Old 07-18-2010, 02:43 PM   #76
yukon ratrod
yukon ratrod's Avatar
Re: Chevyrestoguy's '55 build
im blowen away! dont know what else to say. its stuff like this that never gives me a chance to finish what I start. Trucks looking great and Im glad to see your making great progress. some day I will get back to work on mine I hope. rebuilding a 48 chevy truck for a friend and really fighting with door gaps. cabs been flopped on its lid or something, everything is fighting me and preventing me from getting back to mine. keep up the great work.
yukon ratrod is offline   Reply With Quote
Old 07-18-2010, 02:57 PM   #77
Kabwe
Certified Car Nut
Kabwe's Avatar
Looking great man. I'm glad to see you are posting again.
Kabwe is offline   Reply With Quote
Old 07-18-2010, 03:59 PM   #78
Kim57
Kim57's Avatar
Very cool stuff.
Kim
Kim57 is offline   Reply With Quote
Old 07-18-2010, 08:07 PM   #79
Fat Mike
Fat Mike's Avatar
That is a heck of a setup! Wow!! Keep up the goog work. I always look forward to new pictures.
Fat Mike is offline   Reply With Quote
Old 07-18-2010, 11:08 PM   #80
CAL 58 GMC
CAL 58 GMC's Avatar
Looks cool! Nice job!
CAL 58 GMC is offline   Reply With Quote
Old 07-19-2010, 03:57 PM   #81
kustombrad
kustombrad's Avatar
I need to get out to Mikes and check it out. It looks awesome!
It's all about the stance, baby!
http://67-72chevytrucks.com/vboard/s...d.php?t=320546
kustombrad is offline   Reply With Quote
Old 07-31-2010, 01:58 PM   #82
hotrod1
56 - autocross
hotrod1's Avatar
I love beautiful metal work. It is a motivation to us all. Keep up the great work.
I am anxious to see where you are now.
hotrod1 is offline   Reply With Quote
Old 08-01-2010, 01:37 PM   #83
chevyrestoguy
chevyrestoguy's Avatar
I'm super-busy at work right now, so I haven't had any opportunities to go to the shop, but Mike has been busy building the bridge that will tie in the forward crossmember, mount the shocks, and secure the fuel cell. here's some progress pictures:
You can see the shock mounts in this shot. The suspension is currently set at the full-up position, so you can see that the shocks are compressed with zip-ties. You will also notice that the old shock crossmember has been removed, as has the old rear crossmember that supported the back of the old fuel tank.
Rear corner shot looking forward
Rear shot looking forward. The tubes have a nice flowing shape, and in this shot you can see the fuel tank cradle. The square section of tubing just aft of the rear axle will house the battery. We've already designed up a cool battery box that will serve some other functions as well.
Here's a shot of the gusset I was telling you about in the earlier post. There will also be a triangular gusset on the forward side as well. It will be smaller to allow the cantilever arm to articulate forward without any interference. The aft side of the arm was also cut away a little more than before to allow sufficient clearance for the arm to travel fully.
The plan is to finish plating and boxing, and do the final welding on Friday. Also, the upper wishbone is going to have some sheetmetal work done at the attach point by the rear axle housing in the next day or two. That will clean up the intersection where the tubes and Uni-Ball meet. You'll like those pictures because Mike's Tig welds are insane....
chevyrestoguy is offline   Reply With Quote
Old 08-01-2010, 09:44 PM   #84
W.C. RoDz
W.C. RoDz's Avatar
That rearend looks great!..Can't wait to start mine..I needed a boost work has been killing me!
W.C. RoDz is offline   Reply With Quote
Old 08-01-2010, 10:48 PM   #85
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
That's what a professional does! Wow, great job, I guess you won't have a bed floor since those tubes are arching like that? This is very inspiring.
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 08-01-2010, 11:03 PM   #86
CAL 58 GMC
CAL 58 GMC's Avatar
Very nice work!
Old 08-04-2010, 09:43 AM   #87
chevyrestoguy
I took yesterday off because we were having some work done on the house (complete septic system changeout........lovely), and after the work was complete, I ran over to the shop and saw that Mike had been a busy boy.
He was welding up all of the chassis, and I was able to grab this one and get some pictures of it while it was still hot. He did a LOT of welding on the cantilever arms.
Another shot of the arms, with this one showing the airbag mount.
Here's the finished wishbone, with the dimple-died sheetmetal plate. It's .125 plate, fully welded. I wanted a curved front edge so it wouldn't look so triangular, and I think it turned out awesome.
Close-up shot of the welds. That piece is now super-strong. My only concern right now is how I'm going to paint (or powdercoat) the chassis without burying all of those bad-ass welds.
Here's a shot showing the finished arm with an airbag (Slam RE-8) installed. The gusset and bag mount have also been welded fully. I ran it through full-up/full-down and it operates perfectly. No binding or squeaking, and zero slop.
The next plan is to bolt everything up, run temporary air lines (I'm plumbing it with stainless hard-line later) and cycle the system.
Old 08-04-2010, 09:52 AM   #88
Kim57
Kim57's Avatar
Very slick looking stuff.
Kim
Old 08-04-2010, 03:53 PM   #89
sgtusmc
sgtusmc's Avatar
You could clear powdercoat the parts.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 08-04-2010, 05:39 PM   #90
chevyrestoguy
Got to the shop early this morning and finished the temporary plumbing because it was killing me to see the truck on it's wheels and laid out.
I love it. It has a rake to it when it's laid out, and that's exactly the effect I was hoping for. The next plan is to get it back home where I can do some more fab work. I really want to mount the bed and figure out new attach points because all of the original points have been covered up by all of the air-ride set-up. I've got some trick ideas for the bedfloor/tonneau. The days of this truck hauling anything in the bed are over.
It'll go back to Mike's in a month or two to finish the gas tank, air tanks, compressor mounts, and some finish welding on the hydroboost system.
Old 08-04-2010, 06:11 PM   #91
Fat Mike
Fat Mike's Avatar
Man that's a nice set up!! Really look forward to seeing more progress. Keep up the excellent work.
Old 08-04-2010, 08:11 PM   #92
Kabwe
Certified Car Nut
Kabwe's Avatar
It looks great man.
Old 08-05-2010, 07:36 AM   #93
OLDIRON69
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 09-09-2010, 11:29 PM   #94
kustombrad
kustombrad's Avatar
I went out and finally saw the truck in person and WOW!!!! It looks way better in person than in pics! Mikey is a true master of design and fabrication and Alex will have one very nice truck when it gets done!
Old 09-10-2010, 12:06 AM   #95
nebdrummer
nebdrummer's Avatar
subscribed... hurry up man! i wanna see more of your awesome work!
should be an awesome truck. you have a great mind for inginuity!
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit!
http://67-72chevytrucks.com/vboard/s...d.php?t=380212
nebdrummer is offline   Reply With Quote
Old 09-10-2010, 12:33 AM   #96
hotrod1
56 - autocross
hotrod1's Avatar
I need to learn to weld like that!
Old 09-10-2010, 04:36 AM   #97
GeorgeVale
That looks absolutely stunning, real top notch workmanship.
GeorgeVale is offline   Reply With Quote
Old 09-13-2010, 01:39 PM   #98
Fat Mike
Fat Mike's Avatar
Can you tell me what the lower link bar that the lower shock mounts attack to are? Flat or tube and what size metal is it? In the picture it looks like about 2" flate plate.
Old 09-13-2010, 07:41 PM   #99
solidaxel
solidaxel's Avatar
That is some REAL nice art work !!
When you go to the powercoater ask him about clear powder coat that he uses for candy colors. I did my A arms in clear and they came out really nice
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-13-2010, 08:45 PM   #100
Panelman55
Panelman55's Avatar
Ever thought about a tilt bed? Maybe one that works on air!!! That would let you show off the cool suspension.
In God We trust!!!
Panelman55 is offline   Reply With Quote
