Old 01-28-2012, 06:06 PM   #76
jalopy45
Re: '62 BBW SWB Highschool ride returns
Glad to see you found the filler neck. Is there a young lady trying to trade you a corvair for the PU???
jalopy45 is offline   Reply With Quote
Old 01-29-2012, 12:14 PM   #77
Dan 67 Chevy LWB
A little buffing goes a long way.
Any recommendations on what wax to use?[/QUOTE]
Eric - I would say use car wax.
Danny
Dan
67 Chevy LWB, Small Window - In the process of being rebuilt. Small Block is coming out & I'm gathering parts to switch to a Big Block 496.
Dan 67 Chevy LWB is offline   Reply With Quote
Old 01-31-2012, 11:49 AM   #78
66Z71
66Z71's Avatar
I just love shiny stuff
Finally settled on seat belts. The first ones were too green. The last set are really dark blue, but it seems thats as good as its gonna get. So tonight after work I'll pick up some new bolts, and get them mounted. Then I can bolt the seat down, and finally screw the sill plate down.
"Always try to make the best part you can with the skills you have. If it isn't good enough throw it away and make another. Every time you make a part your skill will increase and you'll make a better part than you were capable of making before." Lil John Buttera
66Z71 is offline   Reply With Quote
Old 01-31-2012, 02:53 PM   #79
Dinos63
chevy only
Dinos63's Avatar
nice work looks great!!
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 09-14-2012, 11:33 PM   #80
Bomp
Bomp's Avatar
lookin really good.
Bomp is offline   Reply With Quote
Old 11-07-2012, 07:26 AM   #81
jalopy45
Gotta bump this to see how the progress is going... He'll probably use some excuse like he's been in Siberia and hasn't had time.
Old 11-07-2012, 11:20 AM   #82
66Z71
66Z71's Avatar
Doesn't everyone vacation there?
Actually moved it around in the shop last weekend. Going to pack the camping gear up for the winter, and clean out the rest of the garage so I can work on it again. As soon as I get back from Alabama, North Carolina, Mississippi, and South Carolina.
Old 08-19-2013, 12:21 PM   #83
66Z71
66Z71's Avatar
Ok. It's time to get this thing done, and out of the shop. I'm tired of walking around it. I put the motor in a few years ago. It was a brand new crate motor from Chevy. We cleaned it up, and re-shot the block & heads. The last time I painted the Edelbrock intake orange, but this time I sand blasted it, and gave it a light coat of aluminum paint to help protect it.
The steering column was swapped a long time ago for one out of a buddies wrecked '69 Cutlass. It had seen better days. The turn signal thingy was broken, the starter switch worked most of the time, and the horn button was DOA. I took another column I had, and gutted it for the electrical. Sand blasted the 'original' column, and painted it to match the truck. Now I just have to get a steering wheel. I'm thinking of one of those old style chrome 3 spokes with a metalflake white grip. Just to add a little bling to it, I made a new turn signal lever. The old one was rusted, and ugly, so... cut the end of a Titanium NASCAR valve off, turned it down a bit, and stuck it into a carbon fiber arrow shaft. Cut that off, and stuck it over the original lever. Bet I got the only Titanium / Carbon Fiber turn signal lever out there
Rebuilt the Holley Carb that was on it (650 vac secondary). So last night I set it up on the bench, and hooked up an electric fuel pump to it. Good thing I did. The inlet needle on the primary side didn't want to seal. Swapped it out, and set the float levels. Tonight when I get home (if there isn't a puddle of gas under it) I will be putting it back in place.
Old 08-19-2013, 01:36 PM   #84
jalopy45
Wow, then you can get to work on your crew cab, airplane, corvairs, race car and bmw's. then you'll have some room in the shop..
Old 10-18-2013, 12:11 PM   #85
66Z71
66Z71's Avatar
Spent a little more time on the truck. Got the inner fenders and radiator support sand blasted, and welded up all the old holes everyone has put in them.
Even fixed a little rust that was in the lower mounts for the radiator support.
All sitting in epox primer now.
This weekend hopefull it will get a skim coat of bondo, and some flat black.
Old 10-18-2013, 12:56 PM   #86
NEWFISHER
NEWFISHER's Avatar
Nice work on the turn lever! The rest looks great too
NEWFISHER is offline   Reply With Quote
Old 10-18-2013, 03:24 PM   #87
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Looking perrty dang cool! nice work!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 10-18-2013, 06:26 PM   #88
RestoringClassics
RestoringClassics's Avatar
This thing is coming together SWEET!!!
Love that bench seat!
RestoringClassics is offline   Reply With Quote
Old 10-21-2013, 10:26 AM   #89
66Z71
66Z71's Avatar
Thanks guys. It's finally starting to look like something. Just hope I can keep the motivation going.
Old 10-21-2013, 10:57 AM   #90
66Z71
66Z71's Avatar
Got a little more done this weekend.
I kinda like the shine
Just gotta wait for them to dry now. Then I can put them on.
While I was waiting, I was playing around with the steering, and noticed that the Pitman Arm was shot. Couldn't believe it but NAPA had the best price in town for a new one. So, without even having to lay on my back to reach it, I was able to change it in 10 minutes. Now every wiggle of the steering wheel = a wiggle of the tires. Can't wait to drive her again.
Old 10-21-2013, 01:01 PM   #91
Low Elco
Nice work here!
Low Elco is offline   Reply With Quote
Old 04-20-2014, 09:36 AM   #92
jalopy45
I think this needs a bump, just to hear the excuses. P)
Old 06-03-2014, 06:38 PM   #93
66Z71
66Z71's Avatar
Ok. I'm back. Race car is together and running good, quit my job (of 20+ years), and started a new business, cleaned up and sheet rocked the garage (so much nicer working in a bright room, instead of the dungeon it was. So now its time to get back to the truck.
Just cleaned the cab, and started putting the engine compartment back together.
Old 06-05-2014, 12:57 AM   #94
Captainfab
60-66 Nut
It's good to see you back on your truck
What type of business did you start?
Old 06-05-2014, 11:21 PM   #95
jalopy45
Big change for the shop, where did you hide all the parts and goodies that were hanging on the wall? Looks like there is room to walk on the floor now too.
Old 10-20-2014, 07:46 PM   #96
66Z71
66Z71's Avatar
A little more progress to post. I sent the last of the cab parts out to be sandblasted. Got them back 2 days later. Very nice to see there was not much rust. But why is it that the only holes I needed for the mirror were brazed shut.
While none of the others were.... Now you see them.
Now you don't.
A little grinding...
and they're all gone.
Everything got a nice coat of Epoxy Primer.
In my makeshift paint booth.
Old 10-21-2014, 11:22 AM   #97
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Very nice!
Old 10-22-2014, 11:31 PM   #98
boat
boat's Avatar
Looking good
STEVES 63 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=412554 GIBSON63 YouTube channel https://www.youtube.com/user/1gibsonl4
boat is offline   Reply With Quote
Old 10-27-2014, 05:22 PM   #99
66Z71
66Z71's Avatar
Got a little more done. Drivers door, and hood have been blasted, cut, welded, bondo'd, and primed. A little block sanding, and they are ready for color.
No more extra holes.
Old 02-20-2015, 04:29 PM   #100
Budman56
Budman56's Avatar
any updates?
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
