03-23-2012, 07:40 AM | #76 |
Re: 56 GMC Aussie Style
G'day Red,
Was great dropping in and meeting you guys today! Your truck looks fantastic and I can't believe the condition that it is in, especially the inside of the bed. Can't wait to see the future developements. All the best mate, have a great weekend. Trently. Posted via Mobile Device |
03-23-2012, 01:30 PM | #77 |
Red Foreman, Just went through your build again after talking to Trently saying he saw your truck. It is going to be a great truck. Love seeing the old school motor with the tri power. Keep up the great work.
Shannon
48 Panel Truck 1948 Chevy / S10 1954 Chevy / S10 1951 Chevy / C4 47 Step van Lowered 1996 Dually |
03-24-2012, 07:30 AM | #78 | ||
Thanks for the compliments on my GMC but my humble graft/build is light weight compared to your project & may I say your frame so far blows me away! Quote:
Cheers George.
RIP John (Lambis), my beloved Father & best Friend. My Build 56 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=486721 |
04-29-2012, 10:01 AM | #79 |
Its been a while but I'm back again with a little more work done.
Got the original spicer 45 diff back in (flipped of course) I used u bolts & plates from a locally made vehicle which helped re-mount the shockers due to verticle uprights that mount a dampner that I will probably be leaving on. I also repositioned the shocks up top, by moving the mounts out a couple of inches to straighten them up & take the lean out.
04-29-2012, 10:11 AM | #80 |
I forgot to mention the shocks are hand-me-downs off my mates 64 c10, they're 4" drop, also brakes are on & 99% of brake lines are done.
04-29-2012, 10:19 AM | #81 |
Making some great progress Red!! Looking really good!
Better to have it and not need it, then to need it and not have it. Fork In The Road....Cummins Build My Build Thread... Alternative A/C Mounting for LS Engines 4L60E Transmission Rebuild Info Trailing Arm How To |
04-29-2012, 01:37 PM | #82 |
Looks good.
Kim |
04-29-2012, 06:21 PM | #83 |
good to see things are moving along
04-29-2012, 09:00 PM | #84 |
Thanks guy's, Its a nice fresh autumn Melbourne morning & I'm going to have a crack at mocking up my new firewall master-cyl/booster & pedal set up that I purchased from POL. As if my firewall is in need of more holes??
04-30-2012, 09:01 AM | #85 |
Got the master cyl & pedal set up in today, as per instructions. As you can see the firewall looked like it was shot at with a musket & I was about to drill it some more
04-30-2012, 09:12 AM | #86 |
Master cylinder & pedal assembly bolted up nicely, not sure about the round pedal pad, I think I might swap it out for a rectangle type??
04-30-2012, 12:09 PM | #87 |
looks good red!
i forget how many holes are in these firewalls from the factory
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
04-30-2012, 02:19 PM | #88 |
Looks good. I like the round pedal.
Kim |
06-10-2012, 08:38 PM | #89 |
RF: Thanks for commenting on my build. You are flying on yours. I always check the build start date to see how long it takes to get anywhere on these projects. You've come a long way. I already have about 6 months in mine and it seems to be crawling.
My Build - http://67-72chevytrucks.com/vboard/s...d.php?t=515876 |
06-11-2012, 11:53 PM | #90 |
I like you're truck...and the 348!! Those are awsome looking motors!
1955 GMC Hydramatic 1959 Chevy Spartan 100 1969 Chevy C/10 1969 Chevy C/30 Bruiser 1972 GMC (Wrecked) 1972 GMC pickup..old blue Restored Vent Windows https://67-72chevytrucks.com/vboard/...d.php?t=766598 1955 GMC hydramatic build http://67-72chevytrucks.com/vboard/s...d.php?t=429417 |
07-09-2012, 06:31 AM | #91 |
Thanks for all the compliments guy's! There's been a lot a action in the project & builds section with alot of awesome builds on the go, so I guess you could say I'm a little inspired to move on with mine.
Next job was to fill all the factory holes in the firewall, I ended up measuring all the holes with a vernier & I ordered a heap of plugs laser cut to size at a local engineering shop....cost $50.00 amount of work saved priceless!! Called on me mate Jonny to come down & stitch them in.
07-09-2012, 06:41 AM | #92 |
And heres the finished product, saved a couple of holes for wiring & stuff but all welded up & ready for a little filler & paint.
07-09-2012, 08:32 AM | #93 |
G'day Red,
It's been too long since I've caught your build. Had a bit going on there by the looks of things. Great little booster set up you've got there. Also fifty bucks well spent on the laser cutting too I'd say. Would have made the job easy I bet. Keep up the good work mate. Posted via Mobile Device
Regards, Trently. My build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=482263 |
07-09-2012, 08:46 AM | #94 |
Hey Trent, you've gone missing on your build & thread, hope your house duty's are travelling along ok!
07-09-2012, 08:59 AM | #95 |
Like you Red, I see my truck nearly everyday, but most days at the moment, it's just in the distance if you get my drift. House is going ok but I've got some long stories that go along with it, but not enough room to write them all down here. Lol. I'll have to put a few hours in on the crew soon just to keep my eye in. Happy for how yours is going though!!
07-09-2012, 10:36 AM | #96 |
The fire wall came out real nice.
Kim |
07-09-2012, 09:44 PM | #97 |
Your's had about as many holes as mine did! Makes you wonder what the hell there were adding on and taking off of the truck throughout its life...Looking good though.
07-10-2012, 12:44 AM | #98 | |
I don't know if its just me but it seems that GMC firewall's had a heap more holes than Chevrolet did? including that big ugly diamond cut out around the steering column? Or was that a Hydramatic thing?? Anyway we welded that part of the firewall up & drilled a 2 7/8" hole to make way for an aftermarket swivel mount. I planned to keep the original patina but decided to repaint the white roof as it had gone too chalky & had a decent dent in it that had to come out. Also repainting the top dash pad in the original dark turquiose with a hint of mettalic & of course the firewall in the same body colour. So far dent repairs have been done plus a little filler on the firewall to tidy up. Carmen's the body man, was happy to help out of work time, also brought the big guns down (his dad Joe) to help, thanks Guy's!
07-10-2012, 08:23 AM | #99 |
If that's factory paint on your cab floor it's about the most rust free one I've seen. I thought these trucks came with more rust than that when they were new, LOL. Nice work you are doing.
07-10-2012, 09:44 AM | #100 |
Russell, definitely original paint, a little surface rust here & there but nothing that a scotchie won't clean, both doors have a solid 3/8" size bubble on the bottom which don't look like changing in a hurry but thats pretty much it.
I do feel kinda lucky to have found this gem! Added a couple more pics of the cab.
