10-17-2012, 09:59 PM | #951 |
A guy with a truck
Re: How to: Ruin a perfectly good C10
Got one side of the front brakes done today--the drop spindles require much less material to be removed than the stockers.
Last look at the D52 'ears' Carnage! Sawzall and a grinder made quick work of it. Also drilled out the backing plate bolts and tapped them to 1/2-13 Painted the cuts and installed the mounting bracket and hub ...and complete. The paint will wipe from the rotor face at first application. Also installed one of the braided lines I got from Kore3. They are nice pieces, custom made to my specs for length and fittings, and are a matching set of 5 with the rear drop and caliper lines... Posted via Mobile Device
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
10-17-2012, 10:15 PM | #952 |
Truck and auto performance nut
I guess I missed it. What rotors/hubs/brackets are you using there?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
10-17-2012, 10:25 PM | #953 |
A guy with a truck
The hubs and brackets are from Kore3--they adapt 13" C5 rotors and calipers. Paired with the CaptainFab rear discs, I hope this thing will STOP
10-17-2012, 10:36 PM | #954 |
cool....and thanks!
10-17-2012, 10:38 PM | #955 |
A guy with a truck
Also cut up a poly bushing to fit the front of the upper shocks to the CPP extenders. Lopped them in half and took about 1/8" off and they fit perfectly
10-17-2012, 10:40 PM | #956 |
A guy with a truck
Wheel on--it's coming together...
10-17-2012, 10:45 PM | #957 |
Brakes look really good, I don't think you will have any problems stopping now.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
10-18-2012, 07:21 AM | #958 |
nice mods bud !!!
check out my build thread 71 c/10 step side 5.3 twin turbo http://67-72chevytrucks.com/vboard/s...d.php?t=485320 raul |
10-18-2012, 08:05 AM | #959 |
67cheby
Sweet !
Posted via Mobile Device |
10-18-2012, 10:59 AM | #960 | |
Thanks, buck |
10-18-2012, 11:36 AM | #961 | |
A guy with a truck
Thanks! Thanks for taking the time--now get back on yours--SEMA is in a few days... Call PB--they should have come with your arms if you're using them with a stock crossmember. I think they are set up for use with a Dropmember unless you specify otherwise...
10-18-2012, 11:50 AM | #962 |
I am patiently waiting on the 1" forward lower a-arm install. Want to see how much they actually move the wheel before I pull the trigger. Great truck and write up!
10-18-2012, 04:16 PM | #963 |
A guy with a truck
Coming soon! I figure the wheel will move forward around a half inch or so, due to the position of the spindle between the balljoints--would probably be a little more with stock height spindles... I'm excited to get to that part as well, for not only the looks, but also the driveability. Thanks for the kind words and welcome to the forum
10-18-2012, 04:54 PM | #964 |
Looks killer brother! Great job. I'm hoping my McGaughys turn out half this nice.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
10-18-2012, 05:37 PM | #965 |
Great job it looks great!!!!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
10-18-2012, 05:51 PM | #966 | |
A guy with a truck
Thanks! The first one took a few hours longer than anticipated--hopefully have the pass side wrapped up soon... Posted via Mobile Device
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 10-18-2012 at 10:03 PM. |
10-18-2012, 06:17 PM | #967 |
Nice to see you back at it, those brakes look good! You almost have me convinced to do it.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
10-18-2012, 10:02 PM | #968 | |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 10-19-2012 at 06:17 PM. |
10-19-2012, 05:53 PM | #969 |
I love this truck! I'm glad I re-stumbled upon this thread again. Awesome progress!
10-19-2012, 09:22 PM | #970 | |
A guy with a truck
Update: WHOLLY SHNIKEYS! This. Thing. STOPS. After assembling the passenger side, I took her out to rub the paint off the rotors and bed the Hawk HPS pads. The initial impression was a bit lackluster, but I continued with the recommended break-in, then let them cool. Went back out for a follow-up and WOW! These things have some serious bite and the firmness and responsiveness of the pedal feel reminds me of my old C5 'Vette. I may need shoulder harnesses to keep from bouncing my passengers' faces off the dash Amazingly, this is with basically no rear brakes at all--when I went to bleed the fronts, I found the rear reservoir empty--I've known for some time that I had a leaky wheel cylinder, but was putting it off until I got the rear discs swapped in. I dumped a little fluid in, but did not bleed the rears, so their contribution to braking is questionable at best. No matter, the fronts lock up with ease. It has gone from 'push-and-pray' to 'don't push too hard' Can't wait to see what four-wheel discs feel like Pic, 'cause you can't have an update without one... Posted via Mobile Device
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 10-19-2012 at 09:30 PM. |
10-19-2012, 10:24 PM | #971 |
67-72 parts collector,…
I think your truck deserves some fender emblems.
Maybe a set of Custom emblems. Not Custom/10,... just Custom,... cause it is so cool. Love the brake upgrades.
10-20-2012, 12:25 AM | #972 | |
A guy with a truck
10-28-2012, 11:49 PM | #973 |
I have a couple of quick questions. I checked on Kore3's site and those appear to be the hubs for the GM tall spindle? Is that correct? Forgive me if I missed it in a previous post, but what spindle are you using? Is that 5x5 or 5x4.75 bolt pattern? Thanks
11-03-2012, 09:27 PM | #974 |
A guy with a truck
Hey, sorry I missed this before. They are technically made for the B-body cars, specifically Impala SS. The spindle shaft is the same on the 'tall' spindle, late '70s F-bodies, big cars, and light trucks, which is the spindles I have (1" thick rotor Belltech 3" drop). The hubs can be had in 5 or 4.75--mine are 5, just 'cause I already had wheels. Kore3 also offers hubs for the 1.25" thick HD truck rotor spindles, though not on their website. Member Scoti has this setup somewhere in his pile o' parts...
11-03-2012, 09:40 PM | #975 |
A guy with a truck
Minor progress today--started assembling the CaptainFab D52 rear disc brakes. QUALITY components. Putting them together was pretty straight-forward, so I'll save you guys the gory details.
Of note: I cut off the backing plate on the driver's side and found that it is not a whole lot easier than just pulling the axles--oh well, live and learn Also found my massive wheel cylinder leak that had everything inside the drum soaked; the brake shoes literally fell apart when I pulled the drum... Before, carnage, and tear-down pics:
