09-26-2006, 10:08 PM | #76 |
Questionable
Re: my official 68 shortstep ls1 thread (lots of pics)
I'm using the stock manifolds from the car listed.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
09-26-2006, 10:57 PM | #77 |
Questionable
Here's a shortcut way to add a manual temp gauge :
http://ls1tech.com/forums/showpost.p...8&postcount=54 Lots of pictures.
09-26-2006, 11:39 PM | #78 |
Nice work so far 68 shortstep! Keep the pictures coming.
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
11-04-2006, 11:49 PM | #79 |
maken a little progress.... got a electric dual fan im maken mounting brackets for, and modding to fit my rad... also plumbed up the rad to the overflow can.. and plumbing up trans to cooler...
11-04-2006, 11:51 PM | #80 |
also got my wheels in they are foose nitrous 20s on rear and 18s on front
11-05-2006, 12:02 AM | #81 |
wow, I need my sunglasses for those...very nice
11-05-2006, 01:06 AM | #82 |
Questionable
Man, those things are huge looking!
Funny you got the fuel lines out. I was sposta work on them today, then a friend called and was stuck in between floors in his house (fell through the cieling while working on the subfloor upstairs). That ate up a lot of the day, then I came home and shot myself in the eye with Brake Cleaner. That put me out of commission for another hour, and by then it was dinnertime Looks like you got your lines going well. I'd post the PDF of how to make em, but looks like you got the hang of it already
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 11-05-2006 at 01:08 AM. |
11-05-2006, 10:34 AM | #83 |
just looking at the overflow tank for your rad, i have a 400ci smallblock and the rad just has a overflow pipe draining on to the fllor if it overflows, is that not right then
11-05-2006, 10:38 AM | #84 |
The LuvShack Garage
NICE
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
11-05-2006, 12:56 PM | #85 | |
Questionable
This is the stock setup. Normally, the overflow tube will come out of the radiator, clip onto the side of the battery box and just pour to the floor. In theory, when your radiator heats up, pressure develops against the spring loaded rubber cork inside the cap, and when it hits a certain PSI (should say on the cap), the rubber cork is pushed up, allowing water to flow into the radiator. I read recently that the radiator should be able to push/pull water from your resevoir when needed. Still not sure how that works with pulling the water back out of it though. So, I guess, ultimately the answer is "yes, no overflow tank is normal", but a lot of the guys add them on here.
11-05-2006, 02:02 PM | #86 |
It's looking good. Coming around.
11-05-2006, 03:38 PM | #87 | |
When water heats up it expands, when it cools it contracts. This contraction creates a vacuum on the resevoir and pulls some water back into the radiator. At least that's how I think it supposed to work.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
11-05-2006, 04:06 PM | #88 |
where can i get one of those overflow tank/tubes????
11-05-2006, 04:46 PM | #89 |
Questionable
I understand how the head + pressure trips the cap/plunger to flow water out of the radiator, I just don't understand how the vacuum after cooling trips the cap/plunger to suck water back in.
11-05-2006, 05:05 PM | #90 |
The Hammer Man
Quick question... the trailing arms and springs you have in the back.... are they stock? maybe dumb question but i have the same set-up on mine and wasn't sure if they are stock or not. i'm just getting to know my truck after 3 years of driving it.
Boise69. Bought in Boise ID and its a '69 ___________________________________________ 1969 Chevy C-10 SWB 350/400 - drivable project www.americanhammer.com 2013 MBZ Sprinter customized 2005 MBZ Sprinter Van 2004 Land Rover Discovery 2001 Yamaha Road Star 1997 MBZ E420 1989 Ferrari Mondial T |
11-05-2006, 08:08 PM | #91 | |
the tank needs to be only halffull the air in the expensiontank gets compressed when the exess water enters it and pushes the water back intoo the system when it cools back down again . the expensiontank itself has a blowoffvalve in the cap too but that only works in extreme cases to prevent the tank from blowing up the only reason to put a tank at the exit end of a blowoff cap is to preserve nature by catching the exess fluid instead of dumping it on the road
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
11-05-2006, 08:23 PM | #92 |
11-05-2006, 08:24 PM | #93 |
yes the trailing arms are stock, springs came in the ECE 6" lowering kit
11-09-2006, 01:12 AM | #94 |
It's coming along nice good job.
My Official build thread http://67-72chevytrucks.com/vboard/s...d.php?t=196844 |
11-09-2006, 02:05 AM | #95 |
Sb 400 club
WOW great build up gonna be one killer stepside when done
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
11-09-2006, 01:54 PM | #96 |
How are you wiring up the motor, and comp? I have a 6.0 and want it in my 68 short stepper. Love the biuld-up, been watching this and shifty's as well. When you guys finish I should be able to just whip through mine with all of the experience I have gained here!!
11-09-2006, 02:06 PM | #97 |
Questionable
Nope, you'll run into your own unique problems. There are a lot of little things that both of us have left out (me, on purpose, or out of laziness) that you'll need to figure out. that's why I pity the person who ever tries to consolidate this info and sell it on eBay as a swap howto (hello, negative feedback! )
What do you mean by "how are you wiring up motor and comp"?? That can be taken many ways - you mean, how are the wires ran, where are you mounting the comp, where did you get the harness, ????
11-09-2006, 08:30 PM | #98 | |
BTW i met boyd in rockwall TX at a car auction i was attending, i thought he was a jerk, but i can say i met him... |
11-09-2006, 09:01 PM | #99 | |
i wouldn't like to work in his shop no matter what they would pay me
11-09-2006, 10:46 PM | #100 |
Great build so far!! I noticed the A&P manual, are you working general or commercial av? I was an AP in my former life, prior to 9/11.
Keep up the gr8 work
___________ Greubin '71 C20 custom - GM Crate 350CI/290HP, BTO 700R4 level II, Qjet, and HEI |
