Closed Thread
Old 03-22-2010, 11:08 AM   #76
jorgensensc
jorgensensc's Avatar
Re: Boss 338 Wheels **GROUP BUY**
So another dumb question. Do the 18 x 8.5 come in 8.5", or 8" width. On the price sheet it says 8.5", but on the spec sheet it says 8"?
I'm a loser. I'm only looking for the 18's not the 20's.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline
Old 03-22-2010, 11:16 AM   #77
brossow
Amateur Rust Fighter
brossow's Avatar
The truck I photographed had 20x8.5's on all four corners. He had a spacer on the back.
Ah. I was confused because you said this: "Anyway,... they are 20x10 (6.250" bs) and 20x8.5 (5.250" bs) with the ever popular 5x5 bolt pattern." I thought you were referring to the truck shown, not the rims you ordered. Guess I could have seen that had it occurred to me to look at the width of the chrome lip.
I haven't mounted my wheels on a truck yet. My 69 is still 6-lug. I plan to run spacers,... I always have.
I think without them they will contact the wheel tubs.(especially with the 67-70 rearend). My blazer has the wider 71-72 rearend and I have a 5.5" bs wheel on it,... and it is close on the inside. No room for another .725" of backspace.
Okay, so obviously it can be done with spacers, which will cost people about $60. Maybe I'm just misinterpreting what you've written, but you've really seemed to be badmouthing the 20x10 option when a cheap solution is not only possible but is in fact what you intend to use. Yes, it's obviously something people should consider when looking at these rims, but I think you've managed to scare away several people over what amounts to a minor issue that's easily resolved. (No offense; that's just how it comes across.)
Brent
'72 Chevy SWB stepside - [ Build Thread ]
'79 ChevMC SWB fleetside - [ Build Thread ]
'64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...)
brossow is offline
Old 03-22-2010, 11:17 AM   #78
brossow
brossow's Avatar
Shawn
Should say 8" -- my cut-n-paste error. All fixed now. Thanks for the heads-up!
Brent
brossow is offline
Old 03-22-2010, 12:07 PM   #79
Boyd
Resident Lurker
Boyd's Avatar
Ordered mine, staggered set of 20's - spacers don't scare me.
Boyd is offline
Old 03-22-2010, 12:12 PM   #80
Wildstreak
"something witty here"
Wildstreak's Avatar
Its morning now and well Im still tired lol. but I have a clear thought now. how would much would shipping to canada cost? Im really interested, I was just about to buy c5's but these are looking very inviting. Im not scared of the spacer either, lots of people use them lol
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline
Old 03-22-2010, 12:33 PM   #81
lolife99
67-72 parts collector,…
lolife99's Avatar
[/I]
No offense taken.
If people are scared to run spacers,... that's their option.
I just don't think people understand or realize what a 6.225" bs means.
I just want everyone to know what they are getting.
I would never run anything other than 8.5's up front and 10's in the rear with these 338 wheels. I always planned to run spacers on the rear.
I also switched to 1" rotors up front because I didn't want to use a spacer up front. (the 5.25" BS on the 8.5's is just barely enough for my liking)
My biggest pet peeve with wheels is the wrong backspace.
In my opinion,... the wheels have to fit the truck.
The offsets have to be different due to the wider track width of the front suspension. (or the rear wheels need to be wider)
Again,... this is just my opinion.
I'll get out of this thread.
I seem to be doing more harm than good.
SCOTI posted alot of good info about running the 20x10's with this 6.225" BS,... and no one seemed to be listening. So I chimed in with the spacer comment.
SCOTI's quote:
My 68 w/the stock 68 12-bolt could use 5-5.50" back-spacing. I installed 5.50"BS wheels that required mini-tubbing the bed floor. Add an additional .725" & it would only be worse. The use of a wider 71-72 rear might work better here but I'm not sure how much clearance would be there.....
The 5.50"BS was about the max I could use on my 74 (w/stock 74 12-bolt). Again, any more back-spacing would require mini-tubbing. There might be a slight chance they'd fit but it would be close.
The easy solution for everyone running a 15x8 ralley wheel, is to go out and see if you have another 2-3/16" or 2-1/4" of room between the inside edge of the wheel and the wheel tub. If you do fine. They will work.
(Just be sure to measure both sides of the truck,... because they are usually different)
Keith
Convert to disc brakes.
lolife99 is offline
Old 03-22-2010, 12:36 PM   #82
Wildstreak
Wildstreak's Avatar
I know what bs is need 5-5.5 but would the larger backspace give it a larger lip? just curious
57 chevy 4x4
68 burb 2wd:
Old 03-22-2010, 12:49 PM   #83
72mistressc10
72mistressc10's Avatar
I value your opinion...
So in other words this is the reason why one "shouldn't", in your opinion, run 20x8.5 all the way around, unless the individual is planning on running a spacer in the rear, correct?
20x10 will fit in the rear for my truck, I was just thinking of the rotating purposes for the 20x8.5 all the way around, but if it won't look right, then I would rather go with staggered.
Thanks for all the info, lolife that includes you
1972 C10 LWB Cheyenne Super
God Said,"Owning A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still Gay"
........................__
..........._______ |__\__
..........|__(O)______(O)]
72mistressc10 is offline
Old 03-22-2010, 01:14 PM   #84
SCOTI
SCOTI's Avatar
Here's a direct link to Benji's post, which shows the 20x10s on the rear of his '72 without any apparent spacers....
Keep in mind, that truck is a 72 which has the wider (by approx .750 each side) rear 12-bolt. That would explain why they fit w/o spacers/adapters vs. the shorter housing from a 6x-70.
Opposite.... more back spacing within the same width of a wheel means less 'lip' on the outside. Less BS = more lip.
I like staggered sizing front to rear. I've never owned a vehicle w/the same width F/R thus have never rotated tires. If you don't mind the same size 8.5" front & rear, they should work w/o spacers. The 20x10's appear to work for the rear of 71-72's w/o issue looking @ the pic of Benji's truck (nice truck @ that).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is offline
Old 03-22-2010, 01:24 PM   #85
k5hart
k5hart's Avatar
Just to jump in and hopefully not cause more problems or sound offensive. I think, as it was said, these wheels were designed more for the 88-98 trucks which is why they work well on them as is. Remember, the track width is different for different years of trucks even among the same body styles.
That being said, the key to getting something that works for you is.....MEASURE YOUR TRUCK. No one knows what you have but you.
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel
Charleston, South Carolina
k5hart is offline
Old 03-22-2010, 01:32 PM   #86
brossow
brossow's Avatar
And sometimes not even that.
Brent
brossow is offline
Old 03-22-2010, 01:54 PM   #87
Leviticus
Shake and Bake!
Leviticus's Avatar
Ha, this is getting good, I think I'll just sit back and drink my coffee and watch the backspace drama continue
My 20x10's will be here tomorrow, and the new re-tooled 20x8.5's the following day. I'll let you guys know if the 20x10's stuff in my rear ok.
And I have a 72, so I will be no help to the 67-70 guys.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent."
Thomas Jefferson
"You are remembered for the rules you break."
General Douglas MacArthur
"Support Our Troops And The NRA"
Leviticus is offline
Old 03-22-2010, 02:05 PM   #88
Sublvr72
Sublvr72's Avatar
Originally Posted by 72gmcshorty View Post
Excuse my ignorance...why would someone order different backspacing between the front and back? Can someone give me a quick and simple explanation of what backspacing is? Is it to do with how close the lip of wheel gets to the fender? Would either of these wheels fit with a stock 72 2wd rear end?
People like to go staggered to get the widest possible tire on the back of their RWD car/truck to get increased traction and looks.
Here's a simple image that goes over wheel fitment
Q: How do I measure backspace?
A: The easiest way to measure backspace is to lay the wheel face down onto the ground so the backside of the wheel is facing up. Take a straight edge and lay it diagonally across the inboard flange of the wheel. Take a tape measure and measure the distance from where the straight edge contacts the inboard flange to the hub-mounting pad of the wheel. This measurement is backspace. The following photo shows three wheels with 2", 3", & 4" backspace.
and here's a good link with plenty of wheel measurement info
http://www.customtacos.com/tech/index.php?article=40
Sublvr72 is offline
Old 03-22-2010, 02:10 PM   #89
Sublvr72
Sublvr72's Avatar
no idea on postage to Canada, but if you are interested in a set I can find out for you. Just need your Province, city, and postal code
Sublvr72 is offline
Old 03-22-2010, 02:33 PM   #90
NORCAL SS
i will be ordering a rim from summitracing to make sure the rears fit and then returning it. I want to test fit the 20x10 rear to see if i can fit a 305 40 20 on the rear of my dads 95 silverado. once thats set and checked i will be ordering them from this link.
NORCAL SS is offline
Old 03-22-2010, 03:08 PM   #91
Wildstreak
Wildstreak's Avatar
ah now I see, Ill wait for Leviticus to get his to make my final decision. sorry you answered at the same time I was responding. Ill send you my info through pm.
57 chevy 4x4
68 burb 2wd:
Old 03-22-2010, 03:23 PM   #92
Wildstreak
Wildstreak's Avatar
whens the deadline for this deal to? I wouldnt want to miss it
57 chevy 4x4
68 burb 2wd:
Old 03-22-2010, 03:37 PM   #93
TyKby2
TyKby2's Avatar
Just went and looked at the prices and I think I can't afford to wait to sell my other set of wheels. I guess I'll sell them to buy tires.
Kevin
1974 Chevy C-10 (The Mistress)
1971 VW Bus
1973 VW Super Beetle
1996 Jeep Cherokee
TyKby2 is offline
Old 03-22-2010, 04:36 PM   #94
brossow
brossow's Avatar
(See Sublvr72's answer below.)
Brent
brossow is offline
Old 03-22-2010, 04:49 PM   #95
Sublvr72
Sublvr72's Avatar
I'm collecting orders this week, and I will place them with american eagle by friday.
Future orders are possible, just need to collect a few before I go down there to have them shipped.
Sublvr72 is offline
Old 03-22-2010, 06:56 PM   #96
Sublvr72
Sublvr72's Avatar
attn all!
18x8 and 18x9.5 chrome are in stock and ready to ship!
Sublvr72 is offline
Old 03-22-2010, 07:06 PM   #97
justincat
cool, im in as soon as the 20 by 10 and 20 by 8.5s come in on the chrome. I understand you have to run a spacer on the back. Do you have to run 1" rotors in the front or can you run 1 1/4 rotors on a 67?
justincat is offline
Old 03-22-2010, 07:18 PM   #98
k5hart
k5hart's Avatar
Are the 18's in grey available yet?
k5hart is offline
Old 03-22-2010, 07:24 PM   #99
Sublvr72
Sublvr72's Avatar
18" grey are available in both 18x8 and 18x9.5
Sublvr72 is offline
Old 03-22-2010, 07:39 PM   #100
DrtyJack75
Wow, Im more confused now.. haha
I have a 67, pwr disk brake conversion and 5 lug axles from ECE.
I do NOT have bags as of right now, but I DO WANT THEM SOON!
Will these fit? Im not that scared of spacers/adaptors...but will these work on a 67 if it's bagged (or going to be)???
Im sorry...my trucks in storage and away in (military) training so Im unable to go out and measure my truck right now.
THANKS!!
DrtyJack75 is offline
Closed Thread
boss 338, group buy, wheels
