Old 04-09-2011, 03:26 AM   #76
coulter
coulter's Avatar
Re: intro + 66 black bagged long fleet
Originally Posted by gatordrag View Post
What are your Plans for the inline 6 that came out of it? Running non running?
a friend of mine has been wanting it for his 67
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 04-09-2011, 09:00 AM   #77
gatordrag
Gotcha, Cool deal Thanks
gatordrag is offline   Reply With Quote
Old 04-09-2011, 11:35 PM   #78
coulter
coulter's Avatar
well got a little bit more done today..
but first let me show you what happened yesterday!!
this was the bearing that was in the neck of an engine stand i am borrowing.. i was gonna move the motor from my garage to my shop on the side of my house
right as i was pushing it out of the door i hit a small crack in the sidewalk and 1 of the bearings in the neck of that stand exploded and my motor went for a concrete dive..
luckly it didnt really do any major damage.. it managed to not touch the end of the crank at all!!!!!
broke the water neck, few spark plugs, dented up my valve covers
o well i wanted aluminum finned vc's anyway
luckly i was smart enough to pull these off before i tried to move it
got these from a buddy for 250.. never been ran before
the drivers side hangs bout an inch below the factory oil ... i might have to cut it down a lil bit
i cleaned and painted my intake mani
then i played around with an idea of how im gonna mount my bed and raise the floor and what not
i had to find a good use for this cool looking spiral stock i had
im gonna take the factory rails out and weld this across a lil higher to raise the floor to clear the notch
on the bottom part of the spiral it is solid so im gonna drill and tap all of them to 1/2 inch or so and have jack bolts coming out of the stock mounts on the frame so i can adjust the bed any way i want to!!!!
ive pretty much got it figured out how im gonna do it so i will prolly pull the bed back off pretty soon to do all the welding.. still have to figure out how much i gotta cut those wheel tubs..
Old 04-09-2011, 11:43 PM   #79
daverod
SSN 706
daverod's Avatar
Sucks about the engine. Why do you want to raise and lower your bed floor? Is that a 350 my finned covers wouldnt clear.
daverod is offline   Reply With Quote
Old 04-10-2011, 12:23 AM   #80
coulter
coulter's Avatar
im making it to where i can adjust the whole bed to make it really easy to get the body lines how i want..plus im thinking bout doing a small body drop on the cab so this will make it easier to line it up if i do end up doing that..
also i want a factory looking wood bed and i dont want a big hole in the middle so im raising the wheel tubs and the height of the floor
and no it is a 454...hope i dont have to do too much cutting on the firewall
Old 04-10-2011, 12:06 PM   #81
jwalk
What was I thinking?
jwalk's Avatar
Looking good! That sucks about the motor, but it coulda been worse.
Justin
'68 C/10 Custom Long wide bed
'78 GMC Sierra short wide
Project: Second time around...'68 short wide
http://67-72chevytrucks.com/vboard/s...d.php?t=423949
jwalk is offline   Reply With Quote
Old 04-10-2011, 03:16 PM   #82
coulter
coulter's Avatar
ya im just glad i didnt have it all done with all the new parts and paint on it
Old 04-10-2011, 09:25 PM   #83
jasonhall
jasonhall's Avatar
Awesome project! cant wait to see more!
jasonhall is offline   Reply With Quote
Old 04-11-2011, 11:05 AM   #84
creep
Registered Loser
creep's Avatar
The bed mounts sound like a pretty cool idea.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 04-12-2011, 09:32 AM   #85
coulter
coulter's Avatar
thanx man i think it turned out pretty cool!! i got them tacked into place today.. gonna pull the bed off and finish welding it.. gonna add a few more smaller pieces of tubing for more braces.. dont wanna make it too heavy!!!
this will be the height of the floor
here is how the adjustment works... gotta get some longer bolts
just adjust it up or down by moving the 2 jam nuts
Old 04-12-2011, 01:20 PM   #86
daverod
SSN 706
daverod's Avatar
Jusy wondering how strong that will be? Side to side. Seems like a lot of force on a nut and washer. Compared to the orginial. Where's it's bolted direct to the cross member. who knows. Just seems like all that force is now on the sides of the nut. Bet that Lakesideroadster guy would put it on his cad system and show ya a bunch of nice colors and stuff. Wish I was there I would give it a good wiggle test. Do like your work though.
Old 04-12-2011, 01:44 PM   #87
Sixty6C10
Sixty6C10's Avatar
This truck is looking awesome!!! I have the same year/ bodystyle and cant wait to get it on the ground.
Sixty6C10 is offline   Reply With Quote
Old 04-12-2011, 06:01 PM   #88
coulter
coulter's Avatar
well it is still gonna use the factory rear mount that is under the tailgate to.. it feels super solid even with it just being tacked in place ( i wiggled the sh#@ out of it)
besides i dont plan on haveing more than 500lbs or so in bed so im pretty sure it will be ok.. also im planning on doin about 3/4inch or so body drop so those bolts wont need to be adjusted out that far after i do that
Old 04-12-2011, 06:53 PM   #89
daverod
SSN 706
daverod's Avatar
If it passed the wiggle test it should be fine.Where do you get the drill lookin things?
Old 04-13-2011, 07:43 AM   #90
coulter
coulter's Avatar
they came out of some screw pumps.. a buddy gave them to me
Old 04-23-2011, 08:17 PM   #91
coulter
coulter's Avatar
been working alot of overtime at work so havent had too much time to work on the truck but here is a small update
got some new goodies
got the cab trim mounted.. still gotta find a drivers side though
nasty!!!!
got the new support put in and the panel... still got some more work to do on this but its a good start
gonna do the other fender next
just for fun i slapped the parts on my motor... i found a lil suprise in the oil pan so im gonna tear it down for a rebuild.. then it will get painted black
also got the bed back off and started welding everything up and added a couple more supports.. still not done
Old 04-23-2011, 08:25 PM   #92
daverod
SSN 706
daverod's Avatar
If I had my computer in the garage I would never have to come in the house. Sucks about the engine.
Old 04-23-2011, 08:29 PM   #93
coulter
coulter's Avatar
ya i think that thing is bad luck!!! lol and ya i love having a computer in my shop.. always got good music playing and i can look up stuff without gettin my comp in the house all nasty when im working
Old 04-24-2011, 05:32 AM   #94
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
nasty!!!!
[IMG]http://img38.imageshack.us/img38/2677/12470180.
How deep will the bed be?
I'm thinking of doing the same thing. Just need a few pointers on how!
Sick5 is offline   Reply With Quote
Old 04-24-2011, 07:17 AM   #95
coulter
coulter's Avatar
the boards will sit on top of the square tubing so it will be a little more than a foot deep
Old 04-24-2011, 01:09 PM   #96
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
how many inches is it from the crease of the bed to the tubing. and are the tubing leveld with the top of the cnotch?
Old 04-25-2011, 08:24 AM   #97
coulter
coulter's Avatar
i set my tubes 2 1/4 below the crease and it will be just a lil higher than the notch
the easiest way to figure how u need to do yours is to keep a few of the stock rails in your bed and set it on there to see how tall your notch is. then build your floor height from that .. cause i made my notches and they arent as tall as most ive seen so if you use my measurements it might not turn out right
Old 04-26-2011, 08:03 AM   #98
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Sound good. Oh and the truck is coming out sweet.
Old 04-26-2011, 11:18 AM   #99
Mechanic77
Figure I might poke a little fun....you do realize you have the right side valve cover on upside, right?
Awesome build, keep up the great work
Pro Touring 1964 C10-Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=441627
Project '65 Short Step Daily Driver http://67-72chevytrucks.com/vboard/s...d.php?t=661948
Mechanic77 is offline   Reply With Quote
Old 04-27-2011, 07:31 AM   #100
coulter
coulter's Avatar
haha ya i turned the dented side around for the pic
