03-06-2016, 01:01 AM | #926 |
All about them K’s
Re: Rat repair.
Great work mike, it's coming together well... I need to go out and get after mine now, been away from it for a few weeks.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
03-06-2016, 04:29 PM | #927 |
Re: Rat repair.
Well the weather isn't cooperating today, i don't mind having my 220V extension cord strung out from the garage, over the fence to my car cover and hung onto the truck if its a little damp or even a light sprinkle, i never let it touch the ground and its got a very heavy duty plastic sheathing that is very durable and it is in great shape, i inspect it often for cracks and abrasion and i keep the plug end high and dry, I'm always standing on dry plywood when i weld also, but once the deluge of rain starts its time to call it quits, i would like to retire some day...
I have about 1/2 of the spot welds done in the rocker, again no pictures.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
03-06-2016, 07:44 PM | #928 |
Re: Rat repair.
Yea, none of my vehicle "to do" list got touched today.
03-08-2016, 06:07 PM | #929 |
Re: Rat repair.
So i finally get a real nice day and what happens? no motivation..
Here's the progress pictures, still have some welding and grinding to do but its coming along nicely. I'm assuming that due to the fact i flanged the floor in i will need to smear the bottom of the flanged area with seam sealer, probably all welded and joined areas i guess. Also, a pic of my passenger cab corner to show how small the flanges are and why i'm so concerned about sealing the gap up, kinda wishing i spent a little time welding in some extra flange material on the drivers cab corner as i think the stock corners had more material there and sealed the area better.
03-08-2016, 06:09 PM | #930 |
Re: Rat repair.
I do have a question, when i epoxy prime the floor and rockers is it advisable to remove the existing weldable primer and black rocker primer first?
03-08-2016, 06:17 PM | #931 |
Re: Rat repair.
The black rockers a electro plate black primer. it's like power coat. you can epoxy prime over it. as for the red prime try a test area and see if it sticks.
03-08-2016, 06:24 PM | #932 |
Re: Rat repair.
Ok thanks Dwilber
Next time i want to find a can of brush on weld thru primer, this stuff in the spray can comes out way to fast and is not controllable.
03-08-2016, 06:44 PM | #933 |
Re: Rat repair.
I had the same issue with gap on rocker and cab corners. I used the hammer and dolly to rework rocker a little then did some trimming and cleaning up in cab corner and B pillar. Was able to get it closer by doing so. There was ripples on cab corner flange and rocker flange I hammered and ground flat.
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
03-08-2016, 06:52 PM | #934 | |
Re: Rat repair.
Thanks, I did rework the rocker a bit, as well as the cab corner, pictures don't show it but the bottom is touching and the top is separated a bit. I'll try and get a pic of that next time.
03-08-2016, 06:55 PM | #935 | |
Re: Rat repair.
As for motivation..... we want to see more so keep it up. no matter how a classic truck looks everyone wants it...... Weld-on my friend!!
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
03-09-2016, 02:39 PM | #936 |
Re: Rat repair.
Looks like it is all coming together nicely Mike. On my floor repairs, I spread seam sealer on both top and bottom of my welds - figuring the extra insurance wouldn't hurt. My goal for the floor was never to make it appear there hadn't been a patch done. Plus, I sprayed bed liner top and bottom of the floor as well. All of that managed to cover any ugly from my welding pretty well
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
03-09-2016, 05:31 PM | #937 | |
Re: Rat repair.
So the weather chanel said by 3 it was gonna start raining again, so i get out there about 10, all the welding gear, 10 minutes later i'm outta gas! Oh well.. Got a new cylinder today instead, bought a new 4.5" grinder too made in Germany called a Metabo (Ma-Ta-Bo) got the 8.5 amp version, should last a lifetime, my old Skill i bought when i was 18 has served me well thru the years but the cord has been replaced, the housing is cracked in 2 places, it vibrates becase the bearings are wearing out, and the switch does not lock onto the on position any more..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's Last edited by swamp rat; 03-09-2016 at 05:36 PM. |
03-10-2016, 11:22 AM | #938 |
Re: Rat repair.
Looking really good Mike a lifetime grinder would be great, was it spensive?
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
03-10-2016, 02:04 PM | #939 |
Re: Rat repair.
$225, about the same as my right angle 20V Dewalt Drill. The 6 amp version was about $150, there was one more powerful that was a bit over $300, the 6 amp version has a smaller body and is lighter, probably would have been fine with that one.
03-10-2016, 03:26 PM | #940 |
Re: Rat repair.
Matabo makes good equipment my Brother has several of there tools.
03-10-2016, 06:21 PM | #941 |
Re: Rat repair.
Its been windy and wet out so being as last time i moved the welder across the side yard i kinda chewed it up a bit caus its a mush pit, so i decided it was time to put some better wheels on my shop welding cart, i wanted wider swivel casters but the hard ware store didn't have any.
Here's a feature if the Metabo grinder i like, a quick detach safety shroud.. Hope to get back to the truck tomorrow pending weather..
03-13-2016, 02:56 PM | #942 |
Re: Rat repair.
Looks like you could ride on that welder all the way to New Yawk Citty!
Victor 57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas |
03-13-2016, 03:06 PM | #943 | |
Re: Rat repair.
The driver floor is pretty much welded in now, i have been fighting a few bouts of porosity that i think maybe my heat and feed were too high, i have turned them down, it seems to be better, now i need to go back over some of the spots with a light under the truck to insure no pin holes are present. Question: seam sealer before epoxy primer or after?
03-13-2016, 03:21 PM | #944 |
Re: Rat repair.
After. Always best to get the epoxy on the bare metal first since it's your last line of defense against moisture. The seam sealer will adhere to it just fine.
Everything is looking great! Having lived up there for almost two years I know all about the weather you're dealing with. Kudos for hanging in there.
03-14-2016, 12:25 AM | #945 | |
Re: Rat repair.
03-14-2016, 06:14 PM | #946 |
Re: Rat repair.
No kidding! Remember my brother-in-law Rick that lives up by Seabeck and came down with me to see your truck? This is his backyard and his brand new car. If I'm not mistaken, it's the ONLY new car he's ever bought - and may well be the last.
03-14-2016, 09:52 PM | #947 | |
Re: Rat repair.
I used to think nothing of the wind when i lived in eastern Wa but around here i have had a change of opinion, watching these trees come down where you live is kinda spooky especially the big ones.. http://www.king5.com/story/news/loca...erry/81751312/ Nothing done today.. just rest.
03-17-2016, 11:13 PM | #948 |
Re: Rat repair.
Hi again swamp rat, awesome progress on the truck. I also like the upgrade to the welding cart, its awesome. I been thinking about getting the cart, and now I'm thinking about doing the same thing.
03-17-2016, 11:52 PM | #949 |
Re: Rat repair.
Fair warning on that cart its not super heavy duty as far as the structural support on the upper front corners of the cabinet right above the top drawer corners, it can bend a bit in shipping from side load, i had to return the first one i ordered and had UPS'ed because my local H/F was sold out when they were on sale, and the bottom where the gas bottle sits has a slight bend to it now, absolutely meant for the cement floor, i have been a little rough on mine i guess.
Thanks for the comps! Not much to report but i cut down the cab reinforcement and reworked it on the passenger side so i can get into the driver side better and finish it up.
03-18-2016, 01:58 AM | #950 |
Re: Rat repair.
Thanks for the info on the cart, mine will probably be in my shop mostly. I do have a nice cement pad outside in front of my shop thought about 18x24.
Here's some cool tools eBay item number 322040819339 |
