07-21-2009, 01:26 PM | #76 |
Sofa King Crazy!!
Re: 1967 C10 Custom Big Window
Cool. Good choice! I see that truck all the time around the Spring/Tomball area. My freinds at Stereo FX installed the sound system so I got to look the truck over really close....alot of work went into it.
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
07-27-2009, 09:03 AM | #77 |
Sofa King Crazy!!
Just when you feel like you are making a little progress one of these "finished product" type of guys drops by to rub it in your face!! My freind Rick was out for a spin in his 69' and dropped by to check out the projects. His car is immaculate so I wanted to share.
07-27-2009, 10:00 AM | #78 |
Under Construction
Nice Camaro! how are you progressing on the truck?
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
07-27-2009, 03:22 PM | #79 |
Sofa King Crazy!!
I bought some 4 wheel drive front brake lines, which may be too long, but put them on the calipers anyway. I also purchased some 1980 Corvette shocks thinking they would work easily as a drop shock for our trucks, they do work, but you have to take the bushings out and swap them end to end. During this process I managed to stop a screwdriver with my palm......it felt great. I got the front shocks mounted, and they work great, but still have to do the back ones. I also cut down my rear shock mounts so I could flip them and use them on the opposite sides as shock relocators. That was not too difficult, just took about 40 minutes. What did all of you do this weekend????
07-28-2009, 03:55 PM | #80 |
Under Construction
stop stabbing your hand to get out of work !!
07-30-2009, 04:18 PM | #81 |
Sofa King Crazy!!
..........at least I was working on my truck when I did it!!!!
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" Last edited by Slick67; 07-30-2009 at 04:18 PM. |
07-30-2009, 09:45 PM | #82 |
Under Construction
yep, i have been a slacker.... probably work on it some this weekend....
07-31-2009, 10:31 AM | #83 |
Sofa King Crazy!!
That's my plan. Scuff the POR15 on the frame and paint it with Chassis Black, may do a couple of other parts with whatever I have left....like the core support. Hope the weather holds out, looks like rain here.
07-31-2009, 01:55 PM | #84 |
Under Construction
yep i should probably have my son scuff and paint the core support as well,. I 'll check back Monday for updates!
07-31-2009, 02:09 PM | #85 |
Sofa King Crazy!!
Uh ho. Now I have someone watching to see if I do anything this weekend. But I will be watching for your updates too!! The bottom fell out of the bucket just a few minutes ago, hope it all clears out for tomorrow!!
08-03-2009, 10:45 AM | #86 |
Sofa King Crazy!!
Weekend progress was good, the weather cooperated! Removed the bed again and pulled all of the e-brake goodies off the frame and cleaned them and painted all the little parts. Pulled the shocks back off and decided to paint them a different color too. I dropped the rearend and decided to go ahead and paint over the POR15 on my frame to give it a cleaner look. After scuffing the entire frame and masking the airbags and hoses and grease fittings (well, my girlfreind did the masking) I pulled out the paint gun and shot the frame Gloss Black.
My freind asked me to lay out the graphic tape for his hood stripes on his 71' Cutlass hood, he just finished painting on Friday. I was honored!
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" Last edited by Slick67; 08-03-2009 at 10:47 AM. |
08-03-2009, 01:38 PM | #87 |
Under Construction
looking good bro!
08-03-2009, 02:03 PM | #88 |
Sofa King Crazy!!
08-03-2009, 02:05 PM | #89 |
Tot Roddin'
The frame looks good, what did you paint it with?
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
08-03-2009, 02:48 PM | #90 |
Sofa King Crazy!!
Por15, then scuffed it with Scotchbrite pads then I used a cheap premixed automotive paint off the shelf from O'Reilly. The finished product looks pretty good I have to admit. Thanks for the compliments!
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" Last edited by Slick67; 08-03-2009 at 02:49 PM. |
08-03-2009, 03:33 PM | #91 |
Under Construction
Think i want you to repaint my frame.
08-03-2009, 03:47 PM | #92 |
VA72C10
Nice work. I plan on painting my frame with spray bomb as well. I'm gonna use rustoleum hammered finish.
Looking for a 67-72 swb or blazer project in or around VA. |
08-03-2009, 04:00 PM | #93 |
Sofa King Crazy!!
Not a problem! I'll do it!
08-03-2009, 04:01 PM | #94 |
Sofa King Crazy!!
The hammered finish looks cool!
08-17-2009, 03:46 PM | #95 |
Sofa King Crazy!!
I got the frame back together and put the front shocks back on. This weekend was spent sanding, fenders, hood, doors, grill preparing them for the second coat of primer and epoxy primer. I'll put the pics up tomorrow. Here is one of the frame back together with the e-brake lines and front shocks back on. Also got the motor mount brackets on and the trans x-member bolted down.
08-17-2009, 03:56 PM | #96 |
Under Construction
looking good..... i better get busy...
08-17-2009, 04:55 PM | #97 |
nice projekt! clean work
08-17-2009, 08:44 PM | #98 |
low n' slo
finally an update! i gotta get back over there and check it again sometime..lookin good!
08-18-2009, 09:40 AM | #99 |
Sofa King Crazy!!
Hey bro! Yeah swing by anytime. Hopin to have a little paint on it in 4-5 weeks. BTW how is the Burb comin along??
08-18-2009, 09:42 AM | #100 |
Sofa King Crazy!!
Tags |
1967, custom, lwb |
