Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-07-2010, 02:08 AM   #76
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: Pro Street Trucks/Cars pics!!! im in love with the fatty tires!!
Call me a butcher cuz I like the meats!!!
prostreetC-10 is offline   Reply With Quote
Old 04-07-2010, 06:50 AM   #77
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
hey PSC10 are those radial's....I noticed that my new sneakers make my truck wonder pretty badly..I was woundering if it was because of the radial fronts and bias back or wether it was due to low air on the rear??
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 04-07-2010, 07:01 AM   #78
djracer
djracer's Avatar
His are bias. How low are you running them on the street?
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 04-07-2010, 07:11 AM   #79
Hottrucks
Hottrucks's Avatar
20/25 lbs the tires are 31x15.5 15 mickey thompsons
Old 04-07-2010, 07:21 AM   #80
djracer
djracer's Avatar
read on the side of the tire and I would run max pressure or close to it when not at the track then let them down.
20 is not enough on the street. I didn't have a problem when I ran sportsman pro's and radials.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-07-2010, 07:27 AM   #81
Hottrucks
Hottrucks's Avatar
thanx I guess I'll air them up...I hate to the foot print is even and I dont want to wear the middles out anymore than I do already.....
Old 04-07-2010, 07:43 AM   #82
bigsnookmaster
bigsnookmaster's Avatar
Here's a few of mine:
bigsnookmaster is offline   Reply With Quote
Old 04-07-2010, 08:05 AM   #83
Hottrucks
Hottrucks's Avatar
hey Greg I'd love to check out your truck I'm going to be in St Pete next week( wednesday)..theres a show in Oldsmar saturday (17th) I'm going to check out..the rest of the time I'll be at the Under Tow,Jimmy B's or some where on Gulf Blvd...hiding behind a beer..yea I spend alot of time in your neck of the woods......
Old 04-07-2010, 08:47 AM   #84
djracer
djracer's Avatar
Man that truck is lookin sweet!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-07-2010, 09:56 AM   #85
prostreetC-10
My Carbon Footprint
They are bias ply sportsman. You are actually running too much air. I believe the tires are only rated at 20 psi max which would be under max load rating. When I ran them at 18, they got worse. It causes the tire to crown real bad. I run 16 in mine and it's about what the truck likes. They are going to feel like they are walking on you no matter what pressure you run. I am on the hunt for either M/T radials or Hoosier radials. I have talked to a lot of people that started with the sportsmans and switched to radials. They say you won't believe the differences. It's not so much that you are running radials with bias as the fact that the bias are so wide and not much of a sidewall. You really have to choose the "look" or ride quality. I chose the look.
Old 04-07-2010, 03:30 PM   #86
bigsnookmaster
Thanks DJ, and if it only ran like yours!
Old 04-07-2010, 09:21 PM   #87
Hottrucks
Hottrucks's Avatar
thanx PSC10 my tires are 31's so there a bit tall for my truck ( being bagged with a C notch) I should be on 29's I'm going to use the old school white shoe polish trick to bring them into the correct presure
Greg got your pm I'll give you a call next week some time ( whens good? )
Old 04-08-2010, 06:33 PM   #88
Hottrucks
Hottrucks's Avatar
hey guys anyone intrested in a group buy on the MT 6642...it's the 29x15.5x15..radials..
seems like there is a price fix on them..$282 each maybe we can get a deal if we buy a few pair??
Jeff
Old 04-08-2010, 08:10 PM   #89
Hart_Rod
Hart_Rod's Avatar
What backspacing did you end up with Hottrucks and were there any clearance issues? I'm looking at buying some 20 x 15s with 9" BS, but I want to make sure they fit.
Hart_Rod is offline   Reply With Quote
Old 04-08-2010, 08:46 PM   #90
Hottrucks
Hottrucks's Avatar
I added 4" to the backspacing of a stock rally any more and there would be issues..mostly because of the panard bar bracket on the cup car arms you can see the Pb hanger in the build pic and the other crappy pic shows the clearance
Old 04-09-2010, 12:00 PM   #91
D13
D13's Avatar
Originally Posted by 383Chevy View Post
85' chevy stepside,33x18.5x15 M&H and she aint tubbed either
I must confess I find the color unappealing. But make it metallic blue or green and you have the truck I want! This looks just like what we would see back in 78-80, a clean truck with a front lift, big rears (N50's not M&H's but the same idea), and a whole lotta motor!
Now I gotta go find a short step but a !!
Seriously, how much did you lift each end to get that stance?
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 04-09-2010, 01:40 PM   #92
Shon
Let me know how many are interested and I will see what I can do.
Jeff
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 04-09-2010, 06:45 PM   #93
Hottrucks
Hottrucks's Avatar
Ok a quick measurement is 8" back space and 4 up front (stock)....the 9" will be close to the spring..really close I would want to check off your wheels if you know what your spacing is??
Old 04-10-2010, 12:01 PM   #94
prostreetC-10
My Carbon Footprint
Use what you feel you need to come to the correct pressure but max air is for max load. You can't compare these to your car tires that you run 35 psi in. They distribute the load differently. You will not want to be anywhere near 20 lbs.
Old 04-10-2010, 12:25 PM   #95
Hart_Rod
Hart_Rod's Avatar
With the price they're asking for the 20 X 15s, believe me, I'll do some serious measuring prior to ordering them, .
R/
PSC10, what backspacing do you have on your wheels?
Old 04-10-2010, 06:16 PM   #96
red rumbler
red rumbler's Avatar
Originally Posted by Marv D View Post
One of my favorites
but right now it sorta looks like this......
and
Just waiting on parts and the time to get this metamorphosis under way. Have been procrastinating on what to do about trans,,, If I change to a glide it adds a LOT of expense. I don't know if the Hughes TH350 is going to like what I'm doing,, and I have a pro-tree Hughes TH400 w/ shields all ready,, but will have to change driveshafts, and to use air will have to change shifters,,, bla bla,, every little detail justs keeps adding more and more $'s. Goal is to have it all ready before it get's hot so I don't have to wear a stinking firesuit to race this summer!!!
were you at pinks all out???
red rumbler is offline   Reply With Quote
Old 04-10-2010, 06:17 PM   #97
red rumbler
Originally Posted by 1Bad62Pro/Street View Post
They said it came of a Freight Train.
YouTube - Camaro Wheelstander with HUGE Blower!!!
that is nucking futs!!!!!!!!!!!!
Old 04-10-2010, 08:50 PM   #98
prostreetC-10
My Carbon Footprint
If I recall.....I have 8.75 to the back and 6.25 to the front.....or 8.5/6.5!
Old 04-10-2010, 08:59 PM   #99
Hart_Rod
Hart_Rod's Avatar
I'm guessing you didn't have any clearance issues? Yours are 14" wide correct?
Old 04-10-2010, 10:40 PM   #100
prostreetC-10
My Carbon Footprint
No clearance issues at all because I did all my cutting and welding first, then just ordered the wheels to fit perfectly. Yes, 15x14's.
