#76 |
Re: Guilty Customs teams up with WellBilt Kustoms to build a 67 C20
very nice!
#77 |
GEARHEAD
If it was me, I'd find another cab. Frame looks great.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#78 |
Thanks for all the comments guys!
I've been working on the cab since the start of the week, and were just moving steady on it. Got most of the rust spots cut out, and patch panels are made. Filled in the trim holes. Shaved the cab seam up at the top of the roof. Shaved the gas filler hole. And about 50% done with the roof drip rail. Both rockers have been removed, and passenger side needs new metal under where the rocker goes. Also got the firewall cut out, and ready for a new skin. We decided to cut the entire firewall out, and shave smooth, instead of filling all the holes, and tapering the two panels to make it look like one. I have also started shaving unwanted holes, open spots on the 55 chevy dash, and once all the floor has been fixed and welded up, I will start molding the dash in. I'll post up some pics later on tonight. Frame comes back from powder coating Friday! ![]() Also the engine comes back this week. Looking forward to seeing how all that bling looks on there with the fresh coat of paint to match all the suspension components. |
#79 |
Member of the longbed union.
Man that thing is sweet. Looks like you could have built a 2x4 and been way less work. But it's outstanding work none the less.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#80 |
powdercoater
What color powder coating did you go with ?
SCOTT |
#81 |
For the frame, we went with a black base with copper vein hammer finish. Should tie everything in really well.
The truck will be pearl white up top, rootbear candy color on the lower half, and in the middle of the two, it will have a tangerine candy color to break it up, with silver pinstripping. Not sure if its just going to be a straight break in the colors with the tangerine, or have some type of graphic or pattern to it. |
#82 |
Frame is back from powder coating. I will post pictures of it here shortly. The copper color isn't as vibrant as we thought it was going to be, but overall it looks like a rootbeer color, which works out perfect with the color scheme for the exterior of the truck.
Metal work and rust repair continues on the cab. I should have a good portion of it done this week. If any of you are local, and attend the long beach high performance swapmeets once a month, May 9th is the next event, and I will be there in a booth with the chassis put together as a roller, so please come by check it out, and say hello. I'd love to meet some of the guys on this forum! |
#83 |
Man what an awesome build! Your attention to detail speaks volume for what kind of work you guys must do.
Erik 1967 K10 SWB Big Window - Bone Stock 1955 JEEP CJ5 13K orig miles (Resto waiting patiently in the garage) |
#84 |
#85 |
Here are a few pics for you all:
The custom built radiator after polishing: ![]() ![]() Fuel cell after polishing, and clear coat: (pics don't do it justice) ![]() ![]() The TONS of chrome plated, Allen head bolts to assemble this truck: ![]() ![]() |
#86 |
Pictures of the fresh, powder coated frame:
![]() ![]() ![]() ![]() ![]() ![]() Starting to put together the parts to make it a roller: ![]() ![]() |
#87 |
Cutting out the cancer areas for new metal:
#88 |
Shaved gas filler hole:
![]() ![]() Shaving roof drip rail: ![]() ![]() Shaving door latch area: ![]() Cutting out firewall for new smooth one: ![]() |
#89 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Where did you pick up those chrome allen bolts?
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#90 |
VA72C10
![]() Join Date: Mar 2008
Great progress! Frame looks AWESOME!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#91 |
Gearhead
Incredible work, that frame looks amazing! Keep it up!!
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
#92 |
I ordered them from my fastener supplier. They look great, but they aren't cheap! But when you look under this truck and notice that every nut is chrome, and every bolt is a chrome plated allen head, it just makes it that much better.
#93 |
I recognize the area now. You are across the street from A-1 Transmission, they resealed my Turbo 400 for my 70.
70 shortbed stepside "Schleprock" 350 w/TH400 rallys and BFGs -We can rebuild it, we have the technology-lower,shinier,faster |
#94 |
#95 |
update and recent pics are coming up soon as my photobucket finishes downloading them
#96 |
![]() Join Date: Sep 2007
Awesome job!
Giving me some motivation! |
#97 |
Frame up on lift starting to re-assemble: Billet carrier bearing.
![]() Getting ready to drop fuel cell in. Made rubber spacers. ![]() ![]() Putting together front control arms. Painted ball joints, and bolted in with chrome allenhead bolts: ![]() More rust repair, and welding of the shaved roof drip rail: ![]() ![]() ![]() ![]() Door sill replacement sheetmetal: ![]() painted new U-joints for driveshaft: ![]() |
#98 |
tranny almost all cleaned up and ready for paint:
![]() ![]() Tie-rods awaiting paint: ![]() U-joints ready to go in: ![]() Front brake calipers clean and ready for paint: ![]() New chrome trans pan: ![]() Energy suspension poly trans mount: ![]() more rust repair: ![]() New cab corners from classic industries: ![]() tie-rods getting painted: ![]() |
#99 |
Junior Member
Real nice work truck will be awesome
#100 |
Tranny ready for paint:
![]() Few coats of base coat: ![]() Clear coat: ![]() Parts cleared: ![]() You do alot of stupid things when you work from 9 am til 2 am: ![]() ![]() Tranny cleared with about 3 coats: ![]() Tranny put back together with new seals, new filter, gaskets, chrome oil pan and silver painted parts with some chrome allen head bolts: ![]() ![]() Tie-rods done: ![]() |
