06-18-2020, 08:17 AM | #926 |
Re: A '54 named Busty
Nice work on the LS swap, and the to do list is getting shorter.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
06-18-2020, 08:50 PM | #927 |
Post Whore
thank you appreciate it, so want to go work on the truck but it's hot as hewk up here, went to Ace Hardware and they were shutting the doors at 5:30 PM today, John the owner knows me by name (cause I buy all my hardware one nut and bolt at a time from him, ha ha) says I couldn't let you in without a mask anyway, new law, the Governor just signed it!
06-18-2020, 08:57 PM | #929 |
Post Whore
tunnels must we make for the injector wiring harness to run under the intake hidden like
06-18-2020, 09:01 PM | #930 |
Post Whore
forgetting to block off the brake booster vacuum port on the back of the intake is guaranteed to make a spectacular vacuum leak
soon we shall upgrade to power brakes for now this is just to ensure proper startability |
06-19-2020, 10:11 PM | #931 |
Post Whore
Progress not perfection!
reluctantly I had to notch the upper radiator frame to move the radiator up a little bit for the upper rad hose to clear the top of the fan |
06-19-2020, 10:13 PM | #932 |
Post Whore
I gotta admit I am in full on Git 'er done! mode
06-19-2020, 10:14 PM | #933 |
Post Whore
I got some mystery lower radiator hose to work absolutely perfectly after trimming it a bit and installing the swivel thermostat housing/neck
06-19-2020, 10:16 PM | #934 |
Post Whore
can you believe this jazz? as if I could hate California even more than I already do!
06-19-2020, 10:26 PM | #935 |
I think the heat is getting to you, the upper hose shouldnt be plumbed to the oil fill, unless you are steam cleaning the inside.
your random lower hose looks a lot like the one I use on my swaps, same bends. you can ship that intake to me and I PROMISE to forward it on.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
06-20-2020, 12:10 AM | #936 | |
Post Whore
I bet! |
06-20-2020, 11:28 AM | #937 |
Post Whore
well since my Summit exhaust manifolds aint supposed to ship till middle of next month, I decided to take matters into my own hands and resurrect this ol' project from my other LS Swap
06-20-2020, 11:11 PM | #938 |
Post Whore
then it was time to manhandle the driver side exhaust manifold
06-20-2020, 11:14 PM | #939 |
Post Whore
took to it with such surgical precision that would make a German engineer cringe
06-20-2020, 11:16 PM | #940 |
Post Whore
Part Numbers? we don't need no stinkin' part numbers!
06-20-2020, 11:20 PM | #941 |
Post Whore
alright then, but how do they fit?
well the passenger side just barely clears the frame, we are talking about 3/16ths of space the driver side has a plenty of room |
06-21-2020, 06:41 AM | #942 |
Meanwhile in Flangestan, Gregski is going all under, Unforging new Frontiers. Under achieving is in....Film and ride along at 11...... Seriously, way to keep your project going...
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
06-21-2020, 09:22 AM | #943 |
Post Whore
06-21-2020, 12:13 PM | #944 |
Grate work on the exaust parts.
06-21-2020, 12:28 PM | #945 |
Post Whore
06-21-2020, 01:05 PM | #946 |
this is actually brilliant, now you can use sewer clamps! just kidding. my friend greg (not you, another greg) was having trouble installing his manifolds on his 52 and I told him about cutting and welding cast steel, I will show him your progress.
06-22-2020, 10:31 AM | #947 |
Post Whore
now there's an idea, well fingers crossed
06-22-2020, 10:32 AM | #948 |
Post Whore
I don't usually do LS Swaps,
but when I do... I prefer for it to be scorching hot! |
06-22-2020, 10:48 AM | #949 |
That’s not even that hot for Sac in the summer!
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
06-22-2020, 10:54 AM | #950 |
Post Whore
Right you are, I was just sayin'
