Old 11-12-2012, 12:23 AM   #76
Hart_Rod
Hart_Rod's Avatar
Re: ls turbo build
How's the install coming?
Hart_Rod is offline   Reply With Quote
Old 11-12-2012, 09:42 AM   #77
69trk
69trk's Avatar
Re: ls turbo build
Jegs sent the wrong flexplate.... I have to use the crank spacer (555-601010) and a FLAT tci flexplate (399753). They told me that the hughes flexplate (512-hp4004x) will work... But it's dished and won't allow the converter to pull up enough to bolt up to the flexplate... So if you install the spacer first then the TCI flexplate it will work....
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 11-12-2012, 10:28 AM   #78
Hart_Rod
Hart_Rod's Avatar
Re: ls turbo build
Bummer. Hopefully they will get you the correct parts soon and you can finish the install.
Old 11-13-2012, 07:12 AM   #79
Kainedogg
Kainedogg's Avatar
Re: ls turbo build
Great progress thus far brother. Got the motor in but ran into a snag with the turbo fitment. As usual I will be keeping a close eye on yours.
Kainedogg is offline   Reply With Quote
Old 11-13-2012, 10:13 PM   #80
19seventeeCustom
Re: ls turbo build
killer setup,, should be sweet,, keep us posted!!
19seventeeCustom is offline   Reply With Quote
Old 11-14-2012, 10:48 PM   #81
Kainedogg
Kainedogg's Avatar
Re: ls turbo build
Will do. My goal is 500 to the wheels. Really don't want to blow this 6.0 up...they are becoming harder to find...and pricier to boot.
Old 11-15-2012, 04:16 PM   #82
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: ls turbo build
Looking good. Following your progress.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 11-17-2012, 02:56 PM   #83
el_diablo
Re: ls turbo build
69trk- Do you post on MWSC as well? That pic of your truck in the avatar looks familiar. I had no idea you had all this turbo/ls swap going on! Nice work so far.
'49 Chevy 5window/S-10 frame. LS 408ci/4l80
'71 Chevy C10- Sold a long time ago.
el_diablo is offline   Reply With Quote
Old 11-17-2012, 03:23 PM   #84
69trk
69trk's Avatar
Re: ls turbo build
Yep, i'm over there....
1.58- 60'
11.37- 1/4 @115.81
Old 11-29-2012, 10:16 PM   #85
69trk
69trk's Avatar
Re: ls turbo build
Got motor and trans installed today.... Went real easy and motor mounts worked perfect!!! So i don't have to cut or lengthen my 3.5" aluminum driveshaft.... Engine slides real easy with these mounts... Now i have to order the steam line kit that uses the fronts and rears and then order my pro flo xt intake and throttle body... But for now i can install my driveshaft, shifter, radiator and hydraboost unit..
1.58- 60'
11.37- 1/4 @115.81
Old 11-29-2012, 10:17 PM   #86
69trk
69trk's Avatar
Re: ls turbo build
Look at all the room in front of the engine... Turbo should be fairly easy
1.58- 60'
11.37- 1/4 @115.81
Old 11-29-2012, 10:54 PM   #87
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: ls turbo build
looks like you could even move the motor back a bit
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-30-2012, 12:43 AM   #88
el_diablo
Re: ls turbo build
It looks great! I wouldn't move it at all. Leaves plenty of room to reach around and lots of clearance for that tall intake manifold. That thing is clean!
Old 01-21-2013, 09:45 PM   #89
69trk
69trk's Avatar
Re: ls turbo build
Haven't posted in a while, just trying to save for the new baby coming in early may. But i did order a ron francis wiring kit that came in today, that should keep me busy for a little while. I cut all the old wiring out of the truck, man what a mess lol....
1.58- 60'
11.37- 1/4 @115.81
Old 01-21-2013, 10:05 PM   #90
69trk
69trk's Avatar
Re: ls turbo build
Heres some picts of the wiring and the shifter. Not sure if im going to like the shifter or not. My helper wanted in the picture also..
1.58- 60'
11.37- 1/4 @115.81
Old 01-23-2013, 12:27 AM   #91
67c10rustbuket
67c10rustbuket's Avatar
Re: ls turbo build
Hey stranger, I just found this thread. I didn't know you were hiding over here in the LS section. Man your are kicking this up a big notch! That engine looks awesome in there. I will have to come over and check it out sometime.
On another note, I saw in the okie summer meet thread about your wifes due date and mine is due the same time..
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 01-24-2013, 09:49 PM   #92
69trk
69trk's Avatar
Re: ls turbo build
Must be one of the roofers lol
1.58- 60'
11.37- 1/4 @115.81
Old 02-23-2013, 11:24 PM   #93
69trk
69trk's Avatar
Re: ls turbo build
Just picked this up today for $375!!
1.58- 60'
11.37- 1/4 @115.81
Old 02-24-2013, 03:06 AM   #94
whitels1
whitels1's Avatar
Re: ls turbo build
Great build so far, keep it up...!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 03-21-2013, 11:31 PM   #95
prostreet1967
prostreet1967's Avatar
Re: ls turbo build
Hey 69 I'm from dfwss and mwsc I starting a turbo build soon. Starting to gather parts. Thanks for sharing the build now part numbers.
Can use pm me a link to those mounts? I have same stands as u and I am going with f body oil pan. Thats the same intake I wanna run can't wait to see some numbers
prostreet1967 is offline   Reply With Quote
Old 03-22-2013, 06:25 PM   #96
69trk
69trk's Avatar
Re: ls turbo build
The upper engine mounts are 355-3-1114g.
And the dirtydingo sliders just say dd-slider... I sent you a pm...
1.58- 60'
11.37- 1/4 @115.81
Old 03-31-2013, 04:20 AM   #97
prostreet1967
Re: ls turbo build
Where u gonna mount turbo?
Old 03-31-2013, 04:24 PM   #98
69trk
69trk's Avatar
Re: ls turbo build
Not sure yet. I'm moving the ac compressor up towards the top and i need to make sure the headers or a log style manifold will miss the ac compressor...
1.58- 60'
11.37- 1/4 @115.81
Old 03-31-2013, 04:29 PM   #99
85burb
85burb's Avatar
Re: ls turbo build
Have you seen this?
http://www.performancetrucks.net/for...k-kits-514181/
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 03-31-2013, 04:33 PM   #100
69trk
69trk's Avatar
Re: ls turbo build
Ive been looking at that, but needs to be a t6 flange. And i think the turbo would be sitting to close or in the way of the ac compressor. Unless i move it to the driverside?
1.58- 60'
11.37- 1/4 @115.81
