Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 05-10-2010, 03:38 AM   #76
Billhilly
Billhilly's Avatar
Re: 41DegreesSouth Build Thread
No, not going to make my own park brake. Just moving it over to the proper side! Need to get started on the rust now.
1972 K2500 Long Box
400/350
Billhilly is offline   Reply With Quote
Old 05-10-2010, 01:51 PM   #77
Beelzeburb
Devil's in the Details
Beelzeburb's Avatar
I was just looking at post #53 with the rear brake components all hooked up. Are those calipers on the right sides? It looks like the bleeders are below where the flexible brake hose attaches to the caliper. Usually that means you won't be able to properly bleed all the air out of the system, compared to having the bleeder at the top where the air can escape when the bleeders are cracked.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread
Datsun 240Z, 510 2 door and an old Honda motorcycle
Beelzeburb is offline   Reply With Quote
Old 05-11-2010, 08:49 PM   #78
Billhilly
Billhilly's Avatar
Good spotting on the calipers. I choose to run them that way to put the ebrake cable up on top out of the way. Hopefully it won't be to much problem to release the cables, turn the calipers and bleed them, then reinstall. Well that's my story anyway!
1972 K2500 Long Box
400/350
Old 05-12-2010, 10:51 PM   #79
Evanz67
All i can say is WOW! and i thot my project was a lot of work. Nice build man cant wait to see it done!
Evanz67 is offline   Reply With Quote
Old 10-04-2010, 03:42 PM   #80
Billhilly
Billhilly's Avatar
Thanks Evan.
Some photo's for 6772owner. Just to confirm, headers are Headman 69830's. Looks close, but I think it'll be ok. I used 2 1/2" pipe. And you could route the pipe slightly away anyway.
1972 K2500 Long Box
400/350
Old 10-04-2010, 04:06 PM   #81
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Those look like good headers, I need to find some I like. Does the coating look like its going to hold up good?
Any progress on the truck?
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 10-04-2010, 04:08 PM   #82
6772owner
Gearhead
6772owner's Avatar
Thank you very much for the pics, that helps me out tremendously!
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 12-13-2010, 10:42 PM   #83
swamp rat
swamp rat's Avatar
Its been a while, Updates??
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-14-2010, 12:54 AM   #84
dammitmitchell
the pollock
dammitmitchell's Avatar
HEY it's your summer why arent you building?
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 12-18-2010, 09:57 PM   #85
Billhilly
Billhilly's Avatar
You guys are absolutely right, I'm slacking down here. It is summer and I should be working on my truck! Seemed to be a long winter, well thats my story. I have done a little more, and have big plans for the next month.
I have finished up most all of the conversion work on the firewall and dash. Everything is pretty much welded up as well. I had to get the park brake deal sorted out, but it ended up ok I think.
Going to mirror the firewall corner and blank off the blower vent (with Nate Porter's patch's), then that should nearly wrap up the firewall work.
1972 K2500 Long Box
400/350
Old 12-18-2010, 10:17 PM   #86
Billhilly
Billhilly's Avatar
I have been working on the inside as well. The dash/glovebox deal is all welded up. Old Air is mounted (just needs final spot welding of supports), and I am working on mounting the gate that controls hot air to the windscreen/feet. The Old Air box only has one outlet for hot so I am going to modify the origonal gate deal to work RHD.
I have also mounted up my MSD box and timing controller. Didn't want it in the engine bay so made up a plate to mount them in the back of the glove box. Will probably put my fuse box in front of the ignition as well. I brought the timing controller because I am going to run propane/petrol. Not really the answer but I own it now so may as well put it in.
So I want to get the heating/cooling sorted out then that will pretty much finish under dash except for the fuse box/wiring. That will leave wipers as the main thing left to convert over I think. Oh, and I swaped over the ignition/lighter and finished up welding the brake pedal brace panel deal.
The rust is now the main project. I just bought in a small box of bit's, including the last couple of patch panels I needed. (Thanks Wes!). My kids left Wednesday for four and a half weeks in Ireland with their Mother so I am home alone! I am self employed so will work right through the holidays, but hopefully besides breakdowns, most of my clients will stay away anyway. I am really hopeful of setting aside some time and making a good start on rockers, cab supports, rear cab corners, well you all know the routine! So no excuses really. I need to watch Earl's DVD's again and get after it!
1972 K2500 Long Box
400/350
Old 12-18-2010, 10:48 PM   #87
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Its coming along really nice! Keep the pictures coming!
Tony
Old 12-18-2010, 11:07 PM   #88
67chevy1series
67chevy1series's Avatar
now you just need to fill in the round hole and remake that part of the fire wall so you can put the e brake
67chevy1series is offline   Reply With Quote
Old 12-18-2010, 11:15 PM   #89
spike38
spike38's Avatar
A right hand drive C10? hummmm
Interesting build, I'll be watching this one.
Spike
spike38 is offline   Reply With Quote
Old 12-18-2010, 11:27 PM   #90
swamp rat
swamp rat's Avatar
Great work! Glad i could help motivate you to post some updates, you know how it is, the forum seems to slow down a bit this time of year.
EDIT: Got the DVD on my christmas list this year, i hope i get it..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 12-19-2010, 01:53 AM   #91
67chevy1series
ya it sucks i love this site and theres nothin this time of year to do because of rain so i am just on here and when i have looked at everything and theres nothin i jaust get bored
Old 12-19-2010, 02:10 AM   #92
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
I think after I win the lottery im going to move to New Zealand during the winters so I never have to be in the cold.
Tony
Old 12-19-2010, 02:39 AM   #93
67chevy1series
Old 12-19-2010, 02:46 AM   #94
Billhilly
Billhilly's Avatar
I was going to make some comment about how I thought it never got cold in Texas, but I just checked your weather report and it says your current temp is 2.7C. Thats coolish I guess.
1972 K2500 Long Box
400/350
Old 12-19-2010, 02:47 AM   #95
67chevy1series
well any progress
Old 12-19-2010, 03:41 AM   #96
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Well its cooler than I like but the next week or so should be pretty warm.
Tony
Old 12-19-2010, 07:06 PM   #97
dammitmitchell
the pollock
yeap im running around barefoot today.. in texas.
but it was below freezing a few times here. but hey.. im liking the warm this "winter"
Army vet 02-08
Old 12-20-2010, 04:03 PM   #98
tomtuna1978
rhd ! im watching this one !!!
tomtuna1978 is offline   Reply With Quote
Old 12-27-2010, 08:38 PM   #99
Billhilly
Billhilly's Avatar
Hope everyone survived the Christmas break. I decided to skip work and start on the rust. Started on the left side cause if it don't turn out so good I won't see it getting in the truck!
Usual stuff, front cab support half gone, rear completely gone. Bottom of A and B pillers gone. Kick panel and floor area, plus rockers and cab corners. So I got it cut out.....now what!!
Going to be an interesting afternoon! What did he say, 'I didn't lose my mind, it was mine to give away!'
1972 K2500 Long Box
400/350
Old 12-27-2010, 10:48 PM   #100
swamp rat
swamp rat's Avatar
Now ya got my attention again.
Question tho is it more of an illusion or did the rear of the cab spring out at the door jam when you removed the rocker?
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
