Old 09-28-2013, 03:03 PM   #76
crossfire84
crossfire84's Avatar
Re: LIL ERV the 50
then i did the upper control arm. same way as the lower.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 09-28-2013, 03:14 PM   #77
crossfire84
Re: LIL ERV the 50
A arms on the truck after mod.
A before shot.
And after.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 09-28-2013, 03:25 PM   #78
crossfire84
Re: LIL ERV the 50
Went to the junk yard awhile back and picked up a serpentine bracket set off a 95 chevy truck and blasted them at work, then painted them with Eastwood aluma blast paint. Then mounted them with a KWIK performance adapter kit to the Big block, the fit is fantastic, pulls every thing in tight. Also refinishing the AC and the power steering pump that came with it.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 09-28-2013, 03:39 PM   #79
runpasthefence
runpasthefence's Avatar
Re: LIL ERV the 50
Great job on those control arms. I'm also working on putting a 50 on a C-10 frame. Yours looks great so far.
runpasthefence is offline   Reply With Quote
Old 09-28-2013, 04:31 PM   #80
crossfire84
Re: LIL ERV the 50
thanks, you need a build thread so we all can see, good luck.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 09-28-2013, 05:32 PM   #81
_Ogre
_Ogre's Avatar
Re: LIL ERV the 50
nice work on the A-arms
have to ask... finger jointed bed wood?
shop air compressor timer
Old 09-28-2013, 07:01 PM   #82
crossfire84
Re: LIL ERV the 50
yes, these were cut offs from a furniture maker. instead of trash they made a bed for there work truck and now it's big part of there business. plus the wood was only $149.00 cut,milled,sanded, and it's all oak, how could i pass that up?
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 09-28-2013, 07:56 PM   #83
99 to Life
99 to Life's Avatar
Re: LIL ERV the 50
A arms look great.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 09-28-2013, 09:09 PM   #84
crossfire84
Re: LIL ERV the 50
Originally Posted by 99 to Life View Post
A arms look great.
thank you, a lot of work.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 09-29-2013, 06:43 PM   #85
av8tr33337
av8tr33337's Avatar
Re: LIL ERV the 50
Sh!t.... LOL I was going to use a 79 C10 IFS but decided on an s10 swap instead because of the track width. I never even thought about narrowing the control arms like that. Great job. I would not be surprised if we start seeing more of the C10 IFS swaps now. I don't know if you are a member of the H.A.M.B but I bet they would appreciate a little write up on what you did over there.
av8tr33337
AKA Bartman Email av8tr33337@yahoo.com
Bartman's Ad-S10 Chassis Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=415418
My First Youtube Video
http://www.youtube.com/watch?v=B6hSt...eature=channel
More Pics of the 51 Project
http://s668.photobucket.com/albums/v...hassis%20Swap/
1951 3100 Pickup
av8tr33337 is offline   Reply With Quote
Old 10-01-2013, 06:20 PM   #86
crossfire84
Re: LIL ERV the 50
thanks, the saddle swap was not that hard to do, plus i only paid $60 for it at the bone yard.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 10-04-2013, 10:29 AM   #87
ghettoluxury
ghettoluxury's Avatar
Re: LIL ERV the 50
Thanks for posting the control arm mod. I need to narrow the lowers on my 73 and was thinking of using tubular arms, but this looks like a very good option.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 10-04-2013, 11:04 AM   #88
Dan in Pasadena
Dan in Pasadena's Avatar
Re: LIL ERV the 50
Ok, so I've gotta ask if that narrowing of the A arms will change the suspension geometry?
On one hand it seems like it would HAVE to. And that could be a bad thing.
On the other, I'm thinking the attachment points are unchanged, the arc the A arms swing through as the springs compress/extend is unchanged...well, except for the distance from the pivot points...hmmmm?
If the fabricator is extra careful to make the modifications EXACTLY alike - and I'm sure you did - very nice looking mod by the way.
Anyone extra knowledgeable about suspension geometry able to provide some insight?
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 10-05-2013, 05:22 AM   #89
47 Fasttoys
47 Fasttoys's Avatar
Re: LIL ERV the 50
OK, first off I'm no suspension expert but just the same I'll through some ideas out there. This is just a guess at the numbers here so bear with me. Lets say you have 600 lbs. springs on the front and lets also say the distance between the pivot points (A arm mounting and spindle mounting) is 14". With the spring (which can be seen as a pivot point in a basic lever) in the center of this distance. If a 600 lbs spring is compressed 1.5" it has a load of 900 lbs. acting on it. So if a normal load compresses the spring 1.5" and this equals 3 " change at the tire then reducing distance on one side of the lever will change the balance point of the lever (the spring) from a ratio of 1:1 to a ratio of .714:1 so now it will take 1260 lbs of force acting on the tire to compress that spring 1.5". Because your truck still weighs the same it will rise by .85" this in turn change the alignment for sure. I'm thinking you may need to cut the coils by 3/4 of a coil each to maintain the same ride height and you will still get a stiffer ride. Of course all this is based on my guesses on measurements.
Boy this chit will make your head spin
Rob
47 Fasttoys is offline   Reply With Quote
Old 10-05-2013, 05:29 AM   #90
47 Fasttoys
Re: LIL ERV the 50
Sorry double post
Old 10-05-2013, 10:18 AM   #91
99 to Life
99 to Life's Avatar
Re: LIL ERV the 50
I wouldn't look that deep into the springs. If your ride height is good, odds are its going to be fine. Especially with the c10 drop springs, they probably have a higher compression rate than stocks anyway. Bringing the Aarms in I think would stiffen it up a tiny bit and "may" make it rise a little if any. Cuttin coils is an option if you want it lower, which I'm always in favor of. Best way to know is if he measured something before and after to reference height.
Old 10-05-2013, 03:43 PM   #92
crossfire84
Re: LIL ERV the 50
the ride height is less than 1/2'' higher now than before the mod. and the coils are 3" drop already.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 03-30-2014, 09:23 AM   #93
mechanixman
mechanixman's Avatar
Re: LIL ERV the 50
I'm loving what you did so far.
Any updates?
-Nick
Projects:
1952 Chevy 1 ton = The Build page
mechanixman is offline   Reply With Quote
Old 03-30-2014, 09:36 AM   #94
crossfire84
Re: LIL ERV the 50
Any updates?
Soon, this winter has been the worst in many years, too cold in garage even with insulation and heat. (so much for global warming). I just sold my motorcycle so now I have more than enough $$$ to finish the truck and be on the road hopefully this summer! I"ll keep posting along the way.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 06-03-2014, 08:22 PM   #95
crossfire84
Re: LIL ERV the 50
So i put my 2 favorite rides together a 50 chevy and a 1954 buick. I put the portholes in the hood today, Now i'll send then off to be plated.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 06-03-2014, 08:48 PM   #96
99 to Life
99 to Life's Avatar
Re: LIL ERV the 50
two nice rides of course. I dig portholes. looking good.
Old 06-04-2014, 07:40 PM   #97
crossfire84
Re: LIL ERV the 50
thanks it was a fun job.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 06-05-2014, 08:00 PM   #98
FarmerSid
FarmerSid's Avatar
Re: LIL ERV the 50
Portholes....How'd you install them? New term and feature I haven't heard of.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 06-06-2014, 05:13 PM   #99
crossfire84
Re: LIL ERV the 50
Install was easy, first i chose a spacing on the hood, then made a template out of cardboard. taped the template to hood then with my trusty sharpi marker traced out the template on both sides. then i used a 1-1/2" hole saw and cut out each corner, warning use a sharp pilot drill! this will leave a small center section that i removed with a die grinder. then it was remove a small amount at a time testing the fit. all 6 took maybe 1.5 hrs.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 06-07-2014, 07:37 AM   #100
FarmerSid
FarmerSid's Avatar
Re: LIL ERV the 50
That's a slick mod.
C4 IFS & D44 IRS
5.3 HO L33
