a time when he can come up from Ft. Myers. To fine tune the body work.
Check out Patches
Old 06-13-2013, 10:54 PM   #946
Xeen
Xeen's Avatar
Re: 1968
That is going to look really sharp George.
Old 06-13-2013, 11:16 PM   #947
Mustard72
Mustard72's Avatar
Re: 1968
Can't wait to see it all together! Get that brother-in-law of yours up there! That orange is pretty cool.
Nick
Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986
http://67-72chevytrucks.com/vboard/s...d.php?t=545356
Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears
Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck.
Mustard72 is offline   Reply With Quote
Old 06-14-2013, 10:53 AM   #948
gdavis
gdavis's Avatar
Re: 1968
Yea I like the orange. As far as my Brother-In-Law I will haveto wait untill tonight he is working during the day. But we will see.
Check out Patches
Old 06-14-2013, 01:16 PM   #949
chevy88
chevy88's Avatar
Re: 1968
Been watching this build for awhile, great job, nice progress.
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline   Reply With Quote
Old 06-14-2013, 06:04 PM   #950
gdavis
gdavis's Avatar
Re: 1968
Thanks guy. Painted more color today.
Check out Patches
