Old 12-31-2010, 01:42 AM   #76
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Re: "The Ayatollah of Rock and Rolla" 1987 Chevy 2WD SWB
20. Disconnected hose from front of intake, passenger side.
21. Removed intake bolts to front of block & unclipped drivers side wire from rear top of intake.
22. Loosened and removed water pump & fan, leaked lots of coolant!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 12-31-2010, 01:45 AM   #77
Gordonr1973
Home Built '87
23. Took off power steering pump.
24. Removed A/C belt.
25. Took off A/C compressor, short bolt is top left (rear).
Gordon
Old 12-31-2010, 01:49 AM   #78
Gordonr1973
Home Built '87
26. Took off drivers coil pack bolts and coil pack.
Gordon
Old 12-31-2010, 01:51 AM   #79
Gordonr1973
Home Built '87
27. Looked under rocker arm cover, will need to get into it in later step.
Gordon
Old 12-31-2010, 01:54 AM   #80
Gordonr1973
Home Built '87
28. Did drivers coil packs same way as #26.
29. Took off coolant air bleed pipe.
30. Removed knock sensor covers & vacuumed as they were very dirty.
Gordon
Old 12-31-2010, 01:58 AM   #81
Gordonr1973
Home Built '87
31. Pulled off knock sensor boots (you have to pull them straight up to get them off).
32. Ratched off knock sensors with a 7/8 socket.
33. Removed valley cover bolts.
Gordon
Old 12-31-2010, 02:02 AM   #82
Gordonr1973
Home Built '87
34. Took off valley cover, pull straight up as gaskets on knock sensor plugs cling. Vacuum out debris out of holes first.
Gordon
Old 12-31-2010, 02:06 AM   #83
Gordonr1973
Home Built '87
35. Taking heads off: take out upper and lower bolts on exterior of head, then take off rocker arm cover and remove the head bolts inside.
36. Need to remove the rocker arms, pins & ledge in order to get to the head bolts. Put these internal parts in order so they can be reassembled in the same spot they were taken from.
Gordon
Old 12-31-2010, 02:09 AM   #84
Gordonr1973
Home Built '87
37. Drivers side is the same way but you need to remove the fuel rail stop if you haven't taken it off already.
38. Interior rocker rail was installed upside down on my motor. I'm going to put it back in this way.
Gordon
Old 12-31-2010, 02:12 AM   #85
Gordonr1973
Home Built '87
39. Removed engine mounts on both sides of the block.
40. Removed hose clamp / bracket on passenger side, will need new gasket.
41. Removed oil cooler lines on drivers side of motor.
42. Removed oil pan, the long bolts are the rearmost two spots.
Gordon
Old 12-31-2010, 02:17 AM   #86
Gordonr1973
Home Built '87
That's all for now. Will order some new gaskets and head bolts tomorrow & do more on this on the weekend.
Happy New Year!!
Gordon
Old 01-03-2011, 08:34 PM   #87
Gordonr1973
Home Built '87
This is kind of cool: http://www.gm-trucks.com/rpo-code-lookup/?find=29u
Its a website to decode your RPO codes!!
I just verified I have a 3.08:1 (GU4) so I think I'll be looking for a 3.42:1
Gordon
Old 01-06-2011, 01:11 AM   #88
Gordonr1973
Home Built '87
Well, it now rolls....so I'm calling this post "the end of Chapter 2"
I put the wheels on for now so I can move it around the garage a bit better and I think it looks pretty good. I have no idea how the clearances will be yet in the fenders but that is a surprise I guess for later on!
I did figure out why the cross link was rubbing in the front (needed to be tightened up to spec) and now I have a list for the next two months (if time allows):
- get order in for parts for next steps, especially motor gaskets and sensors
- get motor cleaned up and painted
- decide on brakes
- order brake parts (if needed)
- get brake lines routed
- get gas tanks painted & installed
- decided on lines, valves, etc etc and order if needed
- decide on radiator and fan set up, order parts if needed
- receive engine parts, reassemble and drop it in with tranny
- adjust tranny cross member
- figure out rear diff and drive shaft
- Then, it will be time to move on to body work......
Gordon
Old 01-06-2011, 01:13 AM   #89
Gordonr1973
Home Built '87
One other thing....here are 2 purchases made on sale last month that are getting good use from me:
- my little sandblaster (good for the small stuff (boths and small shields)
- my hand cart (I love these things and will use it all the time!!)
Gordon
Old 01-06-2011, 10:16 AM   #90
spudz
spudz's Avatar
AWESOME looks good so far... the rust is crazy! keep at it!
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 01-06-2011, 10:54 AM   #91
silvereagle07
silvereagle07's Avatar
Looking good! The chassis looks awesome!
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 01-10-2011, 11:58 PM   #92
89muscletruck
89muscletruck's Avatar
i second that!
89muscletruck is offline   Reply With Quote
Old 01-11-2011, 01:55 AM   #93
Gordonr1973
Home Built '87
Thanks guys! I've been busy painting the gas tanks and straps but nothing really to take photos of yet....really been trying to put together a buy list for the parts I'm going to need soon.
Has been supremely frustrating to get the 'right' info for my situation but I'm on the right track now thanks to other forum members (check my other threads to see what I mean!)
More updates soon!
Gordon
Old 01-11-2011, 02:40 PM   #94
mcboomport
mcboomport's Avatar
Looking good!!!
mcboomport is offline   Reply With Quote
Old 01-13-2011, 04:14 PM   #95
Gordonr1973
Home Built '87
This is what I feel like trying to put together a parts list from all over....it's frustrating!! I'm getting to the point where I'm just going to drop the engine off at ProStock and tell them you do it up & spend up to this much $x !!
Gordon
Old 02-09-2011, 10:53 PM   #96
Gordonr1973
Home Built '87
Parts are now starting to arrive....going to be getting on this truck build again soon...
Been busy though lately...this is a few weeks ago trying to clear a path to my shed where I have some parts.
The front of the house was drifted in, the roads were terrible and now there is a big ice pile infront of my driveway where the city cleared the crescent.
Hope spring comes early!
Gordon
Old 02-10-2011, 01:19 AM   #97
89muscletruck
Not gonna lie, right now after almost wiping out on the solid ice sidewalks on the walk to the University, that snow is kinda looking appealing ..... Am I crazy?
Old 02-16-2011, 12:06 PM   #98
Gordonr1973
Home Built '87
Mounting a 4L80E transmission:
here are some links that I was sent regarding bolting up a 4L80E to a LS motor. Some of these are better than others.
http://67-72chevytrucks.com/vboard/s...d.php?t=444788
http://67-72chevytrucks.com/vboard/s...d.php?t=426994
http://www.pirate4x4.com/forum/showt...php?p=10063967
http://www.ls1tech.com/forums/conver...rter-help.html
http://www.ls1tech.com/forums/conver...-question.html
http://www.ls1tech.com/forums/conver...rt-number.html
http://www.ls1tech.com/forums/conver...eel-use-2.html
http://www.ls1tech.com/forums/conver...lex-plate.html
http://www.ls1tech.com/forums/conver...1-th400-2.html
http://www.ls1tech.com/forums/conver...350-5-3-a.html
http://www.ls1tech.com/affiliates/tr...d.php?t=445713
http://www.pacificp.com/forum/viewto...dc22e39a654db2
http://www.performance-shop.com/showthread.php?p=356722
http://www.theboombopshop.com/ARP-to...p/230-7305.htm
http://www.hotrod.com/techarticles/d...iew/index.html
http://www.transmissioncenter.net/4L...4L80E_Swap.htm
http://performancetrucks.net/forums/...ado+4l80e+swap
4L80E Swqap Info:
http://www.camaroz28.com/forums/show...highlight=4l80
http://www.tbssowners.com/forums/arc...p/t-50616.html
http://www.ls1tech.com/forums/automa...l80e-swap.html
http://ls1tech.com/forums/automatic-...over-part.html
Gordon
Old 02-18-2011, 12:16 AM   #99
73gmc454
73gmc454's Avatar
Nice clean build, I like it !
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237
73gmc454 is offline   Reply With Quote
Old 03-09-2011, 01:24 AM   #100
Gordonr1973
Home Built '87
Well, after 2 months I got a little more done today.
Most of the parts I've ordered are in, I just need to make some room in the garage in order to do work --- but the parts are in the way!!
Here I got the tanks on --- for newbies like me the tank straps are two different lengths, long ones in the rear, short ones in front.
Filler neck goes towards the rear, it also helps to bend down the joint edge a bit with a rubber mallet so the straps reach in order to start the nut.
The smooth rivetts should face down so they don't rub the tank (but in the front it doesn't touch so it doesn't really matter).
I bought gas tank anti-sqeek kit from LMC for $20 --- don't bother, its just some fat tar paper cut to length --- you could buy a whole roll for that much!
Anyways, here's a bit of my home office with parts strewn around & my garage work bench --- slowly getting there!
Going to start putting the engine back together this weekend and get it in there soon....might run fuel lines first though.
Gordon
