Old 05-21-2010, 07:22 PM   #76
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Re: dodge steelies
Love these wheels, I may take the plunge when I'm ready to get some wheels.
Ghostwhite is offline   Reply With Quote
Old 05-25-2010, 12:43 AM   #77
cajundragger
Re: dodge steelies
scotts hotrods made my front rotors.
in the rear I have a 12 bolt, moser axles set to 5.5, and late model ram disk and calipers. I just re-flanged the tube to hold the dodge backing plates.
why use dodge brakes?
because I wanted disk in the rear and the 5.5 axle flange will not fit in the hat of a 5 on 5 rotor.
If you want to run drum its a fairly easy swap.
cajundragger is offline   Reply With Quote
Old 12-12-2010, 04:59 PM   #78
Conundrum
Conundrum's Avatar
Re: dodge steelies
I have a set of these wheels that I am looking to put on my 74 GMC project and according to my measurements, the backspacing is 5 3/8".
CHIZZLER, your truck looks good with the 20s.
cajundragger, I followed your build on gmfullsize for a while and it's a real nice truck.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r
http://67-72chevytrucks.com/vboard/s...d.php?t=460030
97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver
220,000 miles, all stock for now
Conundrum is offline   Reply With Quote
Old 12-13-2010, 11:23 AM   #79
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: dodge steelies
Conundrum,
Are you sure your gonna put them on your 74? Your 74 is 5 on 5 bolt pattern right?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-13-2010, 11:36 AM   #80
cajundragger
Re: dodge steelies
for those of you who havent seen, I did some changes on mine.
Went from a 8" to 10" rear wheel so went from 255/35/20 to 295/35/20.
the rears are widened to 10's now and back spaced to give me a decent lip. The fronts are stock +1" more backspace.
Old 12-13-2010, 05:20 PM   #81
Clyde65
Clyde65's Avatar
Re: dodge steelies
OK cajundragger, how did ya do that? did ya have it done?
Clyde65
Rebuild of Clyde
support our troops!
Old 12-13-2010, 05:56 PM   #82
cajundragger
Re: dodge steelies
stockton wheel did them.
great work, ****ty customer service though. Took 16 weeks for them to get them done instead of the 6 they orignally quoted. and basically acted shady the whole transaction.
Old 12-13-2010, 08:20 PM   #83
Conundrum
Conundrum's Avatar
Re: dodge steelies
Originally Posted by Clyde65 View Post
Conundrum,
Yeah, I have redrilled front rotors and 1 1/4" adapters for the rear.
Hey cajundragger, did you have your wheels done in black chrome as well?
Old 04-11-2011, 06:41 AM   #84
Conundrum
Conundrum's Avatar
Re: dodge steelies
Put 2 on using just the adapters to see what they would look like on a square body, the rear...........
The front...........
Whole truck............
Not to bad, I don't think.
Old 04-11-2011, 09:11 AM   #85
gringoloco
A guy with a truck
gringoloco's Avatar
Re: dodge steelies
Man, those are good looking wheels Is the center cap just resting there?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-11-2011, 04:44 PM   #86
Conundrum
Conundrum's Avatar
Re: dodge steelies
The center cap is attached using the original hardware, although the lug holes took a little modification. It's the only cap I have modified so far, it was in rough shape so I didn't mind grinding on it a bit.
Old 09-18-2011, 08:51 AM   #87
iceship
Re: dodge steelies
C-drum on your truck how close are the rims to the fender.... iv been looking for something doff like that..
iceship is offline   Reply With Quote
Old 09-18-2011, 10:50 AM   #88
Conundrum
Conundrum's Avatar
Re: dodge steelies
Depends on the amount drop you have, stock to a 2/4 drop you could these wheels with adapters all the way around and they'll sit about where the stock ones do. More drop or bagged and you'll need some redrilled rotors in the front to pull them in. I am currently running 2.5" spindles, stock coils with one coil cut, 1.5" sectioned crossmember and a 2" Z, if my math is correct that's 8" in the front. With the redrilled rotors the fenders have clearance but the inner fenders will have to come out. I'll try and get a couple pics up later today.
Old 09-18-2011, 01:25 PM   #89
iceship
Re: dodge steelies
Thanks man I'm 5in in back and 2.5in spindels in front ... I waited to lower the front just for this reason....
Old 09-18-2011, 05:45 PM   #90
Conundrum
Conundrum's Avatar
Re: dodge steelies
This one is with the adapters, 1-1/4" thick....
And this one is with the redrilled rotors....
I know that they are at different angles but you can kinda see the difference in the amount of space there is. I haven't gotten the front sheet metal all reinstalled yet, I will need to mod my fenders and inners when I do.
Old 09-19-2011, 11:49 AM   #91
kieth
kieth's Avatar
Re: dodge steelies
Originally Posted by silvervic99stang View Post
DODGE 1500 PICKUP 02-08 20" BLACK STEEL WHEELS ok will these fit the 73-87 chevy bolt pattern? i like the way these wheels look, and where can i find the for a decent price
On the rear one could drill the axle flanges to get the proper bolt pattern but you will probable need wheel adaptors for the spacing of the rear end.
I got a set of stock hubs for the front of my 66 gmc and had them drilled to the correct 5 lug pattern for 100.00, you will probably not need spacers on the front if you use a later model crossmember, and drop spindles, they space you out 3/4" plus 1/2" per side so you may not want the adapters on the front so it will be easier to slam the truck. Kieth
kieth is offline   Reply With Quote
Old 09-21-2011, 02:42 PM   #92
kieth
kieth's Avatar
Re: dodge steelies
I have been calling around and the least expensive I could purchase these wheels for is $125.00 each used at a salvage, guess we are going to go to the dodge truck dealer and steal spares some evening to hold the cost down.....ha ha...
Old 09-21-2011, 04:28 PM   #93
Conundrum
Conundrum's Avatar
Re: dodge steelies
That's crazy, have you checked ebay?
I have a place saved on my computer, i'll try and post the link later.
Old 09-21-2011, 10:26 PM   #94
iceship
Re: dodge steelies
I found one here for 120...... need to find 3 more... one junk yard said if they have any on lot its 60.. if they have to search and ship any to them it will be 140
Old 09-21-2011, 11:03 PM   #95
Conundrum
Conundrum's Avatar
Re: dodge steelies
92.99 each
http://www.finishlinewheels.com/DODG...C0+TRUCK/2006/
Old 09-23-2011, 11:38 AM   #96
meter swinger
meter swinger's Avatar
Re: dodge steelies
Sweet these should be a bolt-on for the Travelall as long as the center mates up. anyone know the center hole size?
meter swinger is offline   Reply With Quote
Old 09-24-2011, 10:23 PM   #97
iceship
Re: dodge steelies
Ha guys. I was on ebay looking for dodge rims and ran in to so toyota tundra rims that look just about the same ..... 18x5 and a 5x5 bolt pattern what is the odds os that... I guess ill have to rock the 18s so I don't have to use my spacers........ I may put the 20 in back. Just to push the rims out ...
Old 09-24-2011, 11:32 PM   #98
502ms
502ms's Avatar
Re: dodge steelies
To each his own, I guess. I love how the steelies look on every one of these trucks....just not the square body 73-87. To me, the square body needs something beefier filling those wheel wells. Maybe with a drop....but still. I'm not seeing it work....and this is what I do for a living.
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 01-18-2012, 04:30 PM   #99
ScrappinChevy
Re: dodge steelies
will the dodge steelies fit my 64
ScrappinChevy is offline   Reply With Quote
Old 03-25-2012, 03:33 PM   #100
love my 72
love my 72's Avatar
Re: dodge steelies
Not with out modification or adapters, If your truck is a 6 lug the bolt pattern is 6x6.5 and the dodge wheels are 5X5.5
51 Chevy 3100 Deluxe Cab(SOLD)
65 **stang 6cyl
70 C10 Long Bed Fleetside(1st truck,thanks Dad![SOLD])
72 C10 Short Bed Fleetside
73 Blazer 2WD Catalina Blue White Top(Needs Love)
73 Blazer 2WD Work in progress LT1/4L60E
83 Grand National (SOLD)
94 Blazer K1500 Silverado (SOLD)
96 Impala SS All original (NEXT IN LINE 2 B SOLD)
99 Tahoe 2DR, 2WD
love my 72 is offline   Reply With Quote
