View Poll Results: If you had the option, which of these grills would you use?
Original 66 painted grill 1 20.00%
64-66 C60 painted grill 2 40.00%
an original aluminum grill that needs to be restored 2 40.00%
the repo aluminum grill that is now available 0 0%
Voters: 5. You may not vote on this poll
Old 07-13-2012, 02:12 PM   #76
MCCLELLAN103
MCCLELLAN103's Avatar
Re: pdx-sanity66
Thanks for the info, any new updates?
To Broke to be Fast
MCCLELLAN103 is offline   Reply With Quote
Old 08-24-2012, 11:55 PM   #77
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Well, between all the summer stuff I did, being back to work, and the heat, I have gotten very little done on my truck this summer but now that things are settling down I managed to get out in the garage again and got a little bit done. It's not much, but it's given me a some motivation to get going again. I cut the rust out of the passenger side kick panel and the corner of the floor and started to fit up the patch panels and made a couple of my own and actually got a small amount of welding done today. I'm hoping I can get most of the panels welded in tomorrow but here's the latest. This is the first patch panel I have ever made and welded on to anything. I'm pretty happy with it for a rookie.
pdxhall is offline   Reply With Quote
Old 08-25-2012, 01:21 AM   #78
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: pdx-sanity66
Nice patching.
66 C20 Service Truck:
Old 08-25-2012, 03:50 AM   #79
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Thanks. It's just a small start but I sat and looked at it off and on for a week before I built up the nerve to cut in to it and get started, but once I did there was no turninig back and I'm excited to continue.
Old 08-25-2012, 07:40 AM   #80
mark 66
Re: pdx-sanity66
looking good. we spent a good part of our day yesterday doing almost the same thing. I wish our truck looked that clean to start with.these trucks are kinda like a huge erector set.cant get in a hurry. we found a patch panel that goes 7 inches in from sill and drops all the way down to bottom of rocker.length wise it goes from seam of toe board to rear cab corner.did you get the inner kick to? or are you going to make your own?
mark 66 is offline   Reply With Quote
Old 08-26-2012, 01:48 PM   #81
idreama300
Re: pdx-sanity66
Looking good. I just received my floor pans, outer floor patches, and rocker patches. Need to get going myself.
idreama300 is offline   Reply With Quote
Old 08-28-2012, 01:33 AM   #82
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Yeah, I feel pretty lucky compared to some of the rust I've seen in these cabs. You can see in post #61 the patch panels I have ordered so far. I"ll probably need the same ones for the driver side. The floor panel doesn't quite reach to the seam where the floor meets the firewall, that is why I fabbed up the one piece you see above and I also have a piece I just welded in for the seam piece that's needed. I've done a rough cut out of the floor piece and started to fit it in place.
Once the floor is welded in I'll do the kick panel and then the bottom door brace. Then I'll clean up the original outer rocker and reinstall that. That will complete the passenger side and it's on to the driver side.
Sorry no pics today, I'm at work.
Old 08-28-2012, 02:03 AM   #83
ozzyman
ozzyman's Avatar
Re: pdx-sanity66
I wonder if your talking about the same problem I ran into, The patch panel for my floor from LMC didn't have the right angle at the firewall and as it approaches the edge of the cab the floor is about 1" away from the firewall, I will need to make a patch for that are so the two will meet.
Active Duty Air Force 02'-Current
Proud dad of 3 girls, 1 boy and 1 TBD in Dec of 2012 - Lucky Husband
"Family owned and operated since 1969"
Dad's 66' Custom Camper - Big Family Small Budget
ozzyman is offline   Reply With Quote
Old 08-28-2012, 05:56 AM   #84
mark 66
Re: pdx-sanity66
Must be the way they were stamped. ours part fit exactly the same way.
Old 08-28-2012, 06:23 AM   #85
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Yeah, all the floor panels I saw when I was deciding who to buy from were the same way. I wish they were made to attach to the firewall but then they would probably mess that up too and it would be one more thing to fix.
Old 09-05-2012, 11:45 PM   #86
Frizzle Fry
Frizzle Fry's Avatar
Re: pdx-sanity66
Subscribed. Nice Progress! Graveyard Shift: Been there, done that...
Frizzle Fry is offline   Reply With Quote
Old 09-09-2012, 06:30 PM   #87
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Good to hear from you. I haven't seen you around for a while. Have you been working on other projects?
Old 09-09-2012, 06:35 PM   #88
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
I didn't get as much done as I wanted this weekend but I managed to get the floor panel/inner rocker piece welded in that I've bee working on and started fitting up the inner kick panel patch to get welded in next.
Old 09-09-2012, 08:24 PM   #89
mark 66
Re: pdx-sanity66
nice job. looking good
Old 09-11-2012, 05:16 PM   #90
Frizzle Fry
Re: pdx-sanity66
Yep, the Minx is still in the works. Soon to test drive I was travelling quite a bit over the last year...
Old 09-12-2012, 11:56 AM   #91
theastronaut
theastronaut's Avatar
Re: pdx-sanity66
Love the cut down bench-to-bucket idea! The floor patch looks great too, I've got to do the same repair to Goldilocks eventually. I like the way you're saving the outer rocker, much better than using repro parts. Keep up the great work!
theastronaut is offline   Reply With Quote
Old 09-12-2012, 10:14 PM   #92
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Thanks John, I'm going to pick up some bench seats hopefully tomorrow and I'll have enough pieces to do it up right. I just mocked this one up to see how the dimensions are going to work out. This cutting, fitting, and welding body panels is all new to me. I'm learning as I go.
I'm a big fan of your work and I've been following Goldilocks since you started her. Your attention to details is where I'm trying to get someday.
Here's what I did this afternoon. The kick panel is fitted and ready to weld in tomorrow.
Old 09-13-2012, 08:43 AM   #93
theastronaut
Re: pdx-sanity66
Thanks man. Your panel fitment looks spot on! The kick panel patch panel looks good in the pics, any advise about getting them to fit? Looks like everything lines up well, would you use them again or did you have to do alot of work to make them fit?
Old 09-13-2012, 04:17 PM   #94
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Thanks, these panels fit very well. They're Triplus parts and I know a lot of repo parts are crap but these were the proper thickness and it took very little massaging to get them right. Maybe I was just lucky. The only thing I have found is that the bolt holes on both panels are a little off so if you go in to it with the idea of fittinig the panel and not the holes it's easier. They're close enough that I'll be able to drill them out a little when I bolt things together and it will be fine.
It would be nice to have the floor patch include the firewall seam but it's an easy piece to fab up if it's needed.
Old 09-13-2012, 05:26 PM   #95
theastronaut
Re: pdx-sanity66
That sounds great, I had to make that panel from scratch on the blue '65 and it was a pain, glad the repro's fit well!
Old 09-28-2012, 10:42 AM   #96
Bomp
Bomp's Avatar
Re: pdx-sanity66
Don't know how I've missed this build so far. Did a full read and subscribed. Looks great and I'm trying to get to this stage were your at.
Great build
Bomp is offline   Reply With Quote
Old 10-08-2012, 12:45 AM   #97
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
I got a little more done on the passenger side. I got the lower door pillar patch fitted, welded in and ground down, and drilled out the 4 bolt holes so they all line up correctly. Finished welding the inner rocker/floor panel along the vertical side, and started cleaning up and fitting the outer rocker. The outer rocker ended up having a couple of small places that I need to patch before it goes back on but the initial trial fit is great at the front and the rear is unchanged so it is fine. I also need to spray some epoxy primer on the bare stuff before the outer rocker goes back on. Then it's on to the driver side. I'm still looking for a driver side floor/firewall piece (toe board) so I don't have to fab one up. If anybody has a cab they are cutting up or parting out that has a rust free floor section that I can get a patch from, let me know.
I'll post some more pix soon.
Old 10-21-2012, 11:02 PM   #98
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
I was getting pretty far down the list so I thought I'd better post an udate. No new pics yet but I had to weld some patches in 3 or 4 spots on the outer rocker where the rust was starting to eat through from the inside. I test fitted the rocker and it fits good. I guess my patching so far has been good. On my next days off I'm hoping to get it welded back on.
I took advantage of a decent day and shot some epoxy primer on the steering wheel and the roof top clearance lights I've been restoring. The wheel and the lights have been patched and sanded and now that they're primered I can get them prepped and painted during the rainy season.
Here are a couple of pics before primering. I'll get some more updated pics on my next days off.
Old 10-22-2012, 12:31 AM   #99
markeb01
Senior Enthusiast
markeb01's Avatar
Re: pdx-sanity66
I love how you've adapted that horn button. Gives a real vintage quality to the wheel.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 10-22-2012, 04:39 AM   #100
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Thanks Mark, When I got the wheel the original horn button (plastic) was cracked so I was looking for a replacement. I found this one on ebay and decided to give it a try. A little modification and it fit great.
