Old 03-29-2008, 04:50 AM   #76
jlaird
jlaird's Avatar
Re: [Project] "Fnlow69" PART II
lovin it! nice job.
jlaird is offline   Reply With Quote
Old 03-29-2008, 04:57 AM   #77
Coda O'Dell
Coda O'Dell's Avatar
What brand of four link do you have?
Coda O'Dell is offline   Reply With Quote
Old 03-29-2008, 07:18 AM   #78
FnLow69
FnLow69's Avatar
the lower bars are from suicidedoors and the upper link I made.
the bars are 30" centers
FnLow69 is offline   Reply With Quote
Old 04-02-2008, 03:31 AM   #79
SBCustoms
Complete Street Customization
SBCustoms's Avatar
this thing is sick man! too bad you live on the other end of the country! lol i wanna see that thing in person.
by the way where did you buy the pipe notcher. i really like your tubing work!
1968 GMC SWB (Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=269230)
1998 Chevrolet Silverado Z71
Southern Born Customs
Knoxville, TN
865-934-9126
SBCustoms is offline   Reply With Quote
Old 04-02-2008, 07:28 AM   #80
FnLow69
FnLow69's Avatar
thanks man, the notcher is a harbor frieght one, but its pretty decent quality.
Old 04-02-2008, 07:46 AM   #81
FnLow69
FnLow69's Avatar
Update 3/31/08
Well i re-did the tubing work, as i couldnt get the bag bolts out (guess i wasnt thinking). Anyways heres the new tube work, i like it better than the old tubing.....going to add a tube from the front tube to the back tube to finish the circle(hard to explain), and then adding a gusset to the mounts and calling it good? what do you all think??
Also got the front bags installed.............
Old 04-02-2008, 07:52 AM   #82
Rokcrln
Rokcrln's Avatar
Originally Posted by grendel View Post
looks like a rock crawler built it
Hey I resemble that remark
Your progress is looking great! One question for you. On your rear bag mounts are you going to add any more bracing? What you have so far looks sweet but all three points are almost in the same plane and that will not give you alot of upward support. I would at least place a small piece ot tube from the top of frame right up to the front bar and this will help act as a lerverage point for the bag mount and apply the force to the drive shaft hoop. Ifyou already had plans for more braces then never mind my rambling
*Oop's* I posted this with out seeing their was a page 4!! I see that you changed the locations of the mount tubes, with the front one so close to the frame will it add much suport or is it solid as is?
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 04-02-2008, 08:13 AM   #83
FnLow69
FnLow69's Avatar
its solid but more tube/bracing well be done, need more tubing...
Old 04-08-2008, 11:20 PM   #84
abadsvt
abadsvt's Avatar
Looks Sweet Justin!!! I am not sure how i missed your updates though. I think i might be going blind by all the welding i have been doing. Don't the frames look so sweet in raw steel form! I wish they would not rust so you could just leave them like that. The front and rear suspension looks great. I do agree with rocklin about some bracing for the bag mounts because all the weight of the truck pushes down on those mounts. One idea that i have is that you can bend a 90* piece of tubing on both sides of the frame and then have another piece connecting the two together and then have a piece pushing down on the bag mounts. That way when the bag inflates it pushes against eachother plus you can use this to support the front of the bed. Just make some mounts off that straight bar and there you go. Solves two problem at once. Here is a rough drawing of what i am talking about. Just an idea so no worries if you don't like it. I thought about doing something similiar for my other frame but without the bars going to the bag mounts for my other frame. One problem we have by doing a raised back half is supporting the front side of the bed because the new floor is has been raised alot. Anyways keep up the great work!
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 04-13-2008, 06:50 AM   #85
abadsvt
abadsvt's Avatar
Hey Justin I was curious on what your ride height is going to be?
Josh
(Project truck)
Old 04-13-2008, 07:05 AM   #86
bedsled71
bedsled71's Avatar
i agree with what abadsvt said, thats why i did mine the way i did.. but i think you will be alright. the tubing looks like it will be thick enough to hold. i could see it being a problem if the tubing was thin and you drive around like you have a monster truck
bedsled71 is offline   Reply With Quote
Old 04-14-2008, 08:09 PM   #87
FnLow69
FnLow69's Avatar
Josh
its a 5" ride height
Old 04-14-2008, 11:53 PM   #88
abadsvt
abadsvt's Avatar
What is your defination of ride height? Some measure to the bottom of th frame while others measure to the rockers and a few people refer to the lowest point of the car or truck is the ride height.
Josh
Ps. Did you get my pm?
(Project truck)
Old 04-15-2008, 02:25 AM   #89
FnLow69
FnLow69's Avatar
Josh
From the bottom of the frame, my rockers/doors are level with the bottom of the frame.
ya i got it ill get that measurement to you later tonight
Old 05-06-2008, 04:51 PM   #90
abadsvt
abadsvt's Avatar
any updates?
(Project truck)
Old 05-07-2008, 07:14 AM   #91
FnLow69
FnLow69's Avatar
nope, havent worked on it in awhile.
Old 05-07-2008, 07:54 AM   #92
abadsvt
abadsvt's Avatar
Well get your a$$ out there and get it finished. Sometimes it is good to take a few days off it and clear your head.
Josh
(Project truck)
Old 06-08-2008, 11:42 AM   #93
bedsled71
bedsled71's Avatar
its been another month?
Old 06-08-2008, 11:12 PM   #94
pissonNOS
senior member
pissonNOS's Avatar
any more progress on this? this migh be a dumb question but why does it look like you Zd the front of the frame and bought a dropmember? to get lower?
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 06-09-2008, 01:58 PM   #95
FnLow69
FnLow69's Avatar
No progress... been to busy...
the frame has about 1.5-2 inches more kickup to the front than a stock frame, will layout on a 28" tire (22" rim)
Old 07-01-2008, 11:28 PM   #96
Couch
Daily Driver
Couch's Avatar
is it just me or is the rear diff upside down.
http://i104.photobucket.com/albums/m...9/DSC00107.jpg
nitrous...the equal opportunity destroyer.
Couch is offline   Reply With Quote
Old 07-02-2008, 06:02 AM   #97
bad6772
Official Site Guitar Shredder
bad6772's Avatar
i think its just you, looks right to me.....
bad6772 is offline   Reply With Quote
Old 08-31-2008, 12:07 PM   #98
Scott Webster
Sheetmetal Psycho
Scott Webster's Avatar
Any updates? This one's got my favorite frame build written all over it!
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up!
Project "Rigginstine's Monster"
1971 C-10 longbed 355/4spd
Future mods: 67 front clip
Webby's Rigginations - where everything has potential!
Scott Webster is offline   Reply With Quote
Old 08-31-2008, 01:58 PM   #99
FnLow69
FnLow69's Avatar
No updates yet sorry... been too busy to work on it. but this winter there will be progress.
Old 09-14-2008, 12:17 PM   #100
Scott Webster
Sheetmetal Psycho
Fully understand. Today is the first day I have had off from work since Labor Day. Been working 10 hour days (yup even Sunday) and going to school 2 nights a week. Supposedly this is only for a few more weeks, but things change faster than I can keep up. At least when I have the time I should also have the money to do something cool! And now, back to sleep...
