Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 10-10-2012, 10:28 AM   #76
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: Project Family Truckster: 2wd Conversion Turbo LSx Blazer Build
Yes, I'm planning to box a few sections of the frame, as well as some additional stiffening. I'm also planning for a cage, to protect my family, as well as stiffen up an inherently flexy truck.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 10-17-2012, 03:05 AM   #77
floyd
A cage with some frame Tie-ins would be the hot ticket for reducing chassis flex for sure. With the HP you are putting in it,it probably couldnt hurt to have some extra safety either.
Too bad you are on the other side of the country from me. Building a bling cage wouldnt be too tough since the roof comes off.
floyd is offline   Reply With Quote
Old 10-17-2012, 10:01 AM   #78
Wasted Income
Boosted Member
LOL, you have no idea...I'm not one of those guys that builds a screamer then never uses it. I drive my toys like a rental
I think a tube bender is next up on my list of tools. I had the local chassis guy quote me a cage....while not at all unreasonable, I am fully capable of doing it myself....and I'll still have the tools left over. Plus, it's not like I'm planning to build a 25.5 cage or anything
Turbo diesel
Old 10-17-2012, 01:05 PM   #79
floyd
Im pretty sure if you build it to run....you are supposed to use it!
Tube bender is a great investment. I have built several cages and full tube chassis crawlers over the years its alot of fun. You may consider getting some tube bending software if you really get into it....
Old 10-19-2012, 09:14 AM   #80
Wasted Income
Boosted Member
Did some work the past couple nights. Got the front clip pulled off the blue truck, and the engine/trans pulled out. It's kinda bittersweet, seeing as I've been driving this truck for 16 years...
But then sad turns to pumped when I stabbed the drivetrain between the framerails for mock-up.
Ordered up some steel last night to get a transmission crossmember made. Planning to get the front suspension put together this weekend...and maybe the rear axle underneath it if I'm feeling motivated.
Turbo diesel
Old 10-24-2012, 10:29 AM   #81
Wasted Income
Boosted Member
So things are working out how I hoped they would. The Porterbuilt trailing arm crossmember will act as both the transmission mount, as well as the front driveshaft loop.
I was worried that if the mount plates for the trailing arms took a beating from the driveshaft, that they would tweak and bend.
Therefore, it seemed like a good idea to box them in. The additional material should make the side plates bulletproof in the event of a ujoint failure.
On to the trans crossmember.
Ended up using tube clamps that are typically used for offroad cages. Gotta love easy transmission removal....especially with my history of shelling transmissions.
Going to add some more tube bracing between the original hoop and the trans crossmember to tie it all together.
Turbo diesel
Old 10-24-2012, 10:36 AM   #82
smbrouss70
smbrouss70's Avatar
Where did you get those tube clamps?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 10-24-2012, 10:40 AM   #83
Wasted Income
Boosted Member
http://www.ballisticfabrication.com/...mp_p_1467.html
Turbo diesel
Old 10-24-2012, 10:50 AM   #84
smbrouss70
smbrouss70's Avatar
Thanks, I've been looking for those to use on my trans x-member.
Looks good!
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 10-25-2012, 10:37 AM   #85
FTP
FTP's Avatar
Nice on that trans crossmember...hey Wasted...is that turbocharger setup on your 5.3 a kit, or did you fab that together.
FTP is offline   Reply With Quote
Old 10-25-2012, 11:11 AM   #86
Wasted Income
Boosted Member
I fabbed it from scratch.
In fact...I'm thinking about selling this setup as a kit to fit a 69-72 C/10. (Not to produce, just this specific setup).
I kinda want to build something different to package it a little differently to allow for A/C.
Turbo diesel
Old 10-26-2012, 10:38 AM   #87
Wasted Income
Boosted Member
All the parts for the Megasquirt MS3x.
Capabilities include realtime tuning with wideband feedback, electronic boost control, 3-step rev limiter, launch control, traction control capability, progressive water/meth control, bluetooth logging and tuning, 2 stage variable nitrous control, E85 flex fuel sensor control, dual fuel table switching, 2.5 bar MAP sensor.
Turbo diesel
Old 10-30-2012, 09:37 AM   #88
fxdxharley
Just a nother gear head
fxdxharley's Avatar
So are you building your own harnesses for the lsx or do you you use the factory one and modifiy them?
2013 HD FLHX
2000 chevy 2500 6.0l 4x4 3dr
2000 harley fxdx
71 Jimmy 4x4- future crawler/ woods rig
71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589
fxdxharley is offline   Reply With Quote
Old 10-30-2012, 10:29 AM   #89
Wasted Income
Boosted Member
I typically take a factory harness and modify it to be a stand alone. However with the megasquirt, I'm hacking up a factory harness for the sensor pigtails, and building a completely new harness.
Turbo diesel
Old 11-01-2012, 01:11 AM   #90
Wasted Income
Boosted Member
Made some big progress tonight. It rolls again.
Assembled the front suspension
Got the rear axle back under it
Then set it on the ground and rolled it back and forth a few times
And some glamor shots. Seeing it sitting on wheels got the motivation stoked up again.
Turbo diesel
Old 11-01-2012, 03:59 AM   #91
jjzepplin
jjzepplin's Avatar
WOW that looks MEAN!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 11-01-2012, 05:03 PM   #92
etindoll
That thing is going to be killer!
etindoll is offline   Reply With Quote
Old 11-01-2012, 08:33 PM   #93
duallyjams
duallyjams's Avatar
really like the last pic , that's sweet
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 11-01-2012, 09:42 PM   #94
fxdxharley
fxdxharley's Avatar
that looks sweet. I like the stance. is that at your aprox ride height? What front coil over are you using?
2013 HD FLHX
2000 harley fxdx
Old 11-02-2012, 09:35 AM   #95
Wasted Income
Boosted Member
Thanks guys.
I think the front ride height will be close to that in the end. The coilovers are at the lowest setting now, and I will crank them up a bit to maintain that height when the tub/front clip/cooling system/turbo plumbing is installed.
I was trying to get away without notching the rear rails, but I'm not a huge fan of the rake, so I want it to sit more level (lower) in the rear. I also want room so it won't bottom out with 3 buddys and a full cooler in the back seat.
Turbo diesel
Old 11-02-2012, 05:40 PM   #96
jaros44sr
jaros44sr's Avatar
Great build, and exceptional talent! Enjoying your work, almost as much as you...
Thanks for taking the time to post up, keeps me entertained
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-02-2012, 10:32 PM   #97
PHAT TONY
PHAT TONY's Avatar
I reckon you'll want at least a small frame notch; I'm gonna do one pretty quick here.
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 11-04-2012, 09:48 PM   #98
lt155ruck
lt155ruck's Avatar
Great progress so far. I think a c- notch will have to happen.... especially if your beer cooler has to support your three buddies. LOL. My 72 doesnt have one yet and the rear pings off the frame from time to time.
lt155ruck is offline   Reply With Quote
Old 11-05-2012, 09:57 AM   #99
Wasted Income
Boosted Member
Thank you, I appreciate that. Posting about it keeps me entertained at work, also
Yeah, after looking at it a little closer this weekend, I agree with you guys. However, the next issue is that the top of the diff will contact the bed floor at full compression if I go too much lower with it. I had that problem with the blue truck. I guess I could maybe fabricate a "bump" for the bed floor to clear the rear axle center section. I'm gonna think on that one a bit yet.
Not a ton of progress on the blazer over the weekend. I did get the tubes cut and notched to tie the trans crossmember to the trailing arm crossmember.
Also did a lot of measuring...standing around...measuring...scratching my head....measuring....trying to figure out where exactly I want to mount the coilovers in the rear.
Turbo diesel
Old 11-09-2012, 12:31 PM   #100
Wasted Income
Boosted Member
Ordered up some RideTech single adjustable coilovers a few days ago, and they showed up last night. Very nice units. I mounted them to the "stock" location on the Porterbuilt lower arms, and the upper shock crossmember. The packaging is nice, but I don't like how close together they are. I have the room to move them outboard on the frame, and behind the axle, which should increase the lateral stability quite a bit. That should also allow for mounting the coilovers in double shear. Time to fire up the welder and plasma again this weekend and cut up some more perfectly good parts.
Turbo diesel
