Old 06-05-2011, 07:27 PM   #76
chad64chevy
chad64chevy's Avatar
Re: Finally my build thread is here! Lots of pics!
very nice!! any updates?????? been awhile since your last update!!
chad64chevy is offline   Reply With Quote
Old 06-06-2011, 11:48 AM   #77
chillware
Originally Posted by stealth_weapons View Post
nice set-up. i have the same UCA/LCA, but i got my brakes and everything from POL. do you have any pics of the sway bar mounting points. i havent had time to get around to installing mine as i am currently still installing everything else.
I'll try to get under there and take some pics this week of the sway bar mounting.. there were no stock holes in the frame for it, i pretty much just had to put it on the end links, and see where it lined up, marked and drilled the holes. I originally was going to use CPP 'lowered' bracket but they were too short, i ended up going w/ the stock height brackets.
My build thread: '66 Chevy
chillware is offline   Reply With Quote
Old 08-01-2011, 10:17 AM   #78
oldtrux
oldtrux's Avatar
sweet build,give's me great inspiration as well!did you use original rad support or aftermarket?
oldtrux is offline   Reply With Quote
Old 08-24-2011, 01:29 AM   #79
chillware
It's the original rad support, I took it to a local shop and they blasted and powder coated it, same color as the frame. was only about $100 to get it done.
More pics coming soon! Hold tight!
Old 02-12-2013, 02:38 AM   #80
chillware
Holy Crap! I havent updated my build thread in YEARS! WTF?!?
Well, here's what I did just the other day.. I welded up my gas tank hole on my cab! First time welding a patch like this, came out pretty nice! It'll need a bit of filler as the patch shrunk up a little from welding, maybe I should've went a little slower
I'm sending the cab out for sandblasting / epoxy priming this weekend!
