Old 01-27-2009, 09:28 AM   #76
6600DURAMAX
6600DURAMAX's Avatar
Re: 67-72 BigBlock 4x4s! Pos pics info here.
Heres mine
468BBC I dont have any valve cover issues currently, but I have a new set of sheetemtal vavle covers that will not clear at all. So I am going with a hydro boost brake set up to solve that problem.
Truck is currently tore down to build pulling truck!!!!!!!!
1972 K5 Build - plans - LS3-6L80e-One Tons.....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 01-28-2009, 08:22 PM   #77
CTENTA1
Registered 1971 K5
So what about you 6600DURAMAX, did you have any trouble with youre hedders rubbing with the inner frame rails? And also what brand are those hedders?
By the way, Nice looking truck!!!
CTENTA1 is offline   Reply With Quote
Old 01-28-2009, 10:00 PM   #78
drbyrdman
drbyrdman's Avatar
Originally Posted by 6600DURAMAX View Post
Heres mine
what motor mounts did you use?? any spacers? I got poly mounts and the stock cross member and going to get the same oil pan you have there.
drbyrdman is offline   Reply With Quote
Old 02-02-2009, 02:06 PM   #79
6600DURAMAX
sorry it took so long to respond, but the Headers are Hedman but I do not have a part number. They do clear the frame but not by much, can barely get my fingers between the frame rails and headers but they do not even rub under the twisting of the motor
The motor is sitting on stock big block mounts in the stock location
hope this helps guys anything else just let me know, the motor is coming out in a couple weeks!!!!
Old 10-12-2009, 12:20 PM   #80
Wildstreak
"something witty here"
Wildstreak's Avatar
whats the best way to mount a bb in, I was going to order the DI4Yx crossmemeber or should I just look for a set of bb mounts for the sbc crossmember or replace the whole crossmember and where would I get those parts?
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 10-12-2009, 12:25 PM   #81
muscletrucks
muscletrucks's Avatar
DI4Yx crossmemeber
1972 GMC Sierra Grande 3/4 Ton 4x4
1970 Mercury Cougar XR7
1943 Farmall M
muscletrucks is offline   Reply With Quote
Old 10-12-2009, 12:31 PM   #82
Wildstreak
Wildstreak's Avatar
I was thinking the same thing but I like to make sure Im doing the right thing before jumping into the project... I dont want to or should say I wont be bashing or cutting my cab to make room for it.
57 chevy 4x4
68 burb 2wd:
Old 10-12-2009, 05:45 PM   #83
Yukon Jack
Post Whore
Yukon Jack's Avatar
You will probably need to move the engine forward a bit to make it fit. This thread has lots of good info on this subject.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-12-2009, 07:05 PM   #84
superchevy
Got big-block?
superchevy's Avatar
I used the DIY crossmember and it did not fit well...when I bolted it to the frame, it pulled the frame rails in...moving the engine mounts in by a 1/4"...I actually had to get the hot-wrench out and heat up the center of the crossmember, then use a porta-power to "spread" the frame rails back out to where they should be...stretching the crossmember at the same time.
I also installed a 2" body lift. I had to "clearance" the firewall for the HEI and tall valvecovers...as it is, I have about a 1/4" of clearance between the valvecovers and the firewall...I figure they will "self-clearance" when I get on the 468. I had to notch the frame a lot to clear the Corvette manifolds...so much so on the pass side, that I had to box it in with 1/4" plate to stiifen that part of the frame..(really wanted run those manifolds, lol).
Note: I did not move the drivetrain forward. I should have. Would have given more clearance all the way around.
Here are some pics
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 10-12-2009, 10:01 PM   #85
Wildstreak
Wildstreak's Avatar
has anyone else ran into problems with the DI4Yx crossmember?
57 chevy 4x4
68 burb 2wd:
Old 10-12-2009, 10:30 PM   #86
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
The DIY4X didn't clear my oil pan and the motor sat really low, which caused header clearance. I had Kurt send me an new one that needed to be welded together so that I can build to fit.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 10-12-2009, 10:36 PM   #87
Wildstreak
Wildstreak's Avatar
when I call to order it I guess Ill just tell them Im putting in a 454 and see what they have to say? and what kind of oil pan are you using, aka like an older truck 454 or out of a car?
57 chevy 4x4
68 burb 2wd:
Old 10-12-2009, 10:47 PM   #88
Chevy1TonFun
Grease Monkey
I am using a Moroso 20413
Good Luck!
Old 10-12-2009, 10:49 PM   #89
Wildstreak
Wildstreak's Avatar
do you think you would have had problems with a stock pan?
57 chevy 4x4
68 burb 2wd:
Old 10-12-2009, 11:14 PM   #90
Chevy1TonFun
Grease Monkey
Its hard to say what BBC pan clears the DIY4X Crossmember. Anyone else had any luck.
Old 10-13-2009, 09:41 AM   #91
superchevy
Got big-block?
superchevy's Avatar
It clears my pan by a 3/8". They need to raise the mounts a little and deepen the bend in the middle for better clearance. I see they have a new bolt-together crossmember...wish I had that one.
build thread
build thread
Old 10-13-2009, 07:46 PM   #92
Chevy1TonFun
Grease Monkey
I have the bolt together one and I still had issues.
Old 10-21-2009, 10:14 PM   #93
6600DURAMAX
I have the factory crossmember and there is no way I would have cleared the valve covers with the firewall without some "massagin" (beating with a hammer. I hate the idea also but it is not noticabel once the motor is installed. Not that that makes it an easy choice!!!
I did notch the frame rails so the headers had more clearance. The headers now slide in nicely from the top or bottom.
Belwo are some pics, in one of them you can see the notched frame. As you can tell from the pics BBC are a tight fit at the firewall. If I was to do it all over and had the time to mock everytihng up a couple times I would slide the motor forward about 1 1/2''. I would still have plenty of room between my pulleys and electric fans!
Old 10-21-2009, 10:17 PM   #94
6600DURAMAX
pics
Old 11-02-2009, 11:19 PM   #95
bser
Hi did my 71 gm k2500 20 + yrs ago, motor came from a 68 chevelle.
used this oil pan and put on the sb mounts. used a set of chevelle headers that cleared the frame rail, then switched to 68 camaro exhaust manifolds that easily clear the frame. Had to dent the firewall in about 1/2 for hei clearance as it was rubbing the firewall. I would suggest the electronic conversion kit from pertronics that uses a point distributer and converts it to electronic, that solves the clearance problem.Forgot to add that I also used the corvette valve covers
68-k-10 swb fleet
71 gmc K2500 402BB manual fleet
71 Gmc custom camper c2500 402 BB/TH400 fleet
72 chevrolet c2500 350/TH350 custom fleet
Last edited by bser; 11-02-2009 at 11:21 PM. Reason: brain fart forgot needed info
bser is offline   Reply With Quote
Old 11-03-2009, 10:43 AM   #96
Burt4x4
Burt4x4's Avatar
My old pics are gone so here is some new ones:
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 11-14-2009, 12:07 PM   #97
hamllik
hamllik's Avatar
I did one in my 1972 c10 4x4. I used the small block motor mounts the factory 1966 396 impalla valve covers with one of the sloped corners and a hei distributor. A short water pump and I had to hunt for a factory pan that would clear the cross member. The headmen headers for a 2 wheel drive fit except the pass side hangs too low to clear the front drive shaft. So I used factory manifolds. I cut the small block fan shroud down and it still works. With mine you can not use aftermarket valve covers. The only hacking I had to do was to trim the front cross member under the radiator a sliver abot a 1/2'' or so to clear the harmonic ballancer pulley that was it. My truck has factory air and I didnt have to mess with the heater box either. When I swapped in the 396 I also swapped to a 4 speed/np205 from a th350/np205. I hope this helps ya .
hamllik is offline   Reply With Quote
Old 12-04-2009, 09:01 PM   #98
Wildstreak
Wildstreak's Avatar
I guess I didnt read the last post fully it explained my question lol
57 chevy 4x4
68 burb 2wd:
Old 12-08-2009, 05:30 PM   #99
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice BBC installs guys!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 07-31-2010, 10:16 AM   #100
-Greg72
-Greg72's Avatar
SuperChevy,
Those aren't stock valve covers are they???
They look like the correct stamped steel "style" of cover but maybe a bit taller.... I'm trying to find a retro-looking set for my 502, but I am hearing that the stock BBC covers won't clear the rockers. I suppose I could use a set of valvecover spacers as a last resort.
-G
1972 K5 - 502BBC/4L80E/Magnum205/Mog-9s/5.26s/38" BFG KM2s
Find me on INSTAGRAM @MIGHTASWELLK5
'72 K5 - Greg's "Might As Well™" Build
-Greg72 is offline   Reply With Quote
