Old 01-15-2013, 01:14 PM   #951
99 to Life
99 to Life's Avatar
Re: Daverods 52
then you'd need a stencil either hand cut or someone with a plotter can do it. like a sign shop or vinyl specialty shop. if you send me your logo I can see what I can do.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 01-15-2013, 02:09 PM   #952
OrrieG
OrrieG's Avatar
Re: Daverods 52
On TV I have seen Foose sent out some pretty complicated graphics to sign shops to make a die cut stick on. Similar to a car wrap, sticks with static to metal. paint and peel layers to get the final design. Local sign shop here has 24 hour turn around on small stuff like door size.
OrrieG is offline   Reply With Quote
Old 01-15-2013, 03:18 PM   #953
99 to Life
99 to Life's Avatar
Re: Daverods 52
yeah I know a guy that could cut out vinyl too if you need. but odds are someone local can do it for you.
Old 01-15-2013, 03:22 PM   #954
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
That's what I was thinking. But I guess I just went to the wrong place.
daverod is offline   Reply With Quote
Old 01-22-2013, 09:35 AM   #955
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Roads are still messy. Do have the truck all jacked up. I've been running it at different heights to see how everything works. Couple problems. When its all the way downs the tires really heat up the fenders and cause lots of smoke. Also when it's up any more than about 4" the driveline hits the exhaust alittle. I don't think I will run it that height but... right now with it on jacks the diff doest move the way it would when its on the ground.. Might have to bend or move it a bit. Have to make some braces to hold my fenders out alittle. Clearance it close about a 1/2". My rad fan and sender all works no heat problems. Power steeering works good... no leaks. Brakes workbetter after unkinking the hose going to the booster. Welded some stuff with the batt hooked up on the truck. That can't be good? Did have a blown headlight fuse?
Old 01-22-2013, 10:22 AM   #956
99 to Life
99 to Life's Avatar
Re: Daverods 52
well I'm all ears on your problems, I'll probably run into suspension issues on my next build. Atleast exhaust can be altered and moved. Did you hook your temp sender from the original gauge up? Or you running aftermarket?
Old 01-22-2013, 03:34 PM   #957
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
I bought a new old temp gage and oil gage. I'm thinking I can bend the x pipe aliitle to close. The yolk moves out quite abit when I go all the way up. Somthing I never really thought about. I was worried about stuff hitting when everything was down.
Old 01-22-2013, 05:36 PM   #958
99 to Life
99 to Life's Avatar
Re: Daverods 52
cool, glad you kept the old original look. Did you set your pinion angle at your desired ride height? ex. 4" off ground then set your pinion angle? From there, I wonder how much play should be in the driveshaft, I'll have to find out on that cause seems like it should have some room to go in and out like your saying.
Old 01-22-2013, 08:30 PM   #959
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
I set everything at ride height. At that height the yolk was about 1" out. With the 3 link the diff angle changes a lot as you move things up and down. I think I broke my speedo. It started bouncing a lot then nothing.
Old 01-23-2013, 11:05 AM   #960
Strodder
Daring to be Different
Strodder's Avatar
Re: Daverods 52
It probably FROZE.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 01-26-2013, 04:14 PM   #961
sweet70beast
sweet70beast's Avatar
Re: Daverods 52
The speedo will bounce a lot when the cable inside needs lubed up. It might have broke or seized.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 02-05-2013, 11:01 PM   #962
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Could'nt stand it any more. Torn open the garage door and took the little truck for it's first spin. Did'nt go to far. Lots of backing up and turning, Got it to go into 3rd. Turned kinda funny like it was pushing. When straight good. Still need to do a lot ie ..bed mounted better,, tv cable throttle cable. but now I want to drive it even more. Motor sounds good temp ran at 185 190.
Old 02-05-2013, 11:04 PM   #963
bubba327
HOW long until spring??
bubba327's Avatar
Re: Daverods 52
are you pushing snow over the hood???
Ground hawg day was Saturday!!! I am ready for SPRING!!
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 02-06-2013, 09:44 AM   #964
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Roads are clear here. Time to burn some gas. I'm ready for spring too. Just bought a new bow. Big hairy things are going to die soon. I can see it now little lowrider with big old fat but bear stuffed in the bed. Draggin ass all the way home.
Old 02-11-2013, 12:54 PM   #965
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Re: Daverods 52
Hey it was beautiful here on sunday.....I opened up the shop and had my 58 out most of the day....it was cold but clear and it felt awesome to turn some tire. It recharged me for more work on my 66 low and go.....lol. So i understand excatly what your saying....awesome when things move and the roads are clear.....good on ya man.
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 02-15-2013, 09:12 PM   #966
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Been cutting out of work early just so I can run home and go burn around in the 52. Going further and further away from home. Still havent hit the hyway. Had to adjust the front wheels had one that was way cock eyed. Did get it up to about 50 and tested out the overdrive. Now I want a 700r4 in my 64. Did manage to hit the wrong buttons a few times and dumped it driving down the road.haha. Or the stupid dog standing on the switch box. Tires rub on the top of the fenders sometimes when I'm real low and the front is way up. Burned some of the paint off the fenders. Wife is gone for awhile so I don't want to take it too far and have something happen. So far everythings good. I'll get some pics and maybe a movie tomorrow. Posi works good. My drive way has proof. My diff. does'nt move around like it does in my 64.
Old 02-16-2013, 06:49 PM   #967
Strodder
Strodder's Avatar
Re: Daverods 52
Awesome Dave.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 02-16-2013, 08:26 PM   #968
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
PVC valve started to make a tic tic sound. Had me worried till I figured out what it was. Maybe bad? Throttle petal was'nt letting it open all the way up. Big hammer a vise fixed that. Somewhat fast now.haha wider tires and more weight in the back would be a good thing.
Old 02-17-2013, 08:08 PM   #969
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Drive drive tinker tinker drive drive drive burnout rockstar Life is good. Lighting sucked but you get the idea. Poor 64 will never get driven again. 2 years almost to the day from when I bought it till it hit the road again. Another 2 and I might be done.
Old 02-17-2013, 08:27 PM   #970
padresag
Re: Daverods 52
what are you wearing in the picture, a dress?
ron
padresag is offline   Reply With Quote
Old 02-17-2013, 08:50 PM   #971
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
yes... it was a dress. you're supost to be looking at the truck smart a$$. Just the sun playing tricks on your old eyes.
Old 02-17-2013, 09:03 PM   #972
padresag
Re: Daverods 52
after all of the old stuff of bygone days, I figured that it may have been a subliminal message of some sorts. why is the truck sitting on the ground , did you take a torch to the springs or something. the truck seems to be in pretty good shape otherwise
ron
Old 02-17-2013, 09:34 PM   #973
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Ur crackin me up. Ya I torched some things. Filled the cab up with Habor Freight shipping pads. Two on the floor one in each door and five behind the seat...oh and a couple on the seat under the cow hide. Somewhat quite now..
Old 02-17-2013, 09:43 PM   #974
xpickup
xpickup's Avatar
Re: Daverods 52
daverod, Truck looks great. I love the patina.
Shannon
xpickup is offline   Reply With Quote
Old 02-17-2013, 10:27 PM   #975
padresag
Re: Daverods 52
are you using that frt bumper to keep the snow off the driveway? is that why you have it that low. the 64 looks driveable.
fine looking pair of vehicles
ron
